Taking of a vw manifold end castings, is there an easier way? uugggghh....
Discussion in 'The Hokey Ass Message Board' started by Anti-Trend, Jan 13, 2007.
  1. Anti-Trend
    Anti-Trend
    from SW WA
    So I'm putting a Weber 40mm 2 barrel on my bug and I need to take off the end castings to fit in the new middle section for the weber. I've tried all my wrenches but I can't fit anything in there, any suggestions? This such a pain in the ***, anyhelp would be nice.
    thanks-nicholas
  2. DE SOTO
    DE SOTO
    You Need A Socket To Fit In There !!!!!!!!
    You Will Never Get It With A Wrench !!!!!!!!!
  3. Anti-Trend
    Anti-Trend
    from SW WA
    well I kinda meant wrenches sockets whatever, everything. so do you have anything helpful to say?:confused:
  4. Frank
    Frank
    Just a thought, but maybe you can install the carb onto the manifold and then install the manifold?
  5. james
    james
    A socket, a universal joint, and a short extension.
  6. Anti-Trend
    Anti-Trend
    from SW WA
    well, vw manifolds have 3 peices to them and I need to slide out the middle piece of the manifold, putting the carb on really plays no part in this. Its all about the manifold......
  7. lenmann
    lenmann
    from NorCal
    1/4" drive universal joint socket on a long (12") extension, 13mm if I recall right. It is pretty tight around the intake castings.
  8. lenmann
    lenmann
    from NorCal
    Now that I think about it some more, once you get them off, replace the 13mm nuts with 12 mm hex nuts off of a rice burner. Gives you some more room next time.
  9. TERPU
    TERPU
    If it's a single port take a box end wrench and heat and bend it until it's got all the right angles then cut it to length so you can get moe than 1/8 turn, this is a real *****, but then if your taking out the center section it's 13mm nuts in the dual port heads. I used to use a short socket and a wobbly, it was still pretty slow going but it worked. It's kinda like adjusting the clutch on a volksie, you just gotta be patient. Dont over tighten 'em going back in, they can and do crack.
    Good luck,
    Tim
  10. Bad Bob
    Bad Bob
    from O.C. Baby
    Yea. Go on a VW website and ask those dumb***es!
  11. Anti-Trend
    Anti-Trend
    from SW WA
    jeez bob, why so angry? I was asking here because most everybody into cars have touched a vw atleast once in there life.
  12. SinisterCustom
    SinisterCustom
  13. screwtheman
    screwtheman
  14. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    VW questions usually draw fire here. It's not what the site is about.
    And by the way, a few of us have touched "dirty girls" once in our lifes but you don't see us asking questions about STD's...
    :D
    You got your answer. I'm just funnin' ya.
  15. S.T.P.
    S.T.P.
    Seems like you know all about it, Why are you asking anyone else?
  16. Anti-Trend
    Anti-Trend
    from SW WA
    I already know about the samba, the forums there are a bit slow, and never mind, I was just in the garage and managed to get them off........hooray!:D
    Flat Ernie likes this.
  17. noboD
    noboD
    Desoto WAS being helpful. It can't be done with a wrench, which is what you ask about. He said use a socket. Maybe you need someone to come do it for you!!
  18. so, people who like vw's are dumb***es??? not the one's i know.
  19. Thanks, Matt.
    There's VW powered dragsters in the mid- 6's in the /14 mile.
    There's street-driver door-slammers in the low 9's
    To the original poster-
    Get some 12mm nuts, go into Autozone and ask for exhaust nuts for a Vanagon.
    Get a 12mm, 1/4 inch drive, that has a universal incorporated into it.
    I used to work for both of the US-based VW magazines, if you have any questions, to avoid WorldWar 3, just PM me.
  20. Automotive Stud
    Automotive Stud
  21. Bad Bob
    Bad Bob
    from O.C. Baby
    I'm not angree. I was a VW mechanic for 10 years. Must have been post VW psycosis.
  22. Bad Bob
    Bad Bob
    from O.C. Baby
    No. Just the ones who go to a Chinese restaurant and ask for a hotdog. See where i'm coming from? FNG(**** with the NEW GUY)
  23. metalshapes
    metalshapes
    This Thread could have ended here, because Tudor took care of it.
    Thanks for doing that... :)
