Talked to the blaster today
Discussion in 'The Hokey Ass Message Board' started by mjxlange, Mar 27, 2008.
  1. mjxlange
    mjxlange
    from SW Florida
    He stated that it would be imposable to get all of the rust off my model A. So I think I will get some por 15 and try to seal the rust. How many have had success with this
  2. PsychoBandito
    PsychoBandito
    from Montreal
    how would it be impossible? it's an A, there's no crazy corners to get into.
    rust sealers are a last resort in my opinion. i'd get a grinder and a sanding disk and get whatever he can't get.
  3. zman
    zman
    from Garner, NC
    does he mean it'll still be pitted bad? you can treat that with Ospho... but I'm to the point where I prefer dipping to blasting... it'll take everything but concrete away...
  4. Look for another blaster.
  5. 460 willy
    460 willy
    from wisconsin
    I have used POR-15 and it is very very good stuff but I would use it as a last resort I would get a second opinion as far as the blaster goes. Willy
  6. Goztrider
    Goztrider
    from Tulsa, OK
    He may just be trying to cover his *** from a liability standpoint. If he can't get it all, he doesn't want you to come back after him for paint issues.
  7. Squablow
    Squablow
    My thoughts exactly. You don't want to work with anyone who says that. Dipping is another option, but there's no reason that car can't be thoroughly and completely sandblasted.
  8. I would be comfortable using POR-15 on the underside and any other sheet metal that you do not plan to finish paint. You can never get all the rust. So once you have done your best I recommend using an epoxy primer. Sticks to everything and seals the surface from mosture and air.
  9. Cshabang
    Cshabang
    Por 15 doesn't seem as good as it use to be...
  10. cruzr
    cruzr
    like others have said..........get someone else....this guy sounds hokey to me
  11. Ruff T
    Ruff T
    from NJ
    I don't know how true it is, but I have heard over time POR-15 reacts poorly with the suns ultraviolet rays so you must paint over it. I have never had a problem with POR-15 but I have only used it on engines and ch***is.
  12. Primo
    Primo
    Where do you get your stuff dipped zman? And around how much would an A cost if you know (rough estimate)?
    - Primo
  13. Psychobilly351w
    Psychobilly351w
    from 732- NJ
    This guy is a Joke. My uncle owns a Powder Coating Busniess and he can media blast anything. Sounds like you should find another blaster.. POR15 is garbage.
  14. ray
    ray
    from colorado
    what's wrong with it?
  15. SaltCityCustoms
    SaltCityCustoms
    Never heard of such a thing, get another blaster he just plain doesn't want to do the job.
