Tall Shifter Auto Trans -QUESTION
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Oct 5, 2010.
  1. fordstandard
    fordstandard
    SAFETY QUESTION
    I have a C4 and want to use Tall Shifter with Elvis Mic ------
    Question--- some have told me that shifters have come out of gear and can be dangerous?
    *Some have discussed ; Gennie/Lokar / Ford Aerostar Van Shifter/Mustang Shifter Made longer
    ** I am not clear on what way to go ???
  2. GassersGarage
    GassersGarage
    Lokar has a positive lock. I've never had it fall out of gear but then again, I don't have a heavy knob.
  3. This is common knowledge, no need to bring it up again :)
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    no problems with my lokars
  5. big creep
    big creep
    hahahahahaha!
  6. allstarderrick
    allstarderrick
    Had a tall shifter in my pickup and it did come out of gear a lot. It had the stock knob on it too. Took it out and put the shifter on the column.
  7. BISHOP
    BISHOP
    Lokar shifter wont pop out of gear, if you change from the factory knob you will need the Lokar adapter. The adapter makes it so you have to press down on the knob insted of the factory ****on.
  8. fordstandard
    fordstandard
    What about using - Ford Aerostar Van Shifter OR extend length of early mustang shifter?
  9. Bad Bob
    Bad Bob
    from O.C. Baby
    I've got the 36" Swan shifter in my Merc,and have never had a problem with it...
  10. RustyNCA
    RustyNCA
    Wish I could say that, mine will downshift to 2nd on a hard bump, or up to 3rd from 2nd. But never down into 1st or into neutral.
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Its all in the set up dude..trust me..
    is it a floor mount or trans mount..not that it matters because i have both.and neither of them do this..as a matter of fact the way i have mine adjusted you gotta work at it to make it shift out of park, or drive.
    dont go by the factory set up..these are not just 1-800 bolt it in and go, they are adjustable and usually are not set up for every type of config.
    what trans? believe me..it makes a difference too
  12. whistlebritches
    whistlebritches
    from texas
  13. Beebeebobby
    Beebeebobby
    from Webb City
    From the looks of those pics I am gonna have to get a tall shifter for my Falcon...:)
  14. choppedrod63
    choppedrod63
    UMMM What shifter????
  15. fordstandard
    fordstandard
    WOW! I not only got some answers but now i need a cold shower from those pics--awesome women,i'lltake the redhead !
    ** Seriously, some more feedback please. I want to know what way to go with my shoebox and C4 ---
  16. iammarvin
    iammarvin
    from Tulare, Ca
    Thanks Bob, will those cuties put my tall shifter in gear?????
  17. fordstandard
    fordstandard
    What lenght (tall shifter) should i be lookin for to use in shoebox ford with my Elvis Mic as shifter knob?
  18. fab32
    fab32
    How would you know if you had a problem?;) Seriously Bob, you live in your world..................the rest of us.............not so, ah...er.....fantasy oriented. BTW, need application to Bob's World........any available?
    Frank
  19. gimpyshotrods
    gimpyshotrods
    What I would give to visit Bob's world, if just for one day.
  20. diamond dave
    diamond dave
    i had the 23 " tall , swan neck lokar , with the shift knob adapter in my 50. it sat at about radio level. it's in my albums. check it out to get an idea.
  21. tripleduece
    tripleduece
    +1 for the super tall swan...I had one for years and never had a problem..... DO watch out for the rearview though!:D
  22. themoose
    themoose
    I've got a tall Lokar on a 700r4. It took a lot of work to get it to select all of the gears to the point where I had to modify the detents to get everything to work properly. Once set up, it never jumps out of gear and works great, even with a heavy knob.
  23. RustyNCA
    RustyNCA
    It's a trans mount on a 350, I have played around with it, but don't really know what I am doing, just guessing. It is hard to get it into 1st, and it does move up or down from 3rd and 2nd.
    It can be not real good, I was driving the car back from Pinks a few weeks back and on 680, hit a bump that dropped it from 3rd to 2nd on the freeway. The guy I bought the car from had welded a little thing on the trans tunnel to flip over and hold the lokar in third, that didn't work at all.....
