Tapered donut to mount tie rod end for split bones
Discussion in 'The Hokey Ass Message Board' started by qzjrd5, Nov 8, 2006.
  1. qzjrd5
    qzjrd5
    from Troy, MI
    I am all set to start my bone splitting project. I am searching the Speedway catalog, getting the tie rod ends, jam nuts, bungs, and then I started looking at the bolt on radius rod brackets they have.
    I really don't need all that whole big bracket, all I want is the 7 degree tapered holes to mate with the tie rod ends. Then I will weld the donuts to a couple of my own fab'd brackets.
    Does anyone just sell the tapered donuts or do ya gotta buy the big ass brackets? If not, I don't have access to a lathe, so I'll probably shell out the dough and get the brackets.
    I don't have any old steer arms sitting around, or I would steal the tapered ends off of those.
    Thanks for any input you guys have - you're the best.
    Mike
  2. Johnny-B-Bad
    Johnny-B-Bad
    You could try a piece of thickwall tubing and get a 7* reemer. Think speedway also sells those. Cut the piece of tubing to whatever lenght you need and reem the center to the 7*.
    John
  3. Royalshifter
    Royalshifter
    Moderator
    The cut off ends of some old spindle arms work great.
  4. PM me your address and i will send you a pair of "donuts"
  5. Frank
    Frank
    The tool alone is about $80 and best suited for use on a drill press where you have some control.
    A machine shop would probably do it for not too much.
    Looks like 36-3window has you covered though.
  6. bills model a
    bills model a
    call speedway they have them
  7. qzjrd5
    qzjrd5
    from Troy, MI
    36-3 Window is the man....I sent you my address.
    Thanks for the info on Speedway also!
    Thanks again to all y'all.
    Mike
  8. bobw
    bobw
    Speedway Motors has them. Part #916-36502. $3.95 each. It is called a shock eye. Page 31 in my catalog. I've used them successfully.
