Hi, i'm new on this Forum; i'm living in south of france and i'm workin' on an hot rod project. i've bought a '30 cabriolet with a lot of rust one year ago. I'm gonna powered it with an econoline 302 SB Ford and want a traditionnal channeled hot rod look with split wishbone and buggy spring rear end. i'd like to use a F1 steering box on original position and i like to know where can i found a tapered hole pitman arm for it ? thanks Vincent - hotrodder from over the sea
Joblot has them for $45 brand new. Part #8C-3590. Go to www.joblotauto.com They also have all the bearings and gears for a complete rebuild.
F1 boxes and ford cross steer boxes(30's thru 48) share the same internal parts. A ford passenger pitman arm will fit a F1 box and uses a tie-rod end instead of a ball/socket.
If getting rid of the ball is the issue, why not just saw it off, drill a hole, and taper to suit? Speedway and several circle track suppliers have reamers in standard automotive tapers.
If the splines are same as the 53-56 F-100 box (I think they are), then use a pitman arm off a 57-60 F-100, it is the same as the 53-56 ball and socket arm, except has the tapered hole for a tie rod end.
