Tapping a fingernail-what's the best way?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Jan 26, 2009.
  1. usmc50lx
    usmc50lx
    from St.Louis
    I recently had a doctor in the ER use a laser after I kept my XS yamaha off the highway with my pinky for this and that **** was cool as hell I didn't even know he did it til it was a spurtin I've used a paper clip but that laser was cool!
  2. BillBallingerSr
    BillBallingerSr
    from In Hell
    A hot sterile needle does the trick. Believe me, when you spurt that blood out from under that nail it will be like Christmas. If you go to the ER, thats what they do, drill it and squeeze it. It hurts for a second and then its like someone whos been standing on your toe stepping off. The throb will go away too. Its a blood blister under your nail and any blood blister is relieved the same way, you have to drain it or its going to throb for days.
  3. No hammer. Just slipping with wrenches in tight spaces
  4. hotrodladycrusr
    hotrodladycrusr
    Didn't have your mind on your work today huh?:rolleyes:
    Don't worry just cut off those fingers....you've got 8 more.:D
  5. flynbrian48
    flynbrian48
    Yup. My Dad did that a couple of times, always made me queasy. I've used a hot pin as mentioned.
  6. 56sedandelivery
    56sedandelivery
    The technical term for what you're referring to is a "subungual hematoma". The procedure to make it more comfortable is called a "window in nail", and is usually done with a red hot paper clip, or what amounts to a relabeled micro circuit soldering gun. Here's the real concern. You must make sure you have not fractured the distal phalanx (end of the finger); otherwise, when you do the window in nail, you essentially just made a simple fracture a compound fracture. IF bone gets infected, it's not easy to treat, and can be a lenthy process. So, get it X-rayed, get yourself covered medically (antibiotics and pain meds), and only practice self treatment as a last resort. Butch/56sedandelivery.
  7. Danimal
    Danimal
    Denise, don't be a hater! He was probably thinking about you! :cool:
  8. Same here...lets start a club!:D
  9. My shop's been so slow, I'm not used to working. I've been leaving my schedule free for much valued guests;)(that'd be YOU). BTW, shouldn't you be looking for the worst possible picture of me for when you do***ent your trip?
  10. Goozgaz
    Goozgaz
    Try this...
    Put about 4 (5 if you can) ice cubes in your mouth then stick your left hand thumb up your **** and you right hand thumb under your left arm pit. Won't help the swelling any... but it will prevent more smashed fingers.
  11. hoarder1212
    hoarder1212
    I have tried the hot needle and don't much care for it. I like to go over to the bench grinder and grind a small hole in the nail. It doesn't hurt as much and it is quicker!
  12. junkyardroad
    junkyardroad
    from Colorado
    I was thinking this might be bad until I saw that pic. What are you worried about?
    Weenie.
    Get back to work
    Lol.
  13. Model A Mark
    Model A Mark
    from dallas
    dude that ant your thum is it ?
    omg
  14. [​IMG]
  15. noboD
    noboD
    A couple years ago my buddy at work smashed my social finger . End of my finger was broken in four pieces and turned sideways about 45 degrees. Doc had to remove the nail, fix the break with a pin, then s***ched the nail back on to protect it.
  16. I really cant see the hole
  17. No, it's my[​IMG]
  18. It's funny all the response this thread's got. So, ya like someone elses pain do ya?[​IMG]
  19. I cant tell you how many times I have been there !!
  20. zbuickman
    zbuickman
    I use a small file and file a hole(gouge) through it slowly. thats the least painful.
    second is the exacto knife.
    third is spinning the drill bit with your fingers #36 max
    anf fourth is that hot pin ****. that hurts almost as bad as smashing it:eek:
  21. pan-dragger
    pan-dragger
    i think your gonna live groucho. **** hurts, glad it's you and not me.:D
  22. hotrodladycrusr
    hotrodladycrusr
    That's what I did at work today....didn't take long.:D
  23. BrandonB
    BrandonB
    from nor cal
    Stick it in cider........it'll either give you a warm fuzzy feeling or a black eye.
  24. And now if your nail dies and a new one starts to grow underneath yo cun pull the old one out with some pliers. I have done this much relief
  25. phukinartie
    phukinartie
    Thanks for the case of the heebey geebies
  26. 66Newport
    66Newport
    I have always done the exacto trick. Worked for me.
  27. 5wbomber
    5wbomber
    just cut the tip off, thats how i solved it.
  28. Now wait till you forget about it for a minute and cram your hand in your pocket, or try to wipe your ****.
    You'll try not to forget about it again after that...but you will.
    Does that earn me the dual fingers icon?
  29. Mercury Kid
    Mercury Kid
    Got to do this after putting new kingpins in my econoline axle.:D
  30. Ranunculous
    Ranunculous
    Soak the offending finger and nail in fresh DISTILLED turpentine.It'll release some of the soreness and then you can address the nail.
    Good luck and relief soon!
