Tarp Garage Moisure problem
Discussion in 'The Hokey Ass Message Board' started by Fedcospeed, Dec 4, 2011.
  1. Fedcospeed
    Fedcospeed
    Hey. Put up tarp garage for winter storage of car and parts.Put plastic down first then tent.This is a older unit so i was concerned about leaks.Bought some big plastic tarps and covered her up good.Went in it yesterday to do mouse control and noticed it is sweating inside a bit.Things havent frooze up here yet.
    I was told today by a friend to hang a burlap bag with salt pellets in it over a bucket.Absorbs water and drips down.Has anyone tried this???Next thing would be some kind of vent system but how without cutting tarp.Thanks
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    It's a no-win never ending battle.
  3. 73RR
    73RR
    ...something about salty air and tin that doesn't sound too good...
    Venting works as long as the air you bring in is drier than the air inside. A small bathroom type fan with the 4" flex ducting run out of a corner will move air around.
    You can try hanging a couple trouble lights in there, or a couple halogen fixtures, or find a small dehumidfier and let it run.
    On days when the rain/snow aren't coming in sideways then open the ends and let the cold-dry air blow through.
  4. Comet
    Comet
    Make a lean-to with no sides. The intent is to shed water off, but let it breathe. The tarp should not be touching the car anywhere.
  5. 1971BB427
    1971BB427
    from Oregon
    A couple 60 w. lightbulbs work to keep mine dry. I've had one up for 2 years now doing day to day upgrades, plus storage on my g***er. I've got fluorescent lighting for working, but leave the incandescent for when I'm not in there.
    Wont be as bad once it's cold and dry, but extreme temp changes make more humidity.
  6. TomT
    TomT
    Venting is the key - with that inability, keeping the air moving is another choice using a fan preferably from above. I have to do that in my garage until I find a good way to vent it.
    I do like the lightbulb trick, though - alot of guys use that in their small well water pump-house enclosures so I know it works/helps.
  7. Crystal Blue
    Crystal Blue
    X2 on venting. It's a must, just like on your house.
    Buy some gable venst at your local home improvement store
    and install them. It wont' be warm, but it will be dry.
    Good Luck !
  8. chaos10meter
    chaos10meter
    from PA.
    Never tried it but have heard from boaters to get a bag of charcoal, like you burn on your grill and just slit the bag open it supposedly draws in the moisture ?
  9. llonning
    llonning
    There are some products out there, mostly designed for the travel trailer people, that draws in moisture. Only name I can think of is Dri-z-air, but there are others brands. I have been told they work great. Also fairly inexpensive. Hope this helps.
  10. brokenspoke
    brokenspoke
    The tarp should not touch car, period....Nothing will keep it from sweating if it does...my 2 cents worth
  11. macs67
    macs67
    If you want to install vent or even a door get 1" x 2" x 8' sticks cut pieces to the size of your louvered gable vent bought from your lumber yard make 2 sets of frames, cut whole in plastic near the roof, screw from the outside of one stick through plastic into stick on back in other words sandwich your plastic with frames on the outside & inside... install vent.
