Taylor 8MM plug wire install question
Discussion in 'The Hokey Ass Message Board' started by 36tudordeluxe, Dec 19, 2013.
  1. 36tudordeluxe
    36tudordeluxe
    Got a Taylor plug wire kit with 90° boots and am unable to pull plug wire with plug connector back through the boot; the wire pulls out of the connector before it can make the 90° turn inside the boot. Have put silicone on the wire and in the boot but no success, any ideas? I don't have the instructions that would normally come with the kit.
  2. V8 Bob
    V8 Bob
    You may not have a good crimp on the connectors. Plus, pushing the connector into the boot along with pulling the wire a little at a time will give better results.
  3. ebfabman
    ebfabman
    Warming up the boot a little may help.
  4. tfeverfred
    tfeverfred
    Yep. Bad crimp and probably no lube or not enough.
  5. pastlane
    pastlane
    When I went though this I pulled the wire through the boot before I crimped the terminal end on. I tried a lot of stuff for lube and found d&l hand cleaner worked best for me.
  6. 36tudordeluxe
    36tudordeluxe
    Will try more lube, push pull method and see if I get better results. Thanks everyone.
  7. unkledaddy
    unkledaddy
    Ky jelly with the push pull method works for me.
  8. saltflats
    saltflats
    from Missouri
    If this is the plug end lube it up and just push it in from the wire side of the boot.
  9. Model T1
    Model T1
    Yea but were you using a boot? :eek:
  10. tfeverfred
    tfeverfred
    He's working on the distributer side. Most sets are made that way.
  11. saltflats
    saltflats
    from Missouri
    Well on that end I use some lube and push it in with a pocket screw driver.
  12. 36tudordeluxe
    36tudordeluxe
    Why didn't I think of that! It looked way too big to go in that opening but with more lube slid right in. Thank you
      21.4 KB
  13. saltflats
    saltflats
    from Missouri
    Good job now burn a tire.
  14. 1955IHC
    1955IHC
    I put the boot on first then crimp the terminal end on.
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
  15. 19Fordy
    19Fordy
    Bend the 90 degree boot so it is almost straight - add dish soap- and you can push the wire and connector through without too much trouble. It will also help if you insert a chop stick (Chinese food type) inside the terminal end and push while keeping the rubber boot straight.
    These are Taylor 8mm wires and boots.
  16. saltflats
    saltflats
    from Missouri
    I worked at Taylor cable co back in the 70s when I was going to trade school in KC.
    Man I hated that job I worked in the trailer harness dep putting bullet connectors on wires. The machine held a belt of 2500 ends and I would go through 2 1/2 belts in 8 hours.
  17. fsae0607
    fsae0607
    Silicone Spray works for me.
  18. tfeverfred
    tfeverfred
    That and a little thought takes all the work out of it.
  19. dave lewis
    dave lewis
    from Nampa ID
    I have always used smooth hand cleaner as ***embly lube for spark plug wires.
    Cut wire to length +3/4 inch extra..
    Do not strip insulation..
    Apply Liberal amount on the wire itself..another liberal dose applied to the wire side of the boot..
    Slide/push/pull UNSTRIPPED wire thru the boot..several inches past the end.
    Wipe the end of the wire clean...strip the insulation..crimp the terminal...re-apply hand cleaner to the end of wire...
    Pull boot down to cover terminal.
    Remember to clean the wire before stripping and crimping...if you don't..you will regret it..lol...don't ask me how I know...take my word...
    Also....for you detail oriented clean freaks. ( you know who you are ! )
    Smooth hand cleaner will make your ugly spark plug wires look brand new !
    Just sayin..lol
    Dave
