Tech: 'A' Banger on Rolling Road/Dyno.
Discussion in 'The Hokey Ass Message Board' started by Enbloc, Dec 9, 2005.
  1. Enbloc
    Enbloc
    from London, UK
    Today I finally got my banger on the rolling road. I've been wanting to this for a long time as its the only way to know what power your really making and what areas need improving. The other reason was that I plan on pulling the engine soon for more work, so I wanted to know what the power output was in its current spec.
    Current Engine spec is as follows,
    Block.
    Diamond 'B', 'C' crank, full pressure with inserts.
    Head.
    Lion Head II, 7:1 comp.
    Cam.
    Dan Price grind. Specific specs unknown.
    Valves.
    Completely stock, even down to the split cast iron guides.
    Ignition.
    Scintilla Vertex magneto, 8 degrees advance @ 1840 rpm. Timed by trial and error, never seen a timing light! I estimate its about 8 degrees before top dead.
    Intake.
    Dual 97's. Again set-up by trial and error. 43/44 (45 stock) mains and #72 power valve (#65 stock, #72 stock for an 81).
    Exhaust.
    Dan Price 4 into 1 header through a 2" system with a smitty.
    1st Pull.
    This was the first pull on the dyno. Spec as above but with stock 45 main jets put back in the carbs. This was due to me not knowing wether I was coming or going with the main jets, so putting them back to stock was a good starting point.
    I was aiming for 80 bhp at the wheels.
    I got....
    84 bhp at the wheels! Running well but the gas ****yser was indicating a very weak mixture. Dual 97's on a banger and its running lean! I should have had a of mimimum 5% carbon reading, I had 0.5-1%!
    2nd Pull.
    First job was to jet the carbs up. The biggest I had on me was 47's from my single carb days.
    Back running again we got 5% carbon on the gas ****yser, spot on.
    94 bhp at the wheels, a 10 bhp increase!
    Its going well.
    3rd Pull.
    The third pull was to adjust the timing. The current mag position was marked as a starting point and at wide open throttle pulls the mag was turned either way. In the end it only ended up be advanced by 1-2 degrees from my position. Not bad for trial and error!
    4th Pull
    This was the final going for broke pull. Jack-pot! 100bhp at the wheels at a miserable 3000 rpm!
    Summing up.
    I ended up with a 15 bhp increase, its more smoother on the top end of the rev range and it has a real kick to it now when you change gear. I think I've proved that 97's DO work on a banger, they just need setting up properly.
    Even the guy on the rolling road that has been doing it for over 30 years was impressed with the acceleration when you floored it from a cruising speed.
    I so want to give it ago on the strip, but it seems un-likely it will happen again in its current spec.
  2. Mad-Lad
    Mad-Lad
  3. Excellent Clark!
    You do it - I'll just read about it...
    So "not in it's current spec" eh? What devious plans lay ahead?
    Out of interest, what size horses do they have at that rolling road? The one I used to go to had ponies - the numbers were a little larger than elsewhere!
  4. SHRUM
    SHRUM
    Now thats cool.
  5. hotrodA
    hotrodA
    Good stuff!!
    That's real world info that I like to see.
    100 ponies to the pavement should churn 'em and burn 'em.
    Thanks for sharing that; we (bangerheads) need more.
  6. Enbloc
    Enbloc
    from London, UK
    Forgot some info.
    It has a 60 thou overbore.
    1/4 mile times were a consistant 18.8 @ 70 mph before the rolling road session.
  7. Real world info like this is gold! So much effort is hit and miss.
  8. yorgatron
    yorgatron
    couldn't say it any better myself.
  9. flatheadpete
    flatheadpete
    from Burton, MI
    That's alot of power from a banger! Ya done good!
  10. HoB
    HoB
    from Sweden
    Absolutely awesome!!
    No more search for 81's.......thanks.
  11. Ratty
    Ratty
    Phil , the reason that happens is down to either ;
    a) a poorly serviced / calibrated dynomometer roller
    b) an older dyno with no automatic in-built weather station
    c) an operator feeling sorry for you gasping old wreck by fiddling the atmospherics settings
    We all know how air temperature and pressure have an effect on the way an engine performs , and a dyno runs software to let you compensate for different atmospherics . Fiddle these and the power goes up . Not that I ever did anything like that of course , especially not after selling and fitting £1000 worth of so called performance exhaust to a customers' bike , no no no .
    Sorry if I'm teaching anyone to **** eggs , but its not often I get a chance to show off any technical knowledge and I'm enjoying myself :D
  12. FORDY 6
    FORDY 6
    Cool...interesting info...
  13. brandokust
    brandokust
    Great job and congratulations. If you don't mind me asking, about how much you got in to that little banger?
  14. Outback
    Outback
    from NE Vic, Oz
    That's awesome, and somthing to aspire to!
    It's good to see some figures!
    Outback
    Don't want to get OT but what power are others putting out in their bangers??
    I chucked mine on at a recent show, and got :eek: 27.8hp it was overfueling the air fuel ratio fell off the bottom of the graph.....
  15. Enbloc
    Enbloc
    from London, UK
    Thousands and thousands.
    Yikes! Thats way down on stock!
  16. Outback
    Outback
    from NE Vic, Oz
    Like I said it's a little rich, I don't get time to drive it very often, so every chance I get I jump in the saddle and drive the wheels off it, time tinkering is less seat time. Next hols though will be a bit of work, got a F100 column to stick in it, and hopefully a head to chuck on, may even slip the cam in too :D
    Oh Yeah, tune the carbs, and sort the ign out!
    OB
  17. Enbloc
    Enbloc
    from London, UK
    Oh, a weekends work then.
  18. sodbuster
    sodbuster
    from Kansas
    Very cool.............but, shhhh. Banger's will be the next flatheads for the "Hotrod" trend.
    Chris Nelson
    Kansas
    Oh yea, were did you get the Lion
    head? Was it the guy in Hemmings?
  19. Artiki
    Artiki
    from Brum...
    I think the cost of producing decent power from a banger will keep the scenesters away. These things soak up money like a sponge.
  20. Scott Miller
    Scott Miller
    from Tampa, Fla
    That's true, funny, and sad. I should have charged the last guy that gave me a block:rolleyes: . I think he just wanted to slow down the progress on the V4-HA/GR.
  21. Enbloc
    Enbloc
    from London, UK
  22. peanut
    peanut
    sounds great! what are you going to upgrade?
  23. SUHRsc
    SUHRsc
    what gears are in your ******, what rear ratio and what tire size are you running?
    also what is the body? coupe?
    do you know the total weight of the car?
    just wondering and thinking about my banger project
    thanks alot
    zach
  24. Enbloc
    Enbloc
    from London, UK
    This is the car....
    Weight is around 2257 lbs. Rear end is I ***ume 3.78:1 as its stock. Tyre size is 4.75 19 about 29 inches overall and finally gearbox is stock 3 speed with 1st and 2nd close ratio, 3rd is stock at 1:1.
    What are you trying to work out Zach?
    Peanut,
    I'm mainly having the valves done next.
  25. peanut
    peanut
    looks good! congrats on the #s that is awesome!!!!
  26. SUHRsc
    SUHRsc
    well.....i have big plans to build an early to mid 30's era correct 29 roadster that will do over 100mph on the highway
    stock frame, stock body, pretty much look like a stock A roadster with 17 or 18 inch wheels no fenders and a full hood
    but with a mean growl and plenty of gow!
    stock mechanical brakes. basically what someone in that time would have built. paint the body really nice with factory pinstriping and everything
    its probably more of a dream then anything right now but if all works out i might have the money for it by next fall
    im just trying to figure out what parts and what not other people are running to decide on what i want to hunt down
    i have this graham centrifugal supercharger i think its a 36 but im not sure i want to run that with the mechanical brakes as the lag getting off the throttle and the lack of good brakes at 100 might get a bit hairy
    its just a dream right now :rolleyes:
    thanks alot for the info
    zach
  27. Enbloc
    Enbloc
    from London, UK
    I totally understand where your coming from.
    Heres a Tom Fritz painting lifted from hopupmag.com. Look closely and check out the details!
    Nothing wrong with mechanicals. I found that biggest limiting factor was the tyres not the brakes.
    This is what I have in mind for mine eventually.
  28. very bueno...now loose the smithy and you will probably pick up 2 - 5 more horses (those things have to be power hogs)
  29. SUHRsc
    SUHRsc
    thats a coupe with the roof cut off!
    do you think those 32 brakes would be better then the A's?
    what did they do to make the mechanical brakes work with the dropped axle?
    ...just make extensions?
    i have a full set of 32 brakes, axle and spindles
    maybe thats the way i should go?
    i think these types of cars are for your own pleasure
    almost no one understands the desire to have mechanical brakes and things like that
    to me...its a time machine...i want to view the world through the eyes of whatever year i desire
    cars are my means of doing so as thats where my interest lies
    so if i build a car based in 1949....everywhere i look on that car i want it to be 1949...if i build it 1935 then thats what its going to be
    unfortunately on my first car i cut alot of corners in an effort to get it done
    but i learned my lesson as im not happy with it so i will change it and then do another...and another...and...well i'm gona have quite a few 29 roadster i think :D
    zach
  30. Enbloc
    Enbloc
    from London, UK
    I believe the '32 mechanical brakes are better due them being 12 inches in diameter compared to the Model A's 11 inches.That makes them the same size as hydraulics but they are not as wide. '35 and on mechanical brakes are the same as hydraulics.
    Also I think the '32-'34 brakes will bolt straight on, un-like the later mechanicals and hydraulics.
    I know Jim Brierley (4 port Riley) has done the conversion so he's the man to talk to.
