Technical **Tech: Build your own 32 frame rails**
Discussion in 'The Hokey Ass Message Board' started by flthd31, Oct 5, 2008.
  1. gnarlytyler
    gnarlytyler
    soooo... can I be the first to place an order :)
    ratamahata likes this.
  2. striper
    striper
    No. Those rails won't be any good. You can't do good work with a MIG. If you don't use a TIG you're just a hack and your welds will definitely break :rolleyes:
  3. wlspdshop
    wlspdshop
    from Missouri
    :eek::eek::eek:...Holy **** is that cool!
  4. Artiki
    Artiki
    from Brum...
    Simply incredible. My hat is off, Sir.....
  5. sodas38
    sodas38
    This is a tech that has been asked for by many of us. Lots of talent and lots of time in these. I know some may think after all that you may be ahead by just getting some american stamping rails but you'd still have to box those and you didn't sink any money into your metal. Take out your labor and you've got a free frame worth a ton in the end. Hell of a job!!
  6. stealthcruiser
    stealthcruiser
    Sniff....Sniff....Whats that smell?
    Tech week winner,gotta' be!
    Awsome craftsmanship and forming skills.
    Lemme' see that forearm,young man!
  7. DirtyThirty
    DirtyThirty
    from nowhere...
    Damn...thats amazing.
    Looking at the raw, but smoothed/finished rails, after all those pix actually made me want to cry...
    Mostly because I can't do it, but also because they are so beautiful.
    Incredible...things like this remind me of how far there really is to go...how far you can take your skills/learning.
    Incredible, and inspiring...I've always been kind of preoccupied with the drivetrain of the vehicle, but lately metal work has been fascinating me!
    I need lots more practice at both...
    Those are unbelievable....
  8. matt 3083
    matt 3083
    from Tucson, Az
    Real craftsmanship here. Reminds me of the stuff Bugatti and
    Harry Miller built. You really should be proud of your work, I know
    that I am.
  9. Sellers Equipped
    Sellers Equipped
    from San Jose
    Perfection at its Finest! Hands down to you Sir!
  10. Roadsir
    Roadsir
    It Keeps from making an arc shaped disc mark in the material you are grinding. The longer flats cut more gradually into the surface.
    You can also use this technique to trim back the disc into an area less worn.
  11. moefuzz
    moefuzz
    Great Tech Article!
    Approximately how many hours were involved?
    I'd suspect 60 hours or more?
  12. FINKSTR
    FINKSTR
    That's great tech or should I say art. Please post updates on the project. If the rest of the project is anything like the rails it will be perfect. Tech like this inspires me now if I just had the talent or patience. Thanks!
  13. blackmopar
    blackmopar
    from fallbrook
    wow - that is truly fine work
  14. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Great tech! Thank you.
  15. KIRK!
    KIRK!
    Amazing work! Your labor must be cheap. That's WAY more work than I'd do to save $600. More power to ya!
  16. Steves32
    Steves32
    from So Cal
    Holy ****! Simply amazing.
    So what do you do for an encore? Hammer out a roadster from a sheet of flat stock?:D
  17. bustingear
    bustingear
    Great work. When does production start???
  18. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Ha ha
  19. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    Admit it. this is actually "Norm" from the "New Yankee Workshop" Isn't it?:D
  20. flthd31
    flthd31
    And thank you for the sponsorship. It definitely brought this tech week to a new level.
  21. mtlcutter
    mtlcutter
    That is some F*#$ing beautiful work. :eek::eek: Welcome to the community. Great tech thread!!!!!
  22. Doctor Destructo
    Doctor Destructo
    Fantastic step-by-step text-book style tech article. Thank you.
  23. jj mack
    jj mack
    Why don't you show us how to build a nuclear powered submarine while your at it!!!!!:D
    Great work and thanks for the tips and inspiration.
    Jimmy
  24. kustomizingkid
    kustomizingkid
    Awesome work man!
    Waht do you do when you want to bolt something to the frame though?
  25. Clutched
    Clutched
    Bravo! unreal fine job!
  26. flthd31
    flthd31
    There are a couple of options for body mounts. Here’s what I did. I have a bag full of these threaded bushings. They're ¾ inch outside dia. by ½ inch thick with a 3/8-16 thread inside.
    I drill a starter hole, and then plasma cut a 1 inch dia hole with my luan pattern.
    Next, chamfer for welding.
    Screw something into the bushing to hang on to and hold it in the hole a little below flush and tack weld it in one spot. Plumb it up square and tack again directly across from the first tack. Plumb it again and then put two more tacks between the first two. Now weld it up. I leave the stud in the bushing till I’m done welding to keep spatter out.
    The frame can be drilled and tapped for small stuff like brake line hold downs. For other things like fuel pumps etc. your best bet is to make a bracket with the holes you need and weld it to the frame.
    ...Or you can do like Rolf did and put some holes thru the inside boxing plates and work thru them. Here’s a link to his excellent build:
    http://www.jalopyjournal.com/forum/showthread.php?t=104922&highlight=rolf[/FONT]
  27. Brickster
    Brickster
    good job. It's posts like this that make the HAMB what it is.
    Brick
  28. wicked willys
    wicked willys
    from ne ohio
    Great tech. Very good pics and captions. The talent here just amazes me.
  29. There's something to be said for doing it yourself, it doesn't have to be about money.
    This is beautiful workmanship, and thanks for the excellent pictures and commentary too. Inspiring.
  30. Larry Pearsall
    Larry Pearsall
    If you could build another how much? I'd consider 1 ... Thanks Larry
