Tech: Cheap Roadster Top
Discussion in 'The Hokey Ass Message Board' started by fergenboysinc, Jan 4, 2009.
  1. fergenboysinc
    fergenboysinc
    Inside shot
  2. I was wondering how you liked getting in and out with that low top?
    Even with a fairly high top like mine you have to change your MO for in and out when the top's on.
    Have you found much flapping going on in the large roof panel?
    I set mine up with a bit of a wedge - as well as the car has a good rubber rake (24" and 30" tires), but it still flaps a bit.
    Not bothersome and not a problem, just part of the musical sounds a roadster w/top makes going down the road.
    Me too on the oak bows.
    Nice part is, you can alter the tops shape later on if you wish.
    Just slide the bows down, cut shorter if necessary, drill new holes for the screws then pull the tacks at the back and re-tension top material.
    It can help to disconnect the front header from the windshield and bring it up an inch or four once you have a good idea of where the tacks are going to go.
    When you reconnect front header to windshield it draws the top material up really tight.
    So, aside from aesthetics there are some real advantages to an oak bow, but if the upholsterer know's what they're doing, steel bows aren't a problem.
    Another nice thing about a top - besides the obvious - is; it's another place to have your roadster look a little different from the other ones.
    That said, not too many roadsters at the runs and shows I go to.
    Most of the cars are the tin roof wonders and this time of year they're an excellent choice.
    Heaters, windows . . . geez . . . what will they think of next....
  3. Thought of that and there is room in the 31 for an A/C compressor.
    Even so, it's not bad driving in the heat long as you're rolling and the back window is unsnapped.
    One reason my top ended up tall for a 2" chopped car was that I wanted to make sure I had lots of headroom.
    I'm 6' tall and I can wear cowboy hats, NZ bush hats and the usual ball cap in the roadster with no probs.
    With the back window open you have the air flow of a ******* roadster and shade....:cool:
  4. fergenboysinc
    fergenboysinc
    First off....Yes, Its kinda tough getting in and out of it.
    second.....I am short so, my head wont hit the bows.:D
    third........I don't have a cowboy hat.;)
    fourth...... Not sure on the top flapping. It was -20 here last week with lots of snow and now its melting so its a mess and I am a "cake eater"(read wimp).
    The first time I took it out, I let it sit in the driveway and warm up to 165 deg. I then drove it about two miles and when I got back it was at 140! Time for a stat..... Why do I live here....:rolleyes:
  5. For the hot women!:D
  6. fergenboysinc
    fergenboysinc
    Is that a request?:D
  7. fergenboysinc
    fergenboysinc
    But on a more serious note...Can anyone help with a picture of a back window that's NOT in. I'm really second guessing myself on my design. Its just two flat pieces that clamp together. Doesn't seem like it will hold much.
  8. vintagehotrods
    vintagehotrods
    Chad, sorry I haven't kept up to date on your progress.
    I have a used roadster/convertible window frame in my pile o' parts in the museum room. I was going to show it to you when you were down but forgot to (oldtimersalzheimers memory again). It is a half round on each side and screws (16 of them) together with the chrome on the outside and painted on the inside, and it measures 7" X 24". It's missing the gl*** but otherwise should be a good example to look at. I picked it up some years back (on ebay or swap meet?) for my next roadster top. I'll post photos of it or if you are coming my way you can take it and see if you can duplicate it. I'd let you keep it but I'll need it for my Brookville project. I'm impressed with your young trimmers skills for his first top, it turned out great and you built the perfect shape and profile with your irons. Does he want to sew one up for me next?
  9. fergenboysinc
    fergenboysinc
    Pictures would be great! And yes, Im impressed with Cody's skills too. He also did the complete interior in my Belvedere from scratch. He was right out of school when I had him do that.
    Here is a shot of it.
  10. vintagehotrods
    vintagehotrods
    Cody has talent! The Belvedere looks awesome! Ask him if he wants more work in the future.
    Here's those pics. They aren't as good as actually looking at it though. My lighting in my office could have been brighter too.
    It needs a good cleaning of the chrome on the inside piece and painting of the outside piece. The chrome side has the screws going through it so that should be on the inside of the top. I see that LeBaron Bonney offers 1/8" gl*** to fit it so it must be an original Ford window. It has a raised boss at each screw and between each screw so it will not distort when its tightened up and the gl*** must fit tight up against them.
    This is with it split looking at the inside of each piece
    <table style="width:auto;"><tr><td>[​IMG]</td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Roadster Window Frame</td></tr></table>
    This looking at the outside of each piece
    A close up of the inside of each piece
  11. Big Dad
    Big Dad
    Fergen, that 63 was the nicest car you will ever own .. period
  12. fergenboysinc
    fergenboysinc
    Thanks for the pictures!
  13. SDhotrod
    SDhotrod
    Kudos to Cody on his upholstery skills.(yes, I'm kissing up now, after saying he looked like he was gonna hurl...:D) I'll certainly point anyone looking for someone to do trim and upholstery his way!
    You must be bustin' at the seams to get that car out on the road. Hey, Highway 14 was dry today. Dodge around the slop in town and see how that top reacts "at speed". You don't need no stinkin' heater, it's a balmy 5 degrees out there right now.;)
  14. fergenboysinc
    fergenboysinc
    I will be out in it soon! The top is close enough for now. Lets just call it "spring break"...:D. This is what has gotten done lately.:rolleyes: The "top inspectors" came over...then I ****ered them up for "approval"...then my buddies posed with them for the "Beverley Hillbilly Photo"
    Sorry, Thats it for now.
  15. SDhotrod
    SDhotrod
    :eek: They're gonna take your liquor license away.
  16. vintagehotrods
    vintagehotrods
    Chad, you could buy a heater for that roadster if you didn't have to bribe those pretty girls to pose with you! LOL :D
  17. fergenboysinc
    fergenboysinc
    Well...I got the one chick traded for a heater. Summer needs to get here soon!
  18. fergenboysinc
    fergenboysinc
    Its a BFG. Anyone know the history on them?
  19. Dirty2
    Dirty2
  20. terry48435
    terry48435
    Good info...thanx
  21. TimDavis
    TimDavis
    Pics are gone.....
  22. echnidna
    echnidna
    from Australia
    That's the big disadvantage of photo-bucket et al, pics vanish and a thread becomes near worthless.
    If anyone could provide the pics I can put the thread together as a pdf file provided this is acceptable to Ryan all others concerned.
  23. Blue One
    Blue One
    from Alberta
    I have to agree it is a real shame that the pictures are gone. This could be a helpful thread.
  24. Blue One
    Blue One
    from Alberta
    Pictures coming back ? I sent the OP a PM, never heard back :confused: Activity log shows he has been on the board recently.
  25. Blue One
    Blue One
    from Alberta
    Sent him an e-mail as well, nothing yet.
  26. fergenboysinc
    fergenboysinc
    Lots of **** went on (moved) and stuff was lost for a while, along with a new email....Long story short. If anyone still wants pics back up, let me know and I think I have found some of them. But not all of them sorry.
    Later,
    Chad
  27. panheadguy
    panheadguy
    from S.E. WI
    I say put them up again and thank you
  28. fergenboysinc
    fergenboysinc
    Sorry, this is the best I can do for now. Use your imagination and do your own. Start cutting up some metal and drilling holes? They make more. It was 1/2 tubing and 1/2x1/4 strap. Nothing fancy. I will dig deeper for more pics.
    Later,
    Chad
  29. slater
    slater
    Nice pictures, nice roadster... thanks for sharing
