TECH Cheapo 235 Chevy Split Exhaust My way
Discussion in 'The Hokey Ass Message Board' started by Juztyn00, Mar 9, 2010.
  1. "peening" is the word your looking for. preheating really helps and stress relieving the welded area is a must or shortly after the weld you will hear a 'pop" and their will be a hairline crack running the entire length of the weld. using cast rod is slow and expensive. brazing is "old school" but works damm well!
  2. resqd37Zep
    resqd37Zep
    from Nor Cal
    Kool Job but damn man clean that work bench!:D
  3. roddinron
    roddinron
    It's really nice, and not to be a downer or anything, but welding a manifold is really tricky, and with as much welding as you did on those, there's a very good chance they'll fail. Nice though.
  4. Cosmo49
    Cosmo49
    This is a Corvette manifold, (not mine) did you give any thought to keeping the heat on the left and using a block off plate and adding a flange for the right half? May be easier?
    Anyway, hope your welds work out. I know that when I installed my Fentons it was like having an extra half gear as I go over the pass to the Shenandoah Valley, same can be said for the "X-pipe". This is on a daily driver only vehicle.
  5. OldBuzzard
    OldBuzzard
    There is still a good deal of heat transfer through the metal of the manifolds even without the valve open. Without some heat to the base of the intake, one day, when you least expect it, most likely on a cloudy (high humidity) or rainy summer day, your motor will die as you try to get it to the side of the road. You will have to wait for the ice to melt out of the base of the carburetor.
  6. Smokey2
    Smokey2
    Great POST !!!!!
    Always Admire Someone that "Duz ITthier WAY" Lookin' forward to More. Thanks.
    ______________________________________________________________
    Smoked-up, Up, and AWAY !!!
  7. Hdonlybob
    Hdonlybob
    Great job!!
    And great skills too. Good for you.
    Thanks for showing us this neat build.
    Cheers...........
  8. StefanS
    StefanS
    from Maryland
    So it's been a few years...how's it holding up?
