Tech: Converting a '55 Ford Pickup front end into a desk
Discussion in 'The Hokey Ass Message Board' started by Goztrider, Jul 27, 2007.
  1. Goztrider
    Goztrider
    from Tulsa, OK
    As some of you know, I'm getting ready to start my first year as a
    school teacher here in Tulsa. I saw somewhere about someone having
    a desk made out of the front end of a car, and decided that would be
    a really neat idea for me and my cl***room.
    After scrounging and asking for help, I actually managed to find one
    on my own - on the front of the old school bus shown below. Last
    week, I finally got the okay from my principal, as well as the owner of
    the bus, and yesterday I got started!
    This is the bus before I began:
    We managed to make a family day trip out of this entire ordeal, and
    although I had hoped my wife would think to take pictures, we
    somehow ended up without any. My daughter (HAMB name is Miss
    Behavin) wound up helping me get some of the 50+ year old bolts
    loose out in the field without having to resort to the 'fire wrench.'
    Here is the Beverly Hillbillies load when I got home, and on the back of
    the trailer you can just see the desk that will serve as the 'base' for
    the clip to attach to:
    After measuring, thinking, and conteplating the next image, I decided
    to go ahead and make my first cuts:
    I cut the fender wells vertically, and slipped the desk in between the
    curved back portions of the fenders.
    This picture kind of gives you an idea of how the desk sits from the
    front. The beauty of this setup is that the stock fender to fender well
    bolt holes just sit on top of the desk, although the fenders are a bit
    wider in the back than the desk is. I plan to bolt some angle iron to
    the sides of the desk and use spacers to properly mount the fenders
    solid without kinking them to force them flat against the top of the desk.
    This picture shows where the rear of the fenders will coincide with the
    back legs of the desk. I'll use a flat piece of metal plate or strapping
    to solidly attach them to the sides of the desk.
    This is the look with the hood just sitting in place. I plan to cut an
    approximately 3'x2' U-shaped section out of the back of the hood over
    the top of the desk. The top of the base desk is 30" tall, and with this
    hood top in place, the overall height only jumps to 43", so I should still
    have decent vision over the top of it.
    Here is the front of the entire setup with the hood sitting in place, but
    not yet cut to fit. This will also be about the finished 'stance' of the
    front when it is completed. I've got about 3" or so between the
    bottom of the core support sheetmetal and the floor. I've also got
    enough room to hang a super skinny wheel and tire in the fenderwells,
    but I'll have to see how it all fits. I may just wind up using all-thread
    to bolt the wheels to the sides of the base desk. I plan to basically
    bolt the hood to the fenders once I'm done cutting it. This entire desk
    should be movable in 3 pieces (not including wheels/tires)
    Now, all if have to do is choose my colors. I'm now contemplating a
    burgundy/maroon base with flames or a regular maroon with white grill
    and pinstriping accents.
    As I get more work done, I'll update with more pictures.
  2. Goztrider
    Goztrider
    from Tulsa, OK
    Sorry for the size of the pictures. I need to figure out how to make them smaller in my camera.
  3. RatBone
    RatBone
    killer! the part of the hood that overlaps the desk a little, you could put some cubbyholes like an old rolltop desk to keep stuff in.
  4. the-rodster
    the-rodster
    Coool!
    I've got the whole front of a 49 F1 hanging on the wall in my ba*****t, I have the lights hooked up to come on by remote control.
    Rich
  5. chaddilac
    chaddilac
    You definitley need to drop some big wide whites up in them fenderwells also!!!
  6. Goztrider
    Goztrider
    from Tulsa, OK
    I tried to stuff one of those cheap rollers I got (the ones you didn't take)
    up into the opening, and couldn't do it because the trailer's fender was in
    the way. Standing next to it though, that 6.00x16 stands almost high enough
    to reach the top of the inside of the fender. I'm thinking a 15" with a lower
    profile tire - possibly cut in half down the middle - would fit nicely. It'll just
    depend on whether or not I can squeeze a mounted 15" wheel and tire
    (or a 16") up into the opening and still 'mount' it to the desk itself.
  7. cool, be sure to keep the progress pictures coming
  8. Squablow
    Squablow
    My HS shop teacher had the front of a '61 Pontiac as a desk, it was really well built. I plan to build a similar desk out of the back of a '60 Plymouth parts car that I have.
    I personally wouldn't paint that front clip, leave it as-is.
  9. Goztrider
    Goztrider
    from Tulsa, OK
    I more or less have to paint it. The white is oxidizing, flaking, and will rub off on my clothes
    as I move past it. I also can't have that happen to my students either.
  10. 55 dude
    55 dude
    i think you should put a custom grillle in it and send that one to me!
  11. Chopped26
    Chopped26
    Use the hood that way you can sleep and they will never see you or build a little bed under it like George on sinfield did
  12. Goztrider
    Goztrider
    from Tulsa, OK
    No sleeping in cl***!
  13. didgeytrucker
    didgeytrucker
    Actually, Fairlane fibergl*** sells "wall art" '53-'56 front ends. They're about 12"-15" deep.
    I was thingking about using one of these (one-piece fibergl*** tilt) front ends to make a DJ booth. But I have no way to haul it around to car shows.
    Tracy
  14. oktr6r
    oktr6r
    from Tulsa
    Make a trailer out of it using a dropped axle with the steering locked.
  15. Shifty Shifterton
    Shifty Shifterton
    That looks awesome.
    WHERE DOES THE HORN GO?
