Here's a quick tip for getting those primary tubes equal: Fill'em up with ping-pong balls, then count.
so would that be the white ones or the orange ones? great tip man...i'll use that on the headers for my flat caddy
Smart! have you ever used those TAC fleible heat tubes to eyeball in a set? Big issue I see is they are easy to bend, hard to keep in typical radius and straight....
What a great idea. If any of them stick (think dented tubes) they are soft enough to push through with a flexible rod. Thanks for the great tip! -Dave
Be my luck they'd get stuck at the first Collector( thing tri-y) This idea certainly beats the bent coathanger method I've been using for years.
Ping pong balls are made of nitrocellulose, which is essentially guncotton. If one got stuck I suspect the problem would take care of itself.
