Tech / flake A Dash / KIRKS DASH / May Cause Dangerious
Discussion in 'The Hokey Ass Message Board' started by Gambino_Kustoms, Mar 7, 2008.
  1. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    first thing we did was prep the dash , and stering colume then we shot sealer over it all .
    then we re sanded it , cleanded it with wax and grease remover
  2. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    next we laid down the white base
  3. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
  4. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    next we laid down the white crystal base
  5. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    these 2 glove box pieces we desided to put aside after the white crystal base because they dont need to be flaked or cleared (dont want the clear build up)
    take note that we ran out of the white crystal base when we did the jambs on kirks car so i saved enuff of the origonal mix so i could give the top of the dash a matching coat
    in this case the new base i bought more than likly would have matched but its better to be safe than sorry
  6. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    next we go with my "top secerate" flake mix i cant tell ya what it is cause id have to kill ya ! i will tell yas it dose have roth flake in it , binder ,and inter coat clear but thats all im tellin yas :D
    i like to mix flake untill i like how it looks on my mixing stick
    most folfs use the mesuring meathod
    next we laid down some flake
  7. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    next we go with a nother "top secerate"batch of flake this one my cause dangerious
  8. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    after i get the desired look i want with the flake i usaly like to lock it in with inner coat clear usaly 3 coats then 3 coats of a high solids clear
    this time since it was mini flake and a dash i chose to skip my normal inter coat clear sesion and went right to my clear
  9. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    im going to do 3 coats all together heres # 2
  10. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    after coat # 3
  11. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    well thats it for now we'll let this sit for a few days we'll sand it all again ,re clear it with 2 , 3 coats, sand it again, lace panel the top of the dash with the same fades as the rest of the car, i think well candy blue the shifter lever rod and well do some thing else to the face of the dash but not sure yet so stay tuned for the net instalmint!
  12. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    this tech thred was brought to you by
    now you can be a greaser to
  13. Mark in Japan
    Mark in Japan
    The flake doesn't show up real well in those pics, but I bet it looks swell when you're there! Lotsa DETAIL !!!!
    But what's that ugly blue and white car in the background??? ;)
  14. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    i know
  15. Nekronomicon
    Nekronomicon
    Wow thats gonna be hard on your eyes in the sun!! Looks good though, start bolting this thing back together already
  16. It's all in the details! Dig that shit, man!
  17. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    For some strange reason, I was thinking of this car while making coffee this morning. Thanks for the update! Looking real good. I like the blue shifter arm idea
  18. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    yes it is weve had the car out in the sun at some angles it is blinding
  19. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    How come you need the plain white base under the crystal white base? Would the crystal white base not provide enough coverage by itself?
    Thanks for taking the time to do this tech.
    I'd like to see you do one on a laced panel too. I know most of that is covered in the other "dangerous" posts, but those are so spread out and have roughly 1/2 million replies to them that it's hard to follow the complete step-by-step.
    Thanks again!
  20. gas pumper
    gas pumper
    You guys got balls.
    If it was me, the fog from spraying would get under that cover and all over the car like it was a magnet.
    More great work, thanks for sharing, this is a great education seeing this amount of effort in a paint job. I hope to see this car in person some day. will it ever get to the east coast?
    Frank
  21. KIRK!
    KIRK!
    SUHWEET!!!!!!!!
    How did the bottom of that chrome surround go? I'll come get it when it's ready and reassemble the gauge cluster.
  22. Dirty2
    Dirty2
    Good God that sweet !!!!!
  23. That is coming out really nice.
    I can't wait to see this car done.
  24. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    the crystal white base is vary transparent it dont cover at all!with out the white under it you would see evry thing
  25. KIRK!
    KIRK!
    Hey, go to bed!
  26. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    grill should be close to done tomarrow its on the car! also the top is reay to be polished lets keep our fingers crossed!!!!!!!!!!!
  27. kustombuilder
    kustombuilder
    from Novi, MI
    can i have your baby!!! HA HA HA... seriously. if i could work for you for room and board i would!!. my mutha- f'in hero!!! you make me want to paint shit and i'm no painter. just a humble welder/grinder!! you are the DAMN MAN!!!
  28. lostsouldaddyo
    lostsouldaddyo
    from Lompoc, Ca
    That color setup is gonna look killer when shes all together. Great work!
  29. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    hey thanxs i thought you were movin out our way?
  30. KIRK!
    KIRK!
    No shit? I need to get you the rest of the knobs then. Should I come down to drop them off today. I can't stay because I'm babysitting.
