Technical Tech help needed- popping air out carb
Discussion in 'The Hokey Ass Message Board' started by Christie, May 23, 2020.
  1. Christie
    Christie
    I have 272 v-8 and cannot get her to start. When cranked she pops air out of the carb and has a burning smell and won’t turn over. I’ve done quite a few things but not sure what else I should try. So far I’ve put in a new fuel pump, new carb, new plugs, wires, adjusted the points, new ignition coil, did a valve adjustment and am still with this issue. Any suggestions would be appreciated [emoji16]
    kidcampbell71 likes this.
  2. Wanderlust
    Wanderlust
    Was this engine running before the new parts?
  3. Truck64
    Truck64
    from Ioway
    Did this happen all of a sudden? When was the last time it ran?
    Christie likes this.
  4. Hollywood-East
    Hollywood-East
    That's a Lot of changed variables, Need the back story to commence...
  5. stillrunners
    stillrunners
    from dallas
    Sounds like a timing issue - did the distributor turn a little by chance ? Pull the # 1 plug - and stick a rag in it - turn motor over until you here a pop - the rag blows out of the # 1 hole - pull the distributor cap and see where the rotor is pointing - should be at the # 1 plug....
  6. Wanderlust
    Wanderlust
    Another possible is when replacing plug wires is the rotor goes counter clockwise on these engines, I screwed up, started with #1 and went by firing order (clockwise) felt fairly stupid after a bit of investigation.
  7. Christie
    Christie
    I did pull the distributor out entirely in order to adjust points. I couldn’t see well enough with it still in engine. When I put it back I had crankshaft on tdc, and lowered it with rotor facing to #1.
  8. Christie
    Christie
    She hasn’t run in a couple years. The last time she did run she was dying out on me unless I was pressing on accelerator. So that’s when I changed out everything. The more I’m thinking, the more I’m wondering if I placed the distributor back in wrong???
    Truck64 likes this.
  9. Texas Webb
    Texas Webb
    Stillrunners has a good method also make sure the wires are the correct location plug and capAnd good luck,let us know.
  10. 6sally6
    6sally6
    Make a piston stop. (Knock the guts out of a spark plug. Run a long bolt thru the middle of the plug. Screw into no.1 cylinder. Turn engine over BY HAND until it stops because piston came up and lodged against piston stop. Mark your balancer. Turn by hand the other direction until the piston comes up and lodges again. Mark balancer. The distance between your two marks is.....TDC)Find TDC....reposition distrib. so the rotor is pointing to No.1 TERMINAL on distrib. cap.
    6sally6
    You would be surprised how many people think 'pointing to no. 1 cylinder' means the actual cylinder on the engine block!
    1Nimrod, pitman, clunker and 4 others like this.
  11. Hnstray
    Hnstray
    from Quincy, IL
    The procedure you outline will locate TDC, but seems to not take into consideration which stroke, exhaust or compression, the piston is on. In any case it is waaay to much work for simply bringing #1 to TDC on the compression stroke. Pulling the valve cover and observing the valves on #1 when the timing pointer is at TDC on the timing mark is all that is normally required.
    Ray
    1Nimrod, Blue One, egads and 2 others like this.
  12. Christie
    Christie
    I did all of that [emoji53] found the tdc using a screwdriver in the #1 and positioned rotor to #1 on the cap . [emoji53]
  13. Truck64
    Truck64
    from Ioway
    Agree with the above. Make sure the outer balancer ring of the crankshaft balancer hasn't slipped. Very common on Y-blocks with original balancers.
    A piston stop tool is used to check this, installed in the #1 spark plug hole. Then you know for a fact that when the pointer is aligned with the "0" TDC mark the engine really is at TDC. There are two points where the #1 piston is at TDC, compression stroke and exhaust stroke.
    1Nimrod, Mopar Tony and Christie like this.
  14. jaracer
    jaracer
    You realize that on a Y block #1 is not the furthest forward cylinder. #1 is the first cylinder on the p***enger side. I've always brought #1 up on compression stroke by removing the plug and bumping the starter until I feel compression with my thumb covering the plug hole. Then you can use the fan belt to align the mark on the damper.
    1Nimrod and Truck64 like this.
  15. Truck64
    Truck64
    from Ioway
    ***uming the distributor is stabbed in correctly, that still leaves the possibility that the ignition timing is way off, due to a possible slipped balancer ring. The timing marks move with it. A piston stop tool should be used to check this. Any original equipment balancer needs rebuilding or replacing by now.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    Start with a compression check . Stuck , bent or burned valve would act this way ....
  17. Christie
    Christie
    How can I do a compression check if the car won’t even run? I thought you do that on a warmed up engine? No?
  18. Dave Downs
    Dave Downs
    from S.E. Penna
    You can do a cold compression check, numbers may be low but you will see a dead cylinder with a stuck valve
    1Nimrod and Christie like this.
  19. Check your TDC compression as said to at least see that you haven’t put the distributor 180 degrees out, easily done. Plugs out ,turn it over with a thumb over number 1 ,wait for compression to build up then with a screwdriver or whatever to check ,get the piston at the TDC and check the rotor position then, once confirmed,look elsewhere.
    When confirmed at least you can move on.
    Always look at what you changed last before the start of your problem.
    1Nimrod, Hnstray and Christie like this.
  20. Ericnova72
    Ericnova72
    from Michigan
    Perhaps you aren't getting this fact clearly....TDC comes up twice in every cylinder for just one distributor rotor rotation.
    Screwdriver will find a TDC...but was it TDC firing.... or TDC pushing exhaust out?? Big difference between the two. 180° difference to the distributor.
    From your description of engine behavior, It sounds like you have the distributor rotor 180° out of alignment.
  21. southcross2631
    southcross2631
    If you have access to a leak down tester that will tell you if you have a valve issue. If it didn't back fire through the carb when you parked it then you probably caused it by pulling the distributor . Have you checked to see the timing chain hasn't jumped ?
  22. Christie
    Christie
    Thank you everyone, can’t wait to get back out there today and try again!![emoji1360] I’ll update you guys [emoji16]
    1Nimrod and Hnstray like this.
  23. clunker
    clunker
    from Boston MA
    Christie and Barrelnose pickup like this.
  24. gimpyshotrods
    gimpyshotrods
    I have had three Y-Block equipped trucks towed in to the shop because of this, so it is not that unusual to find this as an issue.
    It does not help that different manufactures start numbering in different places, and in different patterns.
    Oh, and often have distributors that rotate the other way, too.
    What is cylinder #5 on a Y-Block is cylinder #1 on a Chevy. It may be as simple as having the plug wires on in the wrong positions, wrong order, or both.
    It happens, even to the most dyed-in-the-wool old-school car guys, who will never, ever admit that they did that.
    Blues4U, scotty t, 1Nimrod and 3 others like this.
  25. Christie
    Christie
    I’ll have to do some reading on this. Ty! Gonna be heading out there soon, pray for me [emoji23][emoji23]
    1Nimrod likes this.
  26. gimpyshotrods
    gimpyshotrods
    Putting a distributor back in is also not all that uncommon. A whole lot of them drive the oil pump, via the roll pin that holds the distributor gear on. Others drive the oil pump with a hex shaft, so you get SIX chances to put it in, instead of TWO, and only one is correct!
    I put a distributor in an Chevy, 180º out-of-position, at the end of last year, and I have been at this for bout 40-years.
    I am much less inclined to believe that you have a stuck valve. I would check over the work you have performed, first.
    The Occam's Razor Principle is an abductive heuristic that basically states: The simplest explanation is most likely the correct one.
  27. jaracer
    jaracer
    When I first bought my 57 T-Bird I hadn't worked on a Y block in many years. I replaced the points and was trying to set the timing, but I could never see the marks. I ended up setting it with a vacuum gauge. A year or two later I realized I had the timing light connected to number 5 cylinder.
    Hnstray likes this.
  28. gimpyshotrods
    gimpyshotrods
    Of folks who have tuned Y-Blocks, there are only two types:
    Ones who readily admit to having done this, and liars.
  29. squirrel
    huh? it's a ford V8, number one is on the p*** side.
    ottoman likes this.
  30. sunbeam
    sunbeam
    To check pull the drivers side valve cover watch the valves on #6 second one from the front. Turn the engine when the exhaust is closing and the intake is starting to open you are very close to TDC #1 check timing mark If not close say 10 degrees Damper may have slipped or cam jumped time and check if rooter is pointing at Number 1.
