TECH: How to Chop your Vent Wings
Discussion in 'The Hokey Ass Message Board' started by Chopped50Ford, Nov 26, 2006.
  1. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    I know im late on this, but I figured since im doing mine, I could share how I did it. Procedure may vary for each car. This chopped vent is going into my Shoebox.
    Okay, here we go!
    1. You must finish the door tops on your chopped doors before you start this. Its pretty much common sense why, but I thought I would throw that in before we really get started.
    2. Take your vent wing ***embly and lay it out.
    3. Dissasemble it. You will have to grind out rivets for some parts. Dont worry, you standard Aluminum type from the local hardware store will work just fine. :) I like to put all my small parts in a zip lock baggie and label for later use. Helps keep the parts together. HUGE NOTE: Dis***emble one side at a time so you can refer back to the other unit in case you forget how to put it back together. :)
    4. Measure your window opening from the base of the window to the top. Be sure to measure in the area of the vertical post mounting area for your vent wing ***embly.
    5. Take that measurement from #4 and mark a cut line on the vertical piece. I measured from the base/bottom of the upper bracket that mounts to the top of the door sill.
    [​IMG].
    6. Make a mark and cut. Be sure to measure twice, then cut once. :)
    7. After you make your cut, install it and be sure it fits nice w/ a little play.
    8. Now, take your outer rim of the vent wing ***embly. See picture for example. This is the piece that holds the rubber.
    9. Set the out rim in place to see where you have to heat and bend the piece to get it to fit.
    10. I used a torch to heat it up to get the correct bend needed for fitment.
    11. The picture is a little fuzzy, but I used a vice to help make the bends needed. Heat, bend, heat and bend. I used a "00" tip on my Victor torch. Quick Note: Be sure not to bend it too hard. The outer rim is a "U" channel and the sides will collapse or crease if you bend it too much.
    12. Take your newly shortened/chopped outer rim and mount it to the upright. Mark the excess to cut. It is important to screw this in to the mounting holes to ensure your bend is correct and your cut line is the right.
    13. Now, there is an upper tab that is mounted to the very top of the upright. A screw goes through the door top to hold this bracket at the top of the vent wing ***embly in place. You can see the original curvature of the stock ventwing wont work for our newly chopped rim. Some modification will be needed before you mount it. Before and after.
    BEFORE:
    AFTER:
    14. Install the top bracket to the upright and now mount the newly chopped outer rim. You will have to add new holes for the brackets new position. Rivet or screw in place.
    15. Now, take the chrome vent wing and remove the gl*** if you havent already.
    16. Take the chrome vent wing and heat it the same as the outer rim to get the desired shape to fit in place. Quick Note: Again, be sure not to bend too sharply, this will cause the "U" channel shape to collapse. Some of these pieces of brightwork are stainless steel, Quite a bit of heat may be needed to bend to desired shape.
    17. Fit your newly "chopped" vent wing in the vent wing ***embly. Once satisfied, cut desired left overs off.
    18. Buff out brightwork. If it stainless, way to go. Otherwise, send it out to the chrome shop. :)
  2. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    19. Install new rubber, cut to fit in place and re-***emble vent wing ***embly and mount.
    I hope this was helpful. It took me about 2.0 hours to complete one side. The other side should go faster.
  3. synthsis
    synthsis
    very nice writeup. the amount of tech that is do***ented on this forum boggles my mind on the daily.
  4. Thanks for the tips
  5. Yeah, I think I learned that one, too. Several times...
    -bill
  6. Bud
    Bud
    from Orange, CA
    Norm, that is a great job. Nice tech.
  7. pimpin paint
    pimpin paint
    from so cal
    Hey Norm,
    If you cut two pieces of Masonite to the exact shape of your vent
    wing gl*** these can be used as a form to bend the "U" channel
    around. The two piece thickness of the Masonite will aproximate
    the thickness of the gl***, and provide an exact shape to form to.
    Tape the Masonite to the frame with 200 mile-an -hour tape and
    roll the frame over your bench top to form. If you need to heat the
    frame, go slow and use a wooden or plastic mallet on the thin "U"
    channel.
    S****ey Devils C.C.
  8. Chaz
    Chaz
    Thank you... Everyone seems to think that their chop is done when the top goes down... The part you are doing is the HARD stuff.. Congrats on a job well done !
  9. gtnrkix
    gtnrkix
    Thank you! That's the point I'm at on my 50. It's the details like this that seperate the really nice chops! Good post.
  10. one thing to remember is
    use a straight edge and make sure the the shaft (bottom pivot) is lined up directly to the top pivot
  11. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Right, the stock pivot points must remain or the vent wing wont open or it will bind badly.
  12. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Another good point was made, Use masonite for your gl*** pattern. Cardboard is too flimsy. Remember too to compensate your gl*** cut for notches to clear the brackets that are hard mounted to your channel.
  13. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    BTTT- for Post-Tech Week viewing :)
  14. Johnny1290
    Johnny1290
    Hey man I just wanted to say thanks for writing this and showing my dumb *** how to do it the right way! I was way, way off base trying to guess how this is done.
    Thanks for your time and giving me the link to the slide show of photos for this tech
    here!
    It's gonna make the difference between me (hopefullly) getting these done and working or just piddling around for a couple days of frustration and throwing them on the junk pile! My shoe with a SBC gets *HOT* inside without the vent windows, so it'll be huge if I can make these babies!!!
  15. Gator
    Gator
    from Statham Ga
    Help! Ready to cut down the windows on my chopped 50 and found this - looks like a great help but where'd the pics go?
  16. BJR
    BJR
    I second that, I could use the photos also.
  17. BJR
    BJR
  18. patman
    patman
    Looks like the photos are available as a slideshow:
  19. the-rodster
    the-rodster
  20. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    I'll work on getting the links fixed, glad to hear folks refer to this for help.
    Give me a bit to work it out.
    Thanks
  21. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Pictures are up! Hope this helps
  22. Gator
    Gator
    from Statham Ga
    Thanks again for the post - I cut a template as Pimpin' paint suggested. A propane torch provided sufficient heat in bending mine.
    Here's a 'before and after' on mine. They're both done now, other than the polishing and getting new gl*** cut. Waiting on new seals from Dennis Carpenter so I can double check the fit.
  23. Finnrodder
    Finnrodder
    from Finland
    Nice tech.I didnt know that they made vent wings from stainless too.I have 3 pairs of them in my stash.I hope that even one pair is stainless.Does the rear vent wings work as front wings?
    I have one pair of them too..
  24. 'Mo
    'Mo
    Doesn't bending the frame change the relative position of the upper pivot point? :confused:
  25. Gator
    Gator
    from Statham Ga
    On mine-which has a 4" chop - all of the bending was above the pivot point...
    Here it is finished, with gl*** etc installed.
  26. Stefan T
    Stefan T
    from Sweden
    Another posilblity is make new ones like mine
    I have them ready execept for the glas but i have forgoten to photo them after that i have made more ready
  27. gaskell
    gaskell
    from CO
  28. yardgoat
    yardgoat
    Thanks for the tech !!!! good job n good luck on the rest of her.............YG
  29. koolkemp
    koolkemp
    But Stefan you have alot more talent than most of us out here :D Nice work!
  30. pecker head
    pecker head
    Thanks for the info , I got one side done on 51 Chevy truck .
