Tech: How to make a recess in sheetmetal
Discussion in 'The Hokey Ass Message Board' started by T McG, Jan 8, 2008.
  1. THE CHIEF
    THE CHIEF
    from MIAMI
    great tech post, took me a bit to get it but it all makes sense
  2. Ebbsspeed
    Ebbsspeed
    Since there is a need for a hole in the sheet metal for the contact, you could also drill a large hole or two through the smaller of the two dies, and use a large bolt (or two) to apply the force required to make the impression. You would have to back up both dies with a heavy piece of metal (with matching bolt holes) but if you have access to both sides of the panel this would eliminate having to weld in the panel with the recess. Not sure I explained it clearly, but if any of you have ever used a ch***is hole punch it uses the same principle, except that instead of using cutting dies you would use the "recess" dies. Make sense?
  3. Rob Paul
    Rob Paul
    very good tech, thanks
    ROB
  4. Seems like it would work, or snap the bolt.:(
  5. Brian W
    Brian W
    Terry did describe that this could be done the way Ebbsspeed suggested. It just depends on how thick the material is and also if you have enough room to get it all in the location you need to press.
    The neat part about this tech is there are different ways of accomplishing the same idea, and a ton of different scenarios to use it on. :D
  6. Rusty
    Rusty
  7. Retrorod
    Retrorod
    Very cool, I was doing some head scratching about some dovetails I have to do, now I know how I can do it cleanly! Thanks...great tech post.
  8. jonny o
    jonny o
    Awesome man! Thanks!
  9. Brad S.
    Brad S.
    Where did the pics go?
    Can you provide a direct link?
  10. Dirk35
    Dirk35
    I too would like to see the pictures. Its all Red Xs that I can see.
  11. farm boy
    farm boy
    from reedley
    Yea, I guess we all lost the photos, maybe you could reprint. this looks to good to miss! Thanks T McG.
    OLY
    The cancer car lives
    Give to cancer research
  12. mwhistle
    mwhistle
    from sacramento
    I'd like to see the pictures too. All I get are blue boxes with question marks?
    Thank you.: :confused:
  13. rjm7404
    rjm7404
    from home
    Photobucket says album is private. Please fix that. Thanks. Iwant to see too.
  14. ***Area-51***
    ***Area-51***
    from Ohio
  15. langy
    langy
    Can't see the first pics ???
  16. chad
    chad
    Same here
  17. DBruce
    DBruce
    Great tech idea, it does look factory!
    Thanks for the tip,
  18. Would it be possible to use the dies directly on the door jam, with some heat, eliminating the welding and finishing?
  19. oilslinger53
    oilslinger53
    from covina CA
    i suppose if you used the idea with two or three large bolts instead of a press it ,and backing plate that has more area than the die could be done on the car.
  20. choppintops
    choppintops
    This was cool enough to be brought back up.
  21. ratman
    ratman
    Works great thanks.
  22. indyjps
    indyjps
    Great Tech,
    another take on this is look at old appliances while on junk yard crawls, many have offsets in the rear panels that come in handy, the back of a refrigerator or stove can yield some good cheap material and is usually heavy enough material.
  23. qcy2k6
    qcy2k6
    Nice...
    Going to save this one...
  24. Bobby Cadillac
    Bobby Cadillac
    one of my favorites and has inspired some cool dies
  25. 65 impala
    65 impala
  26. zomb1e
    zomb1e
    Very cool and easy! Thank you!
  27. brady1929
    brady1929
