TECH: Make a Bellhousing out of an old Intake Manifold!!
Discussion in 'The Hokey Ass Message Board' started by loudpedal, Apr 11, 2010.
  1. loudpedal
    loudpedal
    from SLC Utah
    In my opinion, heat treating the parts I'm doing is overkill. It wouldn't hurt to do it, but I choose not to. I stay away from the cheap aluminum. Basicly I choose cast aluminum for my s****. I get the best results from American intake manifolds. I don't use extruded aluminum at all. That stuff gives poor results. I've never had anything crack or break...
  2. loudpedal
    loudpedal
    from SLC Utah
    Yes, there is always shrinkage. It's about an 1/8" per foot for aluminum. You just build that into your patterns.
  3. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    This is very much appreciated! Thanks so much. I did foundry in high school, always wanted to re-visit this part of the hobby. Very inspiring, well written post!
  4. Django
    Django
    from Chicago
    that rules Kris.
  5. NoSurf
    NoSurf
    Very very cool Kris.
    Thanks for taking the time to put the thread together.
    I feel very unworthy.
  6. roddinron
    roddinron
    Great thread! Thanks.
  7. budd
    budd
    great tech, so i'm looking for one of those v-drives for a dragster project, heres a picture of the engine taken back in 1962, do you make the drives to sell? i vote you win.
  8. deucegasser
    deucegasser
    Excellent information,thank you.
  9. MN Stumpjumper
    MN Stumpjumper
    Great Tech Kris, very enlightening, even if I never do it. Thanks for taking the time to post.
  10. Flat Ernie
    Flat Ernie
    Tech Editor
  11. Kramer
    Kramer
    x 2
  12. freakboy
    freakboy
    i have a question do you have a way to cast manifolds? i can see that being difficult/imposible because the shape of them and the holow insides.
  13. That is all about how complicated you can make your pattern and design in core pieces that the aluminum can flow around - take a look at the mold for his mag drive - it has a simple core in the middle of it to reduce the amount of machining he needs to do.
    I've always wanted to build a furnace and pour some aluminum parts for my projects. I've looked into it two or three times in the last couple of years, I just have never made that step. I do get to see this stuff on a regular basis - I'm an engineer that works at an automation company that works primarily in foundries.
  14. captainjunk#2
    captainjunk#2
    if you dont want to mix your own casting sand there are places on line you can buy sand and small crucibles ,
  15. loudpedal
    loudpedal
    from SLC Utah
    Funny you should ask. My Dad and I were talking about doing some Flathead cylinder heads last night. All we need is some time to devote to the project...
    Oil bonded sand has been mentioned. If you are going to do a bunch of casting, it's well worth the investment, because it's much less maintenance than clay bonded sand...
    kidcampbell71 likes this.
  16. Checkerwagon
    Checkerwagon
    Outstanding post, well written with clear photographs of how its done. Thanks for taking the time to put this together.
    Dale K
    Cleveland OH
    hipster likes this.
  17. bct
    bct
    great thread ...thanks loudpedal!.....my buddy made a crucible from a starter housing he welded a 1/2" bottom on a heavy one....he pours lead for downriggers
  18. I've done a fair amount of casting at home with my charcoal furnace. Your castings are far superior to mine. My sand is certainly to blame. I'm going to mix up a batch of Petrobond or K Bond for my next project. How did you melt enough aluminum to pour a bellhousing, or is your furnace larger than it appears?
  19. loudpedal
    loudpedal
    from SLC Utah
    It took about 18 lbs to pour the bellhousing mold when you count all of the risers and gates the mold had. That was just about right at the limit of the crucible I was using at the time...
  20. 29nash
    29nash
    from colorado
  21. perkshotrods
    perkshotrods
    subscribed , great post--- thank you
  22. Sebastian.A.G
    Sebastian.A.G
    from argentina
    very cool, great tech post
    thanks
  23. 54stude
    54stude
    I have taken a college level foundry cl***, and your post did a better job of explaining the process than my professor did!
  24. Kan Kustom
    Kan Kustom
    Very nice work!
  25. ironfly28
    ironfly28
    from Orange, CA
  26. Dyce
    Dyce
    Very good tech post Kris. Thanks for sharing!!
  27. Okie Pete
    Okie Pete
    This is some great stuff thanks for sharing.
  28. hotrod40coupe
    hotrod40coupe
    This is a great tech. I have been wondering how I could do this at home and now I know.
  29. trad27
    trad27
    Very interesting, now I want to try this. Is there a way you can make the part out of foam or a light wax and leave it in the sand and the molten aluminum would melt away the wax and foam? Or would it just cause impurities in the aluminum?
  30. 57FORD
    57FORD
    i want to try this as well :) i can think of several things i could make for my truck
