TECH: Mechanical Clutch Linkage
Discussion in 'The Hokey Ass Message Board' started by Tindall, Sep 30, 2008.
  1. Tindall
    Tindall
    I had a few options for clutch linkage on my hot rod. I like the simplicity of mechanical linkage, and it was pretty cheap.
    I started out with a DOM tube with a 7/8 id and a wall of 1/8. Then i made two Arms out of 1/4 flat stock. I used 2 GM Clutch Pivot balls for each end.
    One pivot will bolt through a 3/8 plate, attached to the boxed frame.
    On the other end, i pick up off of three bolt on the blow proof bell housing. [​IMG]
    This is what it looks like outside of the frame.
    And Inside
    I used a corvette clutch fork, and a clevis for the fork side. The threaded rod to the clutch for is only for mockup, it will get a real rod later
    And on the pedal side, i used two Heim Joints. This is only a mock up for now, for the real deal, it will get a 7/16 tube and larger heim joints.
    Hopefully, this will help someone out designing their clutch linkage.
    Matt Tindall
  2. Belchfire8
    Belchfire8
    Thanks, might be usefull for me in the future. Are all those parts, pivots and clutch fork, etc. available new?
  3. Tindall
    Tindall
    Yep, got them from Paragon Corvette, they have a website.
  4. blackout
    blackout
    Nice. This is better than going with the used stuff as it is worn near out by the time you get it, and you have to cut it up anyway. Is that a Lakewoood scattershield?
  5. Tindall
    Tindall
    most likely, it came with my 68 camaro
  6. great design!
  7. pan-dragger
    pan-dragger
    nice tech, thanks
  8. skwurl
    skwurl
    Good job Great tech. Thanks!
  9. lucky_1974
    lucky_1974
    Hey that looks great I did something similar, the only difference is I drilled and tapped a hole for grease zurks and used a couple of battery post felts on the ends of the bell crank to act as a dust /grease seal. Nice job!
  10. SASROD
    SASROD
    Looks good, been thinking about making a mech. linkage too. Do you think you need some way to keep your bellcrank centered between the pivot balls?
  11. Rich Wright
    Rich Wright
    Nice work. Simple,effective and well executed.
    Rich
  12. Shifty Shifterton
    Shifty Shifterton
    Nicely done tech
    What info/method did you use to figure out the lever ratios?
  13. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Weird............. yesterday was clutch linkage day for my '71 Chevy pickup. I got mine working and adjusted nice!
    You did real good here, nice post and really nice results!
  14. Gusaroo
    Gusaroo
    Nice, clean and simple. Sweet.
    Grainger's has huge variety of quality heim joints, and they are surprisingly cheap. I just rigged up a hydraulic clutch set up and purchased most of the linkage parts from them.
    http://www.grainger.com
  15. Tindall
    Tindall
    yep i had a 7/8 od tube to slide in and weld inside the main tube to stop left to right movement. haven't gotten to that yet though
  16. SASROD
    SASROD
    Thats what I was thinking you could do, maybe a couple of holes in the outer tube and rossette weld it in there. You could even slide some of the nylon socket bushing things in there to reduce wear on the pivot balls.
  17. TagMan
    TagMan
    Great Tech article ! Wish I had it when I did the one for the Buick - would have saved me a lot of time & trial. Mine was very similar, but I added a small grease fitting for periodic lubes.
  18. 392_hemi
    392_hemi
    You could put bonze bushings in there and not have to worry about lube.
  19. TagMan
    TagMan
    Yep, that'd work, too.
  20. Good looking stuff. How does it feel? I guess you get your mechanical advantage from the length of the clutch pedal? How do you figure all this out, is there a ratio that you have found?
  21. 30 Buford
    30 Buford
    Nice Job , This will be very helpful to me when I fab. mine . In the not too distant future( I hope)
    Thanks for posting , Bruce
  22. DollaBill
    DollaBill
    So, check this out...
    I mounted the brake and clutch pedal in the '54 Dodge Coronet gasser I am building for my friend Zombie, today.
    392 Hemi, Muncie 4 speed.
    As I am doing this, I am designing the clutch linkage in my head, right, as we all do.
    I get done, log on the H.A.M.B., and here's this post. It's...sublime?
    Viva la H.A.M.B.!
  23. Southfork
    Southfork
    Very helpful. Thanks for posting this great tech!
  24. dirty old man
    dirty old man
    I like you concept and the workmanship is excellent. The rolling chassis Brookville '31 roadster I bought partially completed, and am currently working on was already set up with a hydraulic setup when I got it. But if I have any problem with it, this approach looks good!
    Like several others ahead of me, I would like to have some idea of a total combined leverage ratio to start out with in my design.
    Dave
