TECH: MOON Hub cap conversion, snap-on to screw-on, my way. Machining them down.
Discussion in 'The Hokey Ass Message Board' started by Chris Casny, Nov 26, 2007.
  1. Alright, snap on Moon discs are soooooo not traditional, but I took some snap-ons and turned them into screw-ons, with a twist.
    Snap on disks are too big to fit "into" the wheel perfectly, so I machined them down with an unconventional approach, using a wood router table.
    These are made of aluminum, so therefore easely shaped with wood tools.
    Step 1:
    The snap on part of these Saturns is easily removed by simply pulling the spring out of the "groove".
    Step 2:
    In order to align/center the cap, so I could take an even 1/4" off all around, I took a piece of 1/4" plywood, cut it to the size of the hubcap, drilled a center hole into the wood, to create a pivot/center point, just like a turntable, and used double stick carpet tape to stick the two together.
    Make sure thats done accurately.
    Step 3:
    I set up my router table with a straight bit.
    I carefully handheld the hubcap and took a 1/4" out of it, just a tiny sliver.
    I became clear that I had to make 2 p***es with the routerbit, first p*** I took off the "folded edge" and with the second p***, I took off the remaining material, to get the desired diameter.
    The discs get basically rotated by hand with tons of WD-40 as a lubricant.
    Step 4:
    The hubcap was sanded to get rid of the rough edge.
    Step 5:
    I drilled 3 holes in the hub cap, not where you normally see them but more towards the center, where there are, 3 dimples on these OEM wheels I have.
    Step 6:
    I drilled coresponding holes in the actual rim, tapped a 1/4"-28 thread and installed my modified Moon discs, with some fancy aircraft fasteners.
    Done.
    Finished product.
    I have to say, that my wheels are reversed, so there was'nt a valve stem clearence issue.
    Hope you like.
    Just another lo-buck solution, that took maybe 2 hours to complete.
  2. fiveofeen
    fiveofeen
    and you gotta have a fancy tool to steal the hubcaps now.. excellent
  3. zman
    zman
    from Garner, NC
    cool beans... I like
  4. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    Pretty slick setup ... looks really good on that car.
  5. HellRaiser
    HellRaiser
    from Podunk, NE
    Slick'er than snot!!!!
    HellRaiser
  6. skratch
    skratch
  7. Reverand Greg
    Reverand Greg
    Cool loking and dangerous to make...I love it!
  8. SanDiegoJoe
    SanDiegoJoe
    very nice... lets see a side shot!
  9. John Denich
    John Denich
    Great Post, I bought a set of these at the same time as Dreadman! and I am not using them if anyone is interested in doing this conversion! PM me not to high jack your thread.
    John
  10. Pretty cool. I wonder if you attached them with brushed s/s allen ****on heads if they would sort of disappear? In any event they look great. How noisy is the router when cutting these?
    Charlie
  11. It is loud as hell, and aluminum pieces fly all over the place, wear a hood. Without lubrication (WD40) in my case, the router bit get's clogged up, in no time.
  12. touchdowntodd
    touchdowntodd
    hows about a full side shot of the car?
  13. Burny
    Burny
    I like! Did you use a special bit in the router?
  14. Dave L
    Dave L
    from Idaho
    Nice looking!
  15. Nothing special, just a regular 3 fluted, carbide bit.
  16. Royalshifter
    Royalshifter
    Moderator
    Way nice!!!!.....**** the snap-on discs they stick out too far. Great job Chris the car looks awesome.
  17. munster
    munster
    from burbank
    nothing special ha! a "regular" 3 fluted bit is special to me. i would have used a file. :D as always cool stuff man!
  18. 30roadster
    30roadster
    those are gorgeous!... Great tech!
  19. fab32
    fab32
    Another case of finding a lemon and making lemonade. Very cool
    Frank
  20. Swedester
    Swedester
    i really like the way the "inboard" mounting screws,it gives it a more racy look.
  21. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I was impressed until I saw the shot of them on the car. Now I'm damned impressed!
  22. Muttley
    Muttley
    Very cool, the snap-on versions are ****.
  23. Big T
    Big T
    from Florida
    Nice job... they look right at home on your car. Great step by step instructions along with the pictures.
  24. dodgedartgt
    dodgedartgt
    from SW FL
    That look GREAT!
    Now, if you want to add one more dimension to this project, those 12 point bolts also are available drilled for safety wire. Just an idea.
    Mike
  25. Bad Bob
    Bad Bob
    from O.C. Baby
    Way cool buddy! I have a set of those too.
  26. TerryE
    TerryE
    That looks so much better. Now it's the right way. Thanks for sharing.
  27. Graham08
    Graham08
    Very cool tech...Is there a thread somewhere with more pics of your roadster?
  28. OK, here is a side shot of the "Boattail" I built last year.
