TECH Mustang rad in a model A PICS
Discussion in 'The Hokey Ass Message Board' started by Toqwik, May 10, 2004.
  1. Toqwik
    Toqwik
    Alot of folks (myself included) have been asking about the Mustang rad in a model A, well I did it this weekend and it fits good. Here is how I did it. I ordered and orig rad mounting kit , bout 10 bucks, comes with the bolts, rubber pads,springs, and nuts, nothing fancy, could even use hardware store stuff. I welded some 3/4 x 3/4 square tubing (compliments of a old display rack from behind the mall) to a piece of flat stock. Got a rad from a 66 Mustang off ebay for 35 bucks that looks brand new. because of the additional 3/4", I had to drill new holes in my crossmember, only about 1/4 outside of existing holes. If you are real lucky, the rad will have the "clipbolts", and all you have to do is drill 4 holes through th uprights, and mount the rad. Then I drilled thru the side of the rad shell, to mount it to the uprights(will do it nicer for the final shell, but this one is onlt a temp one. Then I attached the orig hood support rods to the top of the shell with some flat stock I just bent and drilled. Total install time was about 1 1/2 hourd, and alot of that was waiting for paint to dry and gettin another beer. Toqwik
  2. STICKMAN
    STICKMAN
    Cool, I've got the same planned out for my 31a. Got any pics? [​IMG]
  3. BELLM
    BELLM
    Pictures! Sounds good. I got one hanging on the wall in the barn from when I used to restore 65-66 Mustang convertibles. Gonna use it in my 30 roadster.
  4. Toqwik
    Toqwik
    pic1
  5. Toqwik
    Toqwik
  6. Toqwik
    Toqwik
  7. Toqwik
    Toqwik
    no clue why 1 and 2 pics are small, can email em to ya if ya want. Also I used a 17" fan, gives me about 1 inch between blades and lower water pump hookup, lower rad hose on stang is 1 3/4 same as chevy water pump, and upper fitting is 1 1/2, same as chevy water neck. Gettin closer......Toqwik
  8. hanginlow58
    hanginlow58
    I have one in a 32 shell for a 34 ford truck proj. I just bought, it has a sbc in it, does these keep them cool enough or do you need more cores put in them?
  9. ray
    ray
    from colorado
    it should keep the chevy cool, you can get new 3 core radiators for mustangs for under $150 brand new. if that don't cut it, aluminum ones can be had for about double that.
