tech question..i know...
Discussion in 'The Hokey Ass Message Board' started by PonyboyWWAC, Sep 20, 2009.
  1. PonyboyWWAC
    PonyboyWWAC
    but i cant post in the tech thread for some reason.
    how does the shifter come out of the column on a chevy 3 on the tree? i want to extend it a bit and put a set of knuckles on the end..but i cant for the life of me find how it comes off..
    also..
    i want to lower my *** end a bit, 49 chevy styleline. Any suggestions?
  2. don't know about the column, but blocks work great for lowering the rear, remove a leaf or 2 to lower it more
  3. belair
    belair
    the lever is held in by a roll pin I think. Just drive it out.
  4. yorgatron
    yorgatron
    you want to pop out of second gear? :confused:
    P.S. you will also look like a *****.
  5. 325w
    325w
    If its a 49 theirs no roll pin. Just a spring with two pads top and bottom. Depress the m both and the shifter comes right off. Two screws on the column and a link under the hood. 49-54 and pickups to 59.
  6. chaddilac
    chaddilac
    Yep don't extend it... it'll be too much weight on the end of it and it'll pop outta second like yorgatron said!
