tech question re tapping after powdercoating
Discussion in 'The Hokey Ass Message Board' started by daddy-o63, Apr 19, 2008.
  1. daddy-o63
    daddy-o63
    why do guys tap after paint or powdercoating a ch***is and not put bolts in the holes beforehand?
  2. lostforawhile
    lostforawhile
    well sometimes if they powdercoat over the bolt, it rips up a large section of powdercoat when you remove it, it's really easy to chase a thread, and you can get silicone plugs to go in the holes that don't do this.
  3. Deuce Roadster
    Deuce Roadster
    Re tap ... always :)
  4. daddy-o63
    daddy-o63
  5. lostforawhile
    lostforawhile
    i forgot that gritty **** gets in there, also if you need to keep part of something unpowdercoated, you can buy the high temp tape, you wrap it in this and if you are lucky it might peel back off,usually you have to pick it off.
  6. 325w
    325w
    Retap in hopes of keeping good grounds in the electrical system.
  7. Retap just to get the bolts in. The first time I had powder done was to all the top bows on the '40 Chevy - and then I couldn't get any of the bolts to go in. That paint is hard.
    Charlie
  8. sasquatch alley
    sasquatch alley
    from Fresno, Ca
    I use bolts just for hangers. I have found silicone plugs work best for the final appearance(no cracks or chips). That tape works great, you can get it in different mil thickness too. Newspaper works great if you are covering something big(as long as you are not going over 450 deg). If you need some help check out www.echosupply.com they helped me out bigtime!
