TECH REQUEST: Block Sanding
Discussion in 'The Hokey Ass Message Board' started by FONZI, Oct 12, 2004.
  1. FONZI
    FONZI
    Please school me on block sanding. Looking for tips, do's and dont's. Got my car in primer right now. Need to block it and primer again (maybee twice) before paint.
    FONZI
  2. Roothawg
    Roothawg
    Block in one direction with one grit. Say 320, then go the other direction with the next grit say 400.
    Guide coat everything. If you are unfamiliar with that, it is like spraying a fine coat of a disimilar color to show highs and lows after sanding.
    Use a couple of drops of liquid dish soap to help while you wet sand. You can use a soaker hose(garden supplies at walmart)to keep feeding the water without making a giant mess on the floor.
    Use a rubber block and wet/dry paper ( the black stuff).
  3. low springs
    low springs
    from Long Beach
    take your time. have a sponge in your left hand while you block with your right and squeeze it every so often to keep feed the water. that way you you don't have to hold the hose or keep bending over to dip into the bucket. use some liquid soap too.
    i'll swing by this weekend to give you the front spash guard.
  4. dixiedog
    dixiedog
    Wet sand in a cross hatch pattern and dont put a lot of weight into it, let the paper do the work. Like Mr. Root says use the 320 & 400 paper and guide coat (usually black or white primer opposite of the primer color. Be carefull around the corners & rounded edges.
  5. FONZI
    FONZI
    Should I be using a block on the straight panels and then something more flexible on the curves?
    FONZI
  6. slammed
    slammed
    Yes, flexible for curve's. Another tip: sight down the panel when it's wet to see if it's wavy. Even pressure when sanding. Rubber mat to stand on.
  7. DrJ
    DrJ
    I DIDN'T WRITE THIS!
    Carl Brunson in Las Vegas did.
    I just saved it for this occasion... [​IMG]
    The Subject: Let's get something straight.....
    At 19:13:21 on 05/15/99, kroozn1 (kroozn2@writeme.com) wrote:
    Let's get something straight ----your car.
    Looking at cars at events this spring, I supprised at how many cars have great engines, good
    looking ch***is, sometimes awesome interiors, but really friendly bodies. You know, the body just
    keeps waving at you. It looks like if there was a little more time spent block sanding that the body
    would be straight.
    I started watching some young guys in the paint and body biz and realize they mostly replace
    panels and really don't know how to block sand, so I decided to do a short post on blocking.
    Folks, the Rambler was kroozn cuz it's kinda a long post for me.
    If your not interested in paint and body work skip this post. there is a lot more than you may
    want to know here. :)
    I've been sanding cars for about 30 years . I don't know if that makes me an expert or just
    stupid, but I can block sand a car to be super straight. Here is what I hope will be useful
    information on how I block sand. If you use another method, I'd sure like to know about it.
    Especially if it's an easier way. In writing this I found out it's a little difficult to explain something I
    do so much of I don't even have to think about it and I'm finding it's hard to describe movements.
    I don't have all- timers yet, but I think I have a touch of part-timers, so if you can see I left
    something out, please jump in and fill in the blanks. I'd really like to hear methods from the Great
    South land..
    Straight cars begin with good body work and it makes the rest of the process easier if you can get
    the body as straight as possible. I tell people doing a car for the first time to do one panel till it's
    right and then go to the next panel so it doesn't become overwhelming.
    First study the panel. Look at the damage on it. Guess as to how it happened because you need to
    reverse the damage by pushing, pulling and then the hammer and dolly work of getting the metal as
    close as possible to the original shape without going too far and stretching the metal and creating a
    high spot. If the metal was stretched when it was damaged or in the repair work there are two
    options. Beat the stretched metal lower than the surrounding metal or shrinking it (the preferred
    method). I'm not going into shrinking in this post cuz it's about block sanding. The perfect repair is
    metal finished, using no fillers. Unless you've got some experience working metal it's more than
    likely you'll stretch the metal trying to" metal finish", but there is only one way to get experience.
    Cuz this post is about sanding, I'm not going there either.
    Next "preferred" method is lead work to fill the low spots. It's slow work for me and expensive.
    What's next? Polyester body fillers. You've heard it called bondo or plastic. Ok, we'll go there. It's
    what almost everyone uses and what we have today is very good. I believe that if the old time
    body men who were melting lead on cars would have had access to today's body fillers, there
    would have never been a stick of lead soldered on a car. Today's fillers are that good, in my
    opinion.
    OK, all the damaged areas have been worked out and none of the metal is higher than the original
    panel was, study it again. Look at all the areas that will need filler. Sight down the side, look for
    low spots in the beauty marks and for any more low spots that could be "bumped" out. Check
    alignment to the adjacent panels. You'd be amazed at how many cars are painted without fitting the
    panels first. Align for gaps and anything that goes on your panel should be test fitted now (lights,
    moldings, fenders, grilles, etc.).
    After all that, the panel is ready to prep for filler. If there is paint on it, clean with grease and wax
    remover. Put on your safety gl***es, gloves and dust mask (3M #7048 is one of the better ones).
    Take a grinder with #24 grit 8 " disc and using light pressure go right to left and left to right
    with only the top 1/3 of the disc. This action will give a cross hatch pattern to the metal showing the
    low spots without any grinding marks on them and the high spots show up fast. Bump up any really
    low spots with a dolly or hammer and tap any high spots down . I grind the area 4" to 5" larger
    than the area to be filled and clean the low spots with a smaller grinder. An old 8" disc can be cut
    down with straight cuts on the edges and the points created will get into the smaller low spots. A
    little sandblaster will also get the paint out of the low spots. What you want is a clean, rough surface
    for the filler to bond to.
    Don't touch it with your bare hands! Oils from your hands can ruin the bond. Use air to blow the
    area clean.
    Buy a quality body filler. You'll be thankful later. The cheap stuff is about $10 a gallon and the
    good stuff $20-25. The cheaper fillers cure rock hard and any money you save will be lost in the
    extra time and sandpaper you'll use sanding it. Stir it up well, the resins that thin the filler tent to rise
    to the top. I'd recommend a brand, but what works best for me here in Vegas wasn't what I liked
    in Illinois. Temperature and humidity differences must be the reason. Find out what the quality
    body shops in your area are using.
    Use a paint stick to dip some filler from the can onto a plastic pallet ($2 from the supply house) ,
    add the hardener and gently fold the hardener into the filler with the stick until the filler is almost the
    same color throughout. S****e the filler off the stick with your applicator ( I like the plastic shrink
    pack kind) and finish gently folding the hardener into the filler. Why do I say gently? If the
    hardener is aggressively stirred into the filler air is stirred in too and causes little bubbles in the filler
    that will make a lot of little pin holes in the surface when it's sanded. Follow the directions on the
    amount of hardener to use. Too little and it'll cure too slow and perhaps not fully cure till after it's
    painted over. A bad thing. Too much and and the color from the hardener can bleed through to the
    top coats. A bad thing, too.
    Never reuse the stick you use to mix the filler and hardener with to get more filler from the can. A
    little hardener transferred off the stick to the can may ruin a whole gallon.
    The old timers always said that it should only take 3 coats of filler to finish a repair. Generally it's
    still true.
    1st. fill coat- to take care of the low spots.
    2nd. contour coat- to give it the correct shape.
    3rd. finish coat- to fill pin holes and imperfections
    Fill coats should be applied in the lowest area using some pressure in the first strokes of application
    to force the filler into the grinding marks for a strong bond. The next strokes can be lighter and
    cover more area leaving enough filler to be a little higher than the metal. I was taught to never apply
    filler in little dabs or up and down on the side of a car because it just creates waves, so I always
    apply filler right to left and there is less "highs and lows" to sand out. Most guys like to use a
    "cheese grater" to remove the excess filler as it starts to firm up. It's quick and easy, but I don't care
    for the way it has the tendency to break the filler loose from the metal on the edges. I wait till the
    filler is firm and sand it with #36 grit until it feels a little low. If some metal high spots show, they are
    tapped slightly down to create a low spot. Now just quickly sand with #80 grit to take out some of
    the #36 scratches and be sure all the filler has some sanding marks in it to help bond the next coat.
    After every sanding blow off all sanding dust. It makes a mess in the shop, but your next application
    of filler will get the best bond if the surface is clean.
    Sanding the filler to contour is a lot easier if it can be smoothly applied, building it a little higher than
    the panel. Not too much higher and try to taper the edge of the filler so it make a smooth transition
    to the metal. Filler is a lot easier to put on than sand off. Start with #36 grit on a sanding block.
    The larger the area of filler to be sanded, the longer the block should be. My longest is 16". Power
    sanders are ok to start with, but difficult to get that filler super straight with, so hand blocking is
    almost required. Adhesive backed sandpaper makes available almost any shape you need for a
    block. PVC pipe, a stiff section of hose or a piece of wood sanded to a needed contour.
    How filler is sanded with a block is one of the things that makes a panel super straight or wavy.
    Start with #36 (3M #02232) or #40 grit on your block and position yourself so you can sand the
    length of the filler with some pressure on the block. I start sanding in the center of the filler using a
    back and forth "X" motion, narrowing the sides of the ">X<" . The smaller the block, the
    narrower the sides of the "X" need to be. Sand horizontally as much as possible, up and down
    motions create the "friendly look", a panel that waves at you.
    "Feeling" your body work or block sanding as your working is important. What looks straight may
    look like heck with paint on it. Feel the entire repair area by running your hand from left to right and
    right to left. Then check up and down. Feel often as you sand. On the sides of cars the up and
    down isn't as critical, it doesn't seem to show unless it's pretty bad. Hoods, roofs and deck lids
    have to be nice feeling in all directions.
    Sand till the surface is level and the edges of the filler are starting to feather to the metal, but it's still
    a little "high" feeling. Now switch to #80 (3M #02230) on the block ( it's nice to have two blocks,
    1 for 36 &amp; 1 for 80) and sand till it's smooth and the edges of the filler feather smoothly to the
    metal. If you hit high spots of metal as your sanding, tap them a little low.
    It seems like this area is the hardest for most people so I'm going to give a few methods of getting
    the filler level and feathered onto the metal.
    Use a "guide coat". If your close to level, but it just doesn't feel right, use a spray can of
    LACQUER primer and put a dry coat evenly over the area (include the surrounding metal) and
    then sand again. The primer will sand off the "highs" first and stay in the" lows" letting you see where
    the problem is.
    Switch back to the #36 grit then follow with another coat of filler. The co****r the sand paper
    the flatter it will cut. Smoother grits will "follow" gradual waves and co****r grits won't. Remember
    this when block sanding anything: Use the co**** grit as long as you can, then switch to the finer grit
    to remove the co**** grit scratches.
    Here is a secret method that works unbelievably well, but you gotta really want your car straight
    to use this stuff. IT SMELLS RANK. If you "broke wind" like this stuff smells, you could clear a
    biker bar in seconds . It is grille brick. The black blocks restaurants use to clean grills. It shapes
    itself to any shape so sand on an area you want to duplicate and that is the shape it will have to
    block with. It breaks away fast if the surface is rough, so I use it after smoothing some with # 80
    grit. Grille brick has a co**** side and a smooth side. The brand name "Disco" seems to be less
    rank than others. It cost from $15 to $25 a case at restaurant supply houses. If someone unwanted
    is hanging around, just start sanding with this stuff 'n you'll be alone.
    Now we're getting somewhere, your all alone and your body work feels like the dent your fixing
    was almost never there. Blow the area off well and examine the surface closely. Look for pin holes
    and small bubbles of air that may have only a thin coat of filler covering them. Test any suspect
    spots with a knife blade or small screwdriver. If there is a bubble, dig it out. If there is any air
    pockets trapped in the filler, as soon as the car gets hot in the sun, the air is going to expand and
    look like heck in the finished paint job.
    Finish coats should be applied as smooth as possible and there are several ways to thin the filler for
    the last coat. Some body men add a little fibergl*** resin or pour off some of the resin on a new
    can of filler to add to the last coat and there is "Plastic Honey"( a can of just filler resin) if you can
    find it. Thinning fillers for the final coat has been almost replaced with with "finishing putty's". These
    are two part putties that will stick to almost any sanded surface (including paint), spreads like warm
    ****er and sand easy enough they can be finished with fine sandpaper. Great stuff and there are lots
    of them.
    I haven't used all of them, but the ones I have and don't hesitate to recommend are:
    Evercoat Metal Glaze #100416. If your going to apply more over metal than filler, this seems to
    have a better "bite".
    Evercoat Glaze Coat #100417. Great stuff. In the rust belt if it's only a ding that's needing fixed,
    the paint is sanded and the dings filled with Glaze Coat. The factory corrosion protection isn't taken
    away by grinding. Good for finishing filler too.
    Wurth Polyester Filler Extra Fine: My favorite. Does everything the above two do, but hard to
    find and a bit pricey.
    Some of the putties have white hardeners. Try to get one with a colored hardener. It's hard to tell
    when the hardener is mixed thoroughly with the putty without colored hardener.
    Apply the "putty coat" as smooth as possible and extend it out beyond the area you've worked on.
    Start the sanding with #80 and switch to #150 for finishing then a light sand with some #220. Use a
    guide coat on the finishing if you need to. But get it right. Primer is the next step and using primer
    costing up to $200 a gallon to do the work of $20 a gallon filler doesn't make much sense.
    The #150 grit is 3M #02596. Pretty neat stuff, it's the same 2 3/4" wide as regular blocking
    sandpaper but comes on a roll and is adhesive backed too. I believe the grits available on the rolls
    range from #80 to #400.
    A neat sanding backing pad is Meguiars # E7200. It's not really a block, it's firm enough to sand
    straight with and to knock out those stink block scratches with #150, but will bend some for the
    curved areas. Good for color sanding paper too. Helps level that "peel".
    It's primer time..... maybe . I don't like to prime repairs that have had filler on them the same day.
    Yes, I know that it says 1 hour or so on the can, but there is solvents in the fillers and an overnight
    dry time can't hurt. BTW, I never have my body work scratches show up later in the paint (called
    shrinking). All paint around your repair must be feathered out and any chips, scratches or other
    paint imperfections. You must not be able to feel the paint edge. I use #220 grit and sand the
    surrounding area with #320. Blow the area off well and if you feel you've been touching the area
    with your bare hands, use grease and wax remover on the painted area ONLY. Fillers have a habit
    of soaking up the stuff. Could cause you problems later.
    Tape and cover everything you don't want primer on. Today's high build primers are heavy and go
    everywhere you don't want them. Lots of people don't think about door jambs and inner fenders till
    it's too late. Don't just cover the tail pipe, do the muffler too. Lay something on the floor. If you
    over spray it, it's gonna be there a while. Anywhere you think primer might go, it will. AND places
    you think it couldn't possibly go. Fair warning. Ounce of prevention time.
    I've posted about the different types of primers before so I'll not go into them much this time, cuz
    this is supposed to be about block sanding.
    I will say this: IF YOUR NOT IN A WELL VENTILATED AREA AND HAVE A GOOD
    RESPIRATOR, TAKE IT TO A SHOP AND LET THEM PRIME IT. The stuff can kill you or
    make you sick. Ain't no car worth it.
    The biggest cause of paint failure is solvent trapping. That's putting on another coat before the last
    one has dried enough and trapping the thinners underneath. They are going to try to come out
    sometime. In the hot sun later is a good bet.
    The second biggest cause of paint failure is drying times again (we're in a hurry about everything
    these days). Not letting the primer dry long enough before sanding. Here in the desert I feel safe
    sanding the next day, but in Illinois if I wanted to sand soon, the infrared heat lamps were on the
    primer. Temperature and humidity play a big role. Check with the paint rep in your area. The info
    on the can is just general stuff for ideal conditions.
    OK, you've etch primed and have 4 or 5 coats of some good filling fully cured primer on your car,
    let's block sand. Guide coat with a contrasting color. Something you can really see. Spray can
    silver works on dark primers and rattle can black for the light colored ones.
    I like to "dry" block the first go around (yep, there is more than one). Using #150 grit on the
    longest block that can be used on the panel. If you "wet" sand use #220. Use the same motions as
    in sanding the filler and putty. More back and forth than up and down. Remember that filler that felt
    so perfect? Well, how's it look now that your sanding the guide coat off? Chances are not so
    perfect. It's difficult to blend filler into the metal. That's why so many straight cars are "skim" coated
    with a few mills of filler and sanded straight.
    Ideally the first block sand will take off all the guide coat and the primer is blown off, re-guide
    coated and re-blocked with # 320, then re-guide coat and wet sanded with # P600. Just seal and
    paint. That's ideally.
    Reality:
    Block until there is no more guide coat. If some filler shows and there is guide coat around it, keep
    blocking till the guide coat is gone. Sand down that high spot. Stop sanding if there is metal
    showing. You'll never sand a metal high spot down. Tap it low and use more finishing putty and
    re-prime.
    Before you re-prime, get another panel ready for 1st primer so you can save a little time by priming
    two panels at a time.Keep going around the car a panel at a time till it's all in 2nd prime and guide
    coat.
    The second prime can be wet blocked with #320 and finish sanded with #P600. It's unlikely you'll
    break into filler or hit metal on the second time around, but if you do......you know the drill.
    I musta borrowed enjenjo's car and he's installed a huge fuel cell in the Marlin's back window cuz I
    done some rambler'n on and told you a whole lot more than you probably wanted to know....again.
    Keys anyone?
    Carl
    Your paint and bodyman.
  8. Gracie
    Gracie
    Yep, that's how he does it... I used to work with him... he is amazing. I miss being out there watching him work... he's faster than a speeding bullet...
    Amazing.
  9. Rusty
    Rusty
    Now that is a serious post. Makes me want to go out tonight and get some more sandpaper. Thanks
  10. Where was that from Dr. J?
  11. Slag Kustom
    Slag Kustom
    another area to look at is all the edges, wheel well edges and lower rockers. too many times i look at cars that seem nice they see nasty edges and ****py looking wheel openings. if you are going to spend the time trying to paint it look at the whole panel. mucked up edges and wheel wells scream piece of ****.avoid making dead lines on trying to paint the car by any certian date. you will start to over look stuff just to get it done.
  12. DrJ
    DrJ
  13. DrJ
    DrJ
    [ QUOTE ]
    [/ QUOTE ]
    Yes it does..
    I'd like to add, after watching that stupid Mercedes commercial where the ditz buys a bunch of the finest towels money can buy to wash her car she puts them on the gravelly dirty driveway to pick up **** that WILL scratch her car!
    If you drop that precious piece of wet or dry paper on the ground, throw it away!
    Immediately!
    It WILL SCRATCH your car instead of sanding it from now on if you continue to use it. [​IMG]
  14. Slag Kustom
    Slag Kustom
    in stead of using a small squegee to clean the sanding sludge off a panel use an old wiper blade.
    wash the car really good when your done the sludge gets every where and is tough to get off when it drys.
  15. rustymetal
    rustymetal
    hi doc wondering if you have a door sand blasted should you epoxy primer it first before you put your filler on.
  16. FONZI
    FONZI
    Wow,
    Thanks Doc...And everyone else! Great info. THe guys at the body shop told me to sand the whole car with 80! That the next coat of primer would fill hte scratches the 80 leaves. THen go down to maybee 150. I was supicious of this advice as Dante finished all his bodywork in 150 and it is silky smooth.
    FONZI
  17. Slag Kustom
    Slag Kustom
    lots of guys forget that primer is not ment as a filler. the old days of 17 coats of laquer you really want the least amount of material on a car you can get away with.
    i finish all my body work with grit 220 guide coating between grit changes and go over all my feather edges with grit 320.
  18. FONZI
    FONZI
    Even the high build filler primer?
    FONZI
  19. Slag Kustom
    Slag Kustom
    yes even the high build stuff. the more material on the ca will all expand and contract at diffrent rates. i have seen guys try to bury bad work with primer only to have it come back or crack 2 months from when it was painted.
  20. FONZI
    FONZI
    THANKS,
    I think I am gonna try and start with 150 and then move on to 220 after the next primer session, then finally 320 before sealing and paint.
    FONZI
  21. low springs
    low springs
    from Long Beach
    i would suggest starting at 220 and moving up.
    don't sand it with 80 and fill it in with primer. thats a NO NO. jsut take your time and use sanding blocks instead of your hands. always have something between your hand and the sandpaper to evenly apply pressure.
    if you need me to go out and check on stuff let me know.
  22. Armstrong
    Armstrong
    One of the toughest things to get right about body work is the AT***UDE. You have to be aware that it is not easy or fast. If you can get yourself into the state of mind that lets you do it right,the outcome will be worth the effort. Spend the time and the effort,you'll be glad you did. Schedules are for the pros,just take the time you need. If you hurry the "good enoughs" will haunt you after it is painted. Experience speaking here!
  23. mikeyboy
    mikeyboy
    Gotta print that....have much finish work to do on the 46 before Austin... Thanks Dr for some killer tips. The only thing i could add is to sand at 45 degrees to a curve, and use the longest block available on the flat stuff
  24. Paul
    Paul
    Editor
  25. ____
    ____
    yes,epoxy over your bare metal....then body filler and other priimers.sealers
    i block with 180 grit and a hand long file and flexible pad on the curved panels.
    .prime,block with 180,prime ,block with 180,prime,block with 180, prime..
    if anytime your not sure use a guide coat,,i usually dont because i can see the color change in the low spots or scratches,,
    after the last coat of primer i wet sand with 400
    ps .if your going for a show paint job or whatever,its good idea to let the primer and fillers cure for a month or so to give it time to setup and cure and do any shrinking if its going to,then block a time or two more,most of todays primers have pretty much eliminated all of that,but its still a good idea.
    im not an expert,but thats the way i do it,,
    later,
    sam
  26. banzaitoyota
    banzaitoyota
    DrJ: I appreciant the lesson on how to do it right! I hope I can return the favor someday.
