Tech request; proper plastigauge useage
Discussion in 'The Hokey Ass Message Board' started by zgears, Jul 18, 2005.
  1. zgears
    zgears
    im switching pistons out on a rebuilt 37 flathead. ive got the tork specs, im about ready to go. im removing the rods switching pistons and puting them back, do i need to check oil flow clearence w/ a plastigauge? ether way how is that used.
  2. Ted H
    Ted H
    Zgears,
    Plastigage is used to determine the clearence between a bearing and the shaft it fits. It comes in a range of sizes ie .000 to .005, .005 t0 .010 ect.
    To use it wipe the crank journal comlpetely free of oil ( the rod bearings also). cut a length of the plastigage to the width of the bearing. Place it on the crank journal parallel to the crank axis at a point it will fall in the center of the rod cap. Tighten the bearing cap to specified tourck, thenremove cap and the plastigage will have been flatened. There is a gage printed on the little envelope it comes in. Place this gage over the flatened plastigage until it matches up with the width and viola you now know how much clearence you have. If the clearence is within specs, clean all plastigage from crank and bearing,put on a little ***embly lube, re torqe to specs and move on to the next piston.
    Hope this helps,
    Ted
    PS: DON'T MOVE THE CRANK WHILE YOU ARE TORQING THE BEARING CAP.
  3. squirrel
    Ps: ....or Loosening The Bearing Cap
  4. zonkola
    zonkola
    from NorCal
    Put some thin paper on one of the main bearings that you're not measuring and torque the cap down. This helps to hold the crank still while you measure the other main bearings. Obviously you need to make sure you remove the paper before you ****on the engine up!
  5. zgears
    zgears
    thanks for the info. whatabout the gap size for a flathead full-floating brearing?
  6. zgears
    zgears
    bttt, any one know gap size?
  7. zgears
    zgears
    bttt one last time
  8. squirrel
    Motors manual suggests .0015 to .003" for all Ford engines 1935-42.
