TECH. SOLUTION FOR the 235 VAC. ADVANCE PROBLEMS!!! w/pics.
Discussion in 'The Hokey Ass Message Board' started by TINGLER, May 11, 2004.
  1. TINGLER
    TINGLER
  2. yorgatron
    yorgatron
    that's awesome,now take it back off,make a couple dozen duplicates,and sell'em on ebay and make your money back-george [​IMG]
  3. shoebox72
    shoebox72
    You're about a fabricatin' motherfucker. Excellent!
    Now about this rope, It seems I'm all out. Could you send me a piece? [​IMG]
    Billy
  4. So, ummmm, ahhhh, are ya gonna put up the plans, there's a Biscayne I know that has a 235... [​IMG]
    Way to go! I hope FatHack didn't have a hand in it...
    Jay
  5. burndup
    burndup
    from Norco, CA
    tech request... how does one piss UP a rope?
    thats bitchin, is it a V8 one? hei or standard?
  6. Damn...now people are going to expect ALL artist-types to be mechanicaly smart. [​IMG] [​IMG] Very ingenius.
  7. KCMongo
    KCMongo
    from KC
    Very sweet, way to make what you can get cheap work!
    With your permission gonna have to steal that one for my website, know 2-3 guys that have bitched about the price of the original style one's that will dig it.
    MONGO
  8. Finally a sensible car related post...Nice werk.
    maiki
  9. Petejoe
    Petejoe
    from Zoar, Ohio
    Great work definitely tech material.
  10. 41ChevyTrucker
    41ChevyTrucker
    nice job. it looks kind of cool hanging way out there parallel to the motor too. shows off the mechanics
    I thought there was some "science" to the size of a vacuum cannister but I could be mistaken. If it runs good that sounds like the right size to me. [​IMG]
  11. DrJ
    DrJ
    That looks great except step #4 is questionable.
    That bracket is there to restrict the distance the rod is allowed to move and therefor how many total degrees the advance advances the distributor.
    Maybe the whole available travel just happens to be the right amount, maybe. If it ends up advancing too far and pinging at no load cruising speed then you might need to add some ofthat frame back on, just not the whole thing that encircles the rod.
    It isn't going to relate the same as the dissy it came off of because the 6 cyl distributor arm is longer so it needsto move farther, but on a different application it might need some of the frame left on.
    KnowhatImean?
  12. yorgatron
    yorgatron
    Crane makes an adjustable vacuum advance,about $22.00,i found a brand new one on ebay for $5.00
  13. yorgatron
    yorgatron
    you're not that bitchy [​IMG] i gotta admit,sometimes i get sucked into the drama,but i'm really here for the tech.no,really [​IMG]
  14. 41ChevyTrucker
    41ChevyTrucker
    [ QUOTE ]
    Boy that sounded bitchy didn't it? [​IMG] [​IMG] [​IMG]
    seriously, if anyone wants to chat a little about which vac advance for which engine....then I'm very interested. Is there an equation or formula something for this?
    Thanks again fellas for the compliments and all..
    VT.
    [/ QUOTE ]
    dude were you bitching at me???? I'LL DROP SCIENCE on your ASS at PASO!!! LOL [​IMG] [​IMG] (kidding/drama)
    but seriously/tech... The size of the can/diaphram? relates to the curve of the advance. I think I read something about the sizing of "the can" in one of my inline books I will search for it when I get home tonight...or someone here must know the "formula" ?
  15. 41ChevyTrucker
    41ChevyTrucker
    no hard science yet but I found this instruction manual for the crane adjustable canister that sheds a little light on how it works. (learning myself too) It just talks about listening for spark knock.
    http://www.cranecams.com/pdf/254g.pdf
    "For maximum performance it is best to run as
    much vacuum timing as possible without
    spark knock."
  16. DrJ
    DrJ
    You're welcome, glad to help out once in a while. Also glad that my buttin in on stuff occasionally helps out.
    Now can I go back to the dissing VDO O/T thread? [​IMG] [​IMG]
    and checking out pictures of germ's girlfriends on thehun? [​IMG]
  17. shoebox72
    shoebox72
    VT, So the advance is working, tell us how it runs now.
    Billy
  18. 41ChevyTrucker
    41ChevyTrucker
    ok here is what I found...
    From California Bill's Chev Speed Manual
    Advance chart as follows:
    1 deg. advance at 600 rpm
    12 deg advance at 1200 rpm
    20 deg advance at 2000 rpm
    39.5 deg advance at 3450 rpm
    Vacuum Data:
    7" HG of vacuum to start travel
    16" HG vacuum should be 20 deg advance
    And from the Leo Santucci Inline Six Power Manual:
    For street use total advance should occur at 3000rpm which should be between 32-38 degrees.
    Cal Bill is referring to Chev 41-49 distributors but probably wouldn't be too different for 50's ?
  19. Nads
    Nads
    from Hypocrisy
    Pure genie arse, good job VonTingler, good job DrJ for being an astute observer.
    My limited thinking means that the simplest of problems leave me befuddled. If I were a bicycle repairman I'd attempt to change flat tires without removing the rims off the frame.
    Anyways I'm printing this sucker because I'm an inline nutcase.
    I've got a working vacuum advance that I can use to copy for correct bracket length.
    You guys never fail to amaze me.
