Tech: Steel wheels at a Steal!
Discussion in 'The Hokey Ass Message Board' started by SlamCouver, Nov 24, 2007.
  1. SlamCouver
    SlamCouver
    from Brazil, IL
    Iv noticed the price of steel rims/wheels has been climing the last couple months and that nice article in hotrod deluxe maybe sparked some more intrest. this is my first Tech thread so bare with me.
    heres a Tech on how to get nice vintage steel wheel/wheels for cheap!
    ever notice the car supports created out of welded together rims at the U-pull its or the vintage car s**** yards. well alot of those rims are **** but if you look you will find some decent steelies!
    I managed to pick up 3 rims for the price of 25 bucks
    Edit: bring a stencil with the bolt pattern you need to the yard before searching.
  2. SlamCouver
    SlamCouver
    from Brazil, IL
    you will need some tools first
    angle grinder
    2x6
    safty gl***es
    ear protection
    malt liquor of your choice
  3. Flat_Broke
    Flat_Broke
    haha...schlitz
  4. SlamCouver
    SlamCouver
    from Brazil, IL
    so to get started you will need to carefully grind the tack welds that are supporting the rim on the bolt side. lightly grind all 4 tacks in this case.
    after grinding pick up your 2x6 board and smack the top rim off!
    make sure your *** is hanging out.
  5. SlamCouver
    SlamCouver
    from Brazil, IL
    after you have seperated the two wheels from each other lightly grind the remaining weld off of the top of the rim. I then proceeded to polish the grinds with sand paper.
  6. SlamCouver
    SlamCouver
    from Brazil, IL
    after that process you can media blast or sand the rims you have picked up for a killer deal. in this instance I scored 2 matching rims for 12 bucks a piece. instead of the usualy 75-100 bucks a pop or the gawd awfull prices of ebay. for real steel wheels.
    now with all this in mind every instance will be a bit diffrent but give those old forgotten welded rims a look over and you might get a great deal.
  7. BigBlockMopar
    BigBlockMopar
    great tip, but I think you missed something...
    ... when is the bolt-circle-checking done so you're sure these junkyard-wheels actually fit on the car's drumstuds... is it before or after all this work? :D
  8. SlamCouver
    SlamCouver
    from Brazil, IL
    this is before! thanks for pointing that out. i brought a stencil with my bolt pattern to the yard before searching.
  9. Dantastic
    Dantastic
    Who took your photos? Looks like he knew what he was doing... Oh wait, it was me.
  10. budd
    budd
    this is a great idea, i have been checking out these stands at a yard i go to and they told me $5,00 a wheel if i replace it with another one, i have an old axle end all ready to go.
  11. squirrel
    don't worry, if they're the wrong bolt pattern, just sell them on epay and buy more malt beverage with the proceeds
  12. skajaquada
    skajaquada
    from SLC Utard
    hell, i get 4 steel wheels for $25 at the yard i go to...and i don't even have to do any grinding :D
  13. Squablow
    Squablow
    I save all the old steel wheels I get on cars that I part out, or wherever I can find them. I'm hoarding them in my shop's ba*****t, I have stacks of them.
    It's always cheaper to have a m***ive supply at the ready than to buy them. Plus, a lot of old hubcaps only fit a specific rim, so that's important too.
  14. Noland
    Noland
    Good Tech
    Heres one I built awhile back
    Its from a t bird center and a scottsdale rim
    reversed 3 1/2 backspacing
    The hardest part was finding two tight fitting rims
    still need to build the other
  15. lakesmod
    lakesmod
    V.W. outer rim,dodge inner.
  16. hunter
    hunter
    lakesmod- nice simple jig. i like it
  17. lakesmod
    lakesmod
  18. the duke
    the duke
    not schlitz but schlitz bull Ice! I usually stay away from my power tools after one of those boys there.
