Tech : Stromberg Emulsion Tube Removal
Discussion in 'The Hokey Ass Message Board' started by Flathead Youngin', May 23, 2007.
  1. Bruce Lancaster
    Bruce Lancaster
    So...start by going down to your Ford agency and demanding a 67-9590 rebuild kit. Don't take any **** from the ***** at the counter--if there's trouble, take hastages and keep repeating your demand.
  2. uncle max
    uncle max
    If I wrap my tool with masking tape, won't it hurt when I take it off? :D
  3. Bruce Lancaster
    Bruce Lancaster
    Next, the left picture: Over on the left are two tapered screw tools as sold by Stromberg and Snap On for yanking the tubes--you could improvise these with sheet metal screws or something, but don't--bad basic design. Not only do they grip with only one thread seriously engaged, if you have to drive them in farther to get a grip you are also expanding the already stuck tube.
    Next to those is the simple screw/wingnut gadget described above and a #6 tap in a handle.
    Weird angled thingy next is a KRWilson sight gl*** for measuring fuel level. It screws into a jet plug hole. Right below that is a Speedway brake banjo fitting and bolt, available with Stromberg threads...3/8 fine, I'm at work and don't remember thread number. That plus the crush washers matching will be the basis of replicating the KRW, which is a bit difficult to locate...
    Over a bit farther are two of the jet plug remover bits described above, obviously easy to replicate from a junk socket and a bit of metal.
    Jet wrenches shown are the best on the planet...Plomb T wrench, Snap On--Stromberg socket style. The two shown are different sizes, one for 97 and EE types, the other for AA's and other big Strombergs. All the way over are two hollow screwdrivers suitable for power valve--note that sleeving or wrapping either of these would produce self centering tools as I describe above.
    The thin strip of metal right of center is also of interest--the forked end is of no use here, it adjusts power valve on AA Strombergs, but the bent and slotted end is a neat factory bending tool for 97 float adjustment. Anyone who owns a hacksaw blade should be able to duplicate that in thirty seconds.
    Especially handy for final adjustment of running level with full carb on engine...
    Also in there are Snap On gauges for preliminary level adjustment. The red device is a heavy duty carburetor jack, in case you need help lifting the thing.
  4. Bruce Lancaster
    Bruce Lancaster
    Aluminum gadget in right picture is an Eelco jet board with Proto jet wrench, a really lucky find.
  5. Bruce Lancaster
    Bruce Lancaster
    Another thing about the jet plug removal tool: If properly made to fit the groove and properly curved to fit bottom radius of groove, it will fit perfectly over a range of angles AND hold the plug well enough that you can lift it into and out of location with the wrench. This thing on a 1/4"ratchet reaches the plugs on the engine easily and handles them without any fumbling.
  6. SinisterCustom
    SinisterCustom
    Humph.....
    And to think I took mine apart without ANY of those fancy tools.......:p
    Although I do have a jet wrench on order to get those out.....:D
    HaHaHa....yeah, probably my FAV of Walken's skits!
  7. Bruce Lancaster
    Bruce Lancaster
    For several years when I was a teenager, I worked on the '48 Ford with only the car's original tool kit, a simple 10 piece or so socket set, and a Whale tool, ancient relative of the vise grip. I actually did not own a hammer or any normal pliers...primitive kit did not stop me from doing much of anything, but I must say I lost a lot less blood after I got more tools...and I don't think I could ever have improvised a way to get out stuck Stromberg jets. Fortunately, I had a 94, which requred only the car's own screwdriver and a paperclip for complete dis***embly.
  8. Bruce Lancaster
    Bruce Lancaster
    "If I wrap my tool with masking tape, won't it hurt when I take it off?"
    Yes, but at least you won't have the horror of waking up the next morning and discovering you've caught a bad case of the zinc oxide from her...
  9. alchemy
    alchemy
    I have LOTS of crusty ones, so I think soaking the WHOLE carb is a good idea. Actually, take it as far apart as you easily can, then soak all the chunks for as long as you can take it. Just beware that some cleaners will digest the pot metal bodies. Check them every day or so to be sure your cleaner isn't too agressive.
    I don't think that mineral spirits will have any affect on the corrosion that is common with the pot metal. That stuff may need to be vinegared or acid washed somehow.
    If you end up blasting the carbs, be very careful around the internal threads, as some of them are fragile and some are irreplaceable. Nobody makes a nutsert with the correct orifices for those jet holes.
  10. Bruce Lancaster
    Bruce Lancaster
    A good cheap soak for loosening stuck bits is a can of diesel fuel or furnace oil, if carb isn't going to be worked on immediately. Just let it marinate til you have time...
    White crud corrosion usually comes off with some vinegar, and vinegar (cheap white gallon jug generic) also gives a nice surface cleaning when applied vigorously with a toothbrush. Everything you eat will taste like sauerkraut, though, til it wears off your brush.
    I do not soak for any great length of time in vinegar--I think these carbs are so soft they might just disappear if left in there.
  11. Flathead Youngin'
    Flathead Youngin'
    what is it really for?
    also, are the reamers used for sizing the throttle shaft bushings? they seem to have an awful steep taper on them.......
  12. strombergs97
    strombergs97
    Hello All....Again, excellent TECH.. One suggestion, when using PB Blaster or whatever, leave the two jet plugs and check valve plug in..The penetrating oil will not leak out..Spray on the idle jets, power valve, and down the emulsion tubes..I fill the emulsion tubes up with the oil..weeps through the holes and pentrates to the outside of the tubes.. Be patient and let set for several days..Remember, penetrating oil needs to wick down the threads..
    Duane..:eek:
  13. draggin ass
    draggin ass
    from hell
    do they just push in lightly?? how do you get them back in? press in?
  14. strombergs97
    strombergs97
    Hello..Here are some tools that are necessary..
    Pipe cleaners.(Good for emulsion tubes)
    PB Blaster..(Let them soak,be patient)..
    Helicoil set..(Replace the stripped body threads)
    Notched Screwdriver..(Removing the Power valves)
    Jet Remover..(Welded a socket on the Jet Wrench)
    Brushes..Different Sizes..(Cleaning, emulsion tube p***age, Power Valve hole, accelerator pump cylinder, idle jet p***ages)
    Tapes..(Cleaning threads)
    Stromberg Stand..(Repair stand, swivels)
    97s..(Notice the plug caps still on, SOAKING)
    I didn't put sizes, will if asked..
    HOPE THIS HELPS..
    :D :D Duane :D :D
  15. strombergs97
    strombergs97
    OOPS..Forgot the Cutting Torch tip cleaner..Great Tool..
    Duane..
  16. HHRdave
    HHRdave
    from So Cal
    Thank you for taking the time to post this tech article. I know what kind of time and patience it takes to load up all the pics and make it look right. Thanks!
  17. Bruce Lancaster
    Bruce Lancaster
    Them's ain't reamers--they are original type tapered screw tube yankers, which I don't use for reasons above--they are the original tool for this job, supplied by Stromberg, though. The jack is actually a tiny machinist's jack, I think really for leveling heavyish objects under a cutting tool...
    I believe Strombergs should not be reamed oversize to replace worn shafts with bigger ones...I recently found a flow test on Q-Jet primary mods (bigger bores and smaller shafts than a 97 already), and the effect of a few thousandths of extra shaft on airflow is startlingly large...slabbing the original size shafts would likely be a good idea, actually. And, there's no need to change size, since there's a bushing on each size and I ***ume they are now easy to get from the new 97 people.
  18. Petejoe
    Petejoe
    from Zoar, Ohio
    Great tech Youngin!
    thanks so much for taking the time to put this together.
    So many of us have special ways of doing these kind of jobs but very few put it together in a tech. i salute you
  19. Flathead Youngin'
    Flathead Youngin'
    You're special alright!
  20. Flathead Youngin'
    Flathead Youngin'
    what did you make that repair stand out of...or is it an old tool for this....i like that
    and, i never noticed until i was working on one last night, bruce is right....those bowl plugs have a curve in them....they aren't just flatheads like they look at a quick glance...
  21. strombergs97
    strombergs97
    Hello..The tool is about 60 years old, made for rebuilding 3 bolt carbs..or maybe others?????.
    Bruce, you are totally correct about the throttle shafts..I will never understand how br*** can wear cast iron??. Replace the shafts with the original size and get new bushings..Actually the throttle shaft rides on the cast iron of the body..Look at the shafts, and you can see the wear from the cast not the bushings..Especially the center shaft support..What a waste of money to buy new oversize shafts and the reamer???????..
    Again, I don't think br*** can wear cast iron..
    Good job Youngin, on getting the tech started and good follow through by Bruce..
    I hope you both didn't mind me chimming in..
    INFO..I had a friend do a CSI on the gasket material from England and the ones sold by Vintage Speed and Sacramento Vintage Ford..Quality of the material is equal for sealing the air horn to the body, the body to the base and the base to the intake.
    Same thickness also..
    Vintage Speed has the best sealing plug gaskets.(neoprene, sp) only on the smooth surface face..some will only take the cloth type, they fit in the ridge of the face..Where the plug gasket seals against the body..
    Duane...
  22. dan34
    dan34
    from Norway
    Congratulations :)
  23. uncle max
    uncle max
    True, for the most part, then & now. Nice little refresher for the New Year!
    *No uncle max's were killed or injured in the composition of this tech article.
  24. plym49
    plym49
    from Earth
    Can a small soda blaster be used to safely clean zinc die-cast carb bodies?
  25. strombergs97
    strombergs97
    Happy New Years, ALL..This tech is good but there is lots more to be learned..
    Duane..
  26. Abomination
    Abomination
    BTTT
    Folks ask me about this stuff, but for the Stromberg WW, WW3, etc and I send 'em to this thread. Different carb, same tricks.
    Hopefully by adding this comment, it'll come up in searches for those folks now. :cool:
  27. stainlesssteelrat
    stainlesssteelrat
    from ms
    this should be stickied or marked somehow. it's important to all of us.
  28. Bruce Lancaster
    Bruce Lancaster
    There is a LOT more...some of it probably known only to Max and his tiny group of equals out there in the wilderness.
    The br*** shafts do indeed wear the iron, which seems all wrong. My guess is that dirt embeds in the br*** and laps out the hole, bigger hole lets in more dirt, onward...
    Oversize shafts are evil, and have a surprisingly large effect on airflow*. Ideally, bush and go stock size...hard on most carbs, but the Strombergs are bushed STOCK, so WHYINHELL would anyone do what has to be a precision enlargement and shove oversize shafts into the airstream?? Tests have repeatedly shown that br*** flows significantly less air than air does.
    * AND slabbed shafts flow significantlt better than stock...this is from detailed engineering tests on Q-Jets, but it should apply perfectly well here. Airflow gained without enlarging the venturiis is ALL GOOD, increasing ultimate flow without hurting venturi excitation, wheras getting more flow by going to carb with bigger venturis necessarily postpones main jet tip-in and so hurts low end of operation...
  29. mwhistle
    mwhistle
    from sacramento
    Bruce and Duane -- I have been unable to find standard size longer (extended) throttle shafts for use with progressive linkages. The only long (extended) shafts I can find are the oversize ones. Maybe that's why folks buy the oversize shafts. If someone knows who sells standards size but longer shafts, please let us know.
    Thank you.
  30. Redbows35panel
    Redbows35panel
    I'm really surprised that no one has mentioned the accelerator pump jet tubes. I've found no easy way to get these darn things out and quite often they are plugged up. When this happens I drill out the lead plugs in the bottom of the the carb and use a fine copper wire to clean them out. There has got to be an easier way. I then reseal the access holes with a lead shot. How do you know if they are plugged. After I have soaked the dissembled carburetor I spray water down into the accelerator pump and watch for it to come out the jets. If it doesn't, you have got a problem.
    I just use a small sliding hammer to remove the emulsion tubes. If you will notice they have a flat side which align them properly. I usually reinstall them with the sliding hammer so I can rotate them if need be. Then I apply a little blue Lock***e to the plug threads and walla:eek: no leaks.:D
