TECH: Tin foil
Discussion in 'The Hokey Ass Message Board' started by Sawracer, Nov 29, 2007.
  1. maddog
    maddog
    from So Cal
    You can put a chunk of tin foil in a bucket of water with baking soda. Put in a dirty br*** item and conect the two with a jumper wire. It will be clean in the morning. Door knobs, hardware etc.
  2. 29bowtie
    29bowtie
    I remember rod magazines from the early seventies,had "road recipes",for cooking on the engine on the way to events.:eek:
  3. Sawracer
    Sawracer
    from socal
    You guys are not worthy of my technical savvy. :p
  4. 302GMC
    302GMC
    from Idaho
    There's a book, "Manifold Destiny" ... full of highway cooking recipes with mileage chart.
    Need to solder one small connection without a soldering iron? Strip wires, twist together, add solder, wrap with foil, heat with Zippo or propane torch.
  5. Around here we call it a CAR-B-Que
  6. 61 chevy
    61 chevy
    i dryed out some green pot on my engine with tin foil, thats was years ago:D
  7. DirtyTace
    DirtyTace
    Now I'd like to smell that, ur, I mean, see that!
  8. Years Ago A Friend Of My Brothers Came Into Our Kitchen Asking For Tin Foil I Asked "what It Was For "he Said "he Needed A Carburator" I Gave Him The Roll ....
    Then Sent Dad Out To Help Them With His "carburator .....
    Whole Carload Busted They Were Using It On A Bong.
  9. 40StudeDude
    40StudeDude
    If you pull out a section of about 10 feet off the roll, roll it tightly around a pencil to get it started, roll it tightly then solder a wire to it carefully, hook it to your radio and stick the whole thing out the window, you've successfully made an antenna. It'll pick up Martians, saucers and sometimes Australia...!!!
    R-
  10. Mazooma1
    Mazooma1
  11. LAROKE
    LAROKE
    All my work is outside. Had the pan off my '55 not long ago for a couple of weeks. Used tin foil to shield the crankcase from any stray illegals with leaf blowers.
  12. BigBlockMopar
    BigBlockMopar
  13. brigrat
    brigrat
    from Wa.St.
    Old thread but here goes, have dull scissors, take a piece of tin foil and cut it, walla sharp scissors ..........................
  14. spinout
    spinout
    from Dallas, TX
    If you leave your lawn mower outside all winter, squish a piece of foil over the gas cap. No water will get in there.
  15. Really?
  16. hodge!
    hodge!
    did this when we were yonger to scare people in the high school parking lot. we would wad up tin foil in little balls and put them in 20oz soda bottles then add the works toilet bowl cleaner cap off waite five min and boom chemical reaction.
  17. Speedwagen
    Speedwagen
    Period Correct use of tin foil is to cut strips and put in your Hub Caps--the urban legend was, it would confuse radar guns
  18. ehdubya
    ehdubya
    Down here it was wrapping it around a fan blade and a fish in cop's hubcap.
  19. 325w
    325w
    When I hear the rattleing of tin foil I get hungury..Got to go now........
  20. stude_trucks
    stude_trucks
    I know this thread is over a year old, but I think they stopped using tin since then and now use aluminum for foil. Just a technical FYI update on that for those projects where that may be critical.
  21. Roupe
    Roupe
    I hate to tell you all, but there is no such thing as tin foil. It is really ALUMINUM FOIL. Read the box! Do you really think you can cook food with tin? Sorry for the rant, but thats the way it is.
    Cool stories though.
  22. tfeverfred
    tfeverfred
    Put some sulfer in there with the matches and wrap it REAL tight. Then, you can throw it at a hard surface and you'll have smoke AND a very foul odor. Stink bomb 101
    Disclaimer: In NO WAY does the writer of this post advocate the use of fire or smoke as a form of amu*****t or harm to others. Do not try at home.
  23. TP
    TP
    from conroe tx
    I'd pay to see this one!
  24. 5150merc
    5150merc
    it makes a great replacement for chewing gum too.
  25. Boyd Who
    Boyd Who
    It tastes better if'n you have a filling or two. :D
  26. Yutan Flash
    Yutan Flash
    from Gretna, NE
    "Period Correct use of tin foil is to cut strips and put in your Hub Caps--the urban legend was, it would confuse radar guns"
    Sure, if you dropped 10,000+ of them from the bomb bay of a Lancaster, B-17 or B-24 at 15,000 feet (ask my old pastor, who was a 16-year old Luftwaffe flak helper/aimer in 1945)
  27. 61TBird
    61TBird
    It also keeps "them" from reading your thoughts....
  28. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Spray glue on those boring stamped valve covers, add aluminum foil, and you got it........... Insta-Billet!
  29. rottenrod
    rottenrod
    insta-billet sounds like it should be one of those late night info-mercials
  30. And as an extra bonus- for FREE... Insta-Stench!!!
