Technical Tech Week; control cable repair
Discussion in 'The Hokey Ass Message Board' started by Pist-n-Broke, May 13, 2021.
  1. How often do you need new Heat/Air control cables that fit exact and have that dang Rolled eye that slips over that push/pull arm. You can't buy exactly what you need and now your stalled. This might help ya move on.
    You must roll your own Eye, this is how I've done it many times.
    It's just another home made tool being ya can't just go buy one. Mine started life as just a standard #5 3/8" bolt. I cut it short and drilled a hole the shaft will fit in just a little loose off center on purpose.
    With a 3" cutoff disc I left a piece on the edge and cut a kurf in it so it would hold the cable liner snug against the lever. It actually holds onto the cable, not open on the bottom.
    20210510_173837.jpg Next is to make sure your lever is at full travel and you can hold it there while winding the Eye. Put a hand wrench on the bolt head and turn a full rotation. You now have your first loop.
    Next you want the eye to stack tight so you press down on the bolt head with your Thumb and make 2 more full loops.
    At this point you should be looking pretty good and on the last loop you only go 3/4 turn and cut off the remainder of the wire. Turn the tool the rest of the way till it runs off the end of the wire. 20210510_174248.jpg
    In the end you should have something that looks like this. You may want to practice a couple times with the broken cable before trying for a Home Run with the new cables.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. Rocky
    Rocky
    Classified Editor
  4. Baumi
    Baumi
    I‘m gonna steal that idea! Great!
  5. cretin
    cretin
    That's fantastic, simple, useful tech. Love it.
  6. Nominal
    Nominal
    That's the sort of tech week tip I like!
  7. loudbang
    Good idea and so simple. :)
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
  9. Johnny99
    Johnny99
  10. trollst
    trollst
    Well, aren't you just the smartest guy I've read this morning, nice work, something, I'd never thought of.....
  11. Slick little tool
  12. 6sally6
    6sally6
    Sweeet....and no heat involved??! Nice
    6sally6
  13. guthriesmith
    guthriesmith
    Very cool! Thanks for sharing! I will have to remember this.
  14. goldmountain
    goldmountain
    Now that is pretty slick, but actually there is a tool made for this job. Mine says K-D No. 495. It consists of special pliers that holds the wire and has a small metal post. There is a "T" shaped socket with a tang - much like Pist n Broke's bolt that does the wrap around the post. You are very clever.
  15. partssaloon
    partssaloon
    The KD tool was great, but like most stuff it has been discontinued
  16. y'sguy
    y'sguy
    from Tulsa, OK
    Perfect idea, I've got to try it.
  17. Unique Rustorations
    Unique Rustorations
    Yep. Neat. Nice work! Regards, Randy
    loudbang, VANDENPLAS and Pist-n-Broke like this.
  18. BamaMav
    BamaMav
    from Berry, AL
    Have that to do on mine, was wondering how to go about it. Now I know! Thanks!
  19. evintho
    evintho
    That's genius! Never even crossed my mind. I like everything about it. Homemade, cheap, simple, fast and does the job perfectly! What's not to like? Great job P&B! Kudos!
  20. This is what this place is about.... Fabulous!!!
  21. Doublepumper
    Doublepumper
    from OR-WA, USA
    Great idea!
    This is a K-D 495 tool for those that haven't seen one:
  22. I have that KD tool (KD #495) And use it regularly. Before I had the correct tool I often resorted to doing something much like Pist-n-Broke has shown us. I still have a couple of tools I made to do that job.
  23. flatheadpete
    flatheadpete
    from Burton, MI
  24. That is a nice tool. Glad to see someone took my idea and improved on it,,, sorta. To bad we can't just go out and buy one.
  25. bchctybob
    bchctybob
    Another priceless pearl of wisdom from the Wiz.... thanks PnB!
  26. 32 hudson
    32 hudson
    That is a cool idea and solution. Thanks for the sharing.
  27. Brand Apart
    Brand Apart
    from Roswell GA
    Super slick. I've only had need for this once but I have a few projects in early stages and I believe this will come in handy. I bet a wing nut socket would work for this as well, I'll give it a try since I already own some, but if not I'll be cutting a bolt and copying this for sure!
  28. Back to the Top just because it may help others.
  29. y'sguy
    y'sguy
    from Tulsa, OK
    Thanks for the reminder.
    Tow Truck Tom likes this.
  30. DDDenny
    Here's a "now that I'm warm, what's for breakfast bump".:D
    Why are the simplest solutions so evasive, me thinks it's because we get so involved with the big parts of projects that we have used up our creativity ( or energy) for the little things, I turned 70 recently and it seems the small stuff takes me forever to do.
    Keep them coming P&B.
