Tech Week.... Drilled, Dropped Axle How to
Discussion in 'The Hokey Ass Message Board' started by OoltewahSpeedShop, Mar 3, 2012.
  1. killbilly
    killbilly
    Kevin,glad to see you and yours are ok,great tech,I have used that drill for years ,drilling truck frames for wheelbase changes.You have to be very careful not to de-magnetize them,they sure aint cheap!
  2. ago
    ago
    from pgh. pa.
    You don't need the magnetic drill press. The Hougen rotabroach bits really work well for doing this type of work. you can use them in a drill press, milling machine etc. The size you need for this job have a 3/4" straight short shank with a flat for a set screw. From my experience you wont be disappointed using these bits.
    Ago
  3. OoltewahSpeedShop
    OoltewahSpeedShop
    Try flipping the magnet switch when it's overhead.... That'll get your attention. Thanks for the thoughts.
  4. atch
    atch
    so very cool. at the risk of derailing the excellent post, what would be the best bit or hole saw to do the same thing on an old fashioned drill press. i've got a couple of good ones (cast iron head drill presses) and will never be able to buy, beg, borrow, or steal a mag drill.
    edit:
    ok, while i was typing ago posted.
    any concurrences or other suggestions?
    also, how fast/slow do you need to turn the bit?
  5. bobscogin
    bobscogin
    You probably never will. Forging of medium carbon percentage parts is done at red hot plus temperatures and the part air cooled. No quenching or rapid cooling. Any stress would be relieved during that process.
    Bob
  6. OoltewahSpeedShop
    OoltewahSpeedShop
    Greenlee has a really cool and VERY precise holesaw kit. Pretty pricey compared to regular holesaws, but no comparison in the quality. The only other problem is.... They are pretty shallow. Not sure they would drill all the way through an aftermarket type axle, stock axle would be fine.
    The Mag drill runs at 350 RPMs.
  7. Blue One
    Blue One
    from Alberta
    I did this twice actually in my build thread. Once on a cast Magnum dropped axle that I decided not to use, then again on the Forged SO-Cal axle I bought to replace it. :)
    I bought my mag based drill on e-bay, its a cheap one but it works very good and takes the same annular cutters that the more expensive mag drills take.
    For lube and cooling I used the white water soluable cutting oil you see in the spray bottle on the table.
    My axle is a 46" one so less holes. The holes are also 1 1/8".
    http://www.jalopyjournal.com/forum/showthread.php?t=460009&highlight=26&showall=1
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    One trick I learned on a forum a while back is to replace the drill bit in a hole saw arbor with some 1/4 inch drill rod (if you can't find drill rod a long 1/4 inch grade 8 bolt with the threads and head cut off works too) First you drill a 1/4 inch pilot hole and insert the drill rod on the holesaw and start cutting as usual. A drill bit will want to wallow out the pilot hole on long cuts but the drill rod spins smoothly and accurately in the hole, making the holesaw hole cleaner.
    Cutting oil helps too, much better than engine oil, WD 40, etc. I've been using Lennox and Ridgid brand holesaws and they seem to hold up well considering they are Home Depot and Lowes stuff.
    Don
  9. OoltewahSpeedShop
    OoltewahSpeedShop
    It would probably burn them up, just wanted to mention the best holesaw I've ever used. Not designed for this though. At $250 a set I'd probably stick to sheet metal with them.
  10. The37Kid
    The37Kid
    Thanks! It is always nice to see what can be done with a tool most of us have never seen before. Is there a pilot drill inside the hole saw that allows you to center the holes?
  11. OoltewahSpeedShop
    OoltewahSpeedShop
    It's not a pilot bit, but a spring loaded line up pin that ejects the slug after drilling through the metal. The drill is fairly common in the structural steel and electrical fields. I bought one of mine at a pawn shop....
  12. beater32
    beater32
    I used a Step Drill with a 7/8 drill as it's final cut and drilled right through. Worked perfect.
  13. The37Kid
    The37Kid
    What a great Tech Week tip, even the follow up questions get photos!:)Bob
  14. OoltewahSpeedShop
    OoltewahSpeedShop
    That's just how I roll..... ;)
  15. Looks good Punkin'! Nice job. ;)
  16. OoltewahSpeedShop
    OoltewahSpeedShop
    Ahh... Thanks alot Spoke Straightner. :D
  17. OoltewahSpeedShop
    OoltewahSpeedShop
    Thanks bro....
  18. Johnny Cash
    Johnny Cash
    What is a step drill?
  19. OoltewahSpeedShop
    OoltewahSpeedShop
    We call them Uni-Bit's but here it is.... You can get them in alot of sizes but the most common are 1/2", 3/4" and 1" conduit sizes.
      15.6 KB
  20. Kevin,
    Ad to your list maintence machinists to drill or bore pieces that are too large to get back to the shop or set up in the mill. :)
    Very good piece of tech for sure.
    My question is do you intend to champher the holes? I know pretty hard to find a counter sink that large. :D
    I have alwasy felt that they looked more finished champhered, personal taste I suppose.
    I will tell you one thing it sure beats using a Black and Decker 1/2" Mechanics drill with a 135 lb long haired germ attached ot it.
  21. OoltewahSpeedShop
    OoltewahSpeedShop
    I did chamfer the holes with a cone shaped sanding tool. Both sides.
  22. Cool,
    I have a friend that is a tool and die man that has a 30 degree chamfer bit he made that we used or use for that. The cone shaped sanding tool is a more likely tool to find in someone's tool box.
    I have alwasy hated to see an axle just drilled and sharp around the holes. I have even seen them drilled and not debured at otherwise nice cars. :eek:
    Something that someone that has not worked in a decent machine shop doesn't normally know is that a piece of work not deburred is not a finished piece. it is sure nice to be around fellas that know the difference.
    Very nice looking axle by the way.
  23. OoltewahSpeedShop
    OoltewahSpeedShop
    I'm a de-burr fanatic.... I de-burr stuff that didn't have a burr... My guys say that I'm **** about it.
    I say "If that's so, I don't want a burr in my ***"
    Right?
  24. Nethery
    Nethery
    from Palm Coast
    Do you still use the inside beveled tool?
  25. OoltewahSpeedShop
    OoltewahSpeedShop
    Of co****.... Your uncle RG perfected that tool.
    Not many people have seen this one (unless you hang around my garage). It's a reversed cone to de-burr the back side of whatever you drill.
    I know..... Crazy right?
  26. rancid737
    rancid737
    I was thinking the same thing.
  27. OoltewahSpeedShop
    OoltewahSpeedShop
    Really....? We are 4 pages into this thing now and still in confusion.
    My post said NOTHING about dropping an axle. I guess you can't please everybody.
  28. hotrod40coupe
    hotrod40coupe
    Great tech. The only problem I see is the cost, about half what I paid for my car.
  29. killa fab
    killa fab
    I was thinking about drilling my axle using a drill press and holesaws. Now that i see the webbing is 1/2" thick or so, i'm deciding against it. I already have too much time in drilling holes in my frame! I cant imagine how long it would take to drill through 1/2" steel.
  30. OoltewahSpeedShop
    OoltewahSpeedShop
    The 1/2" thick web is only on the So-Cal axle. Stock Ford axles are about 1/8" or so....
