Art & Inspiration Tech Week Emboss your valve cover
Discussion in 'The Hokey Ass Message Board' started by Rich B., Oct 13, 2015.
  1. Rich B.
    Rich B.
    from Portage,IN
    A friend here on the HAMB (scotty t) sent me a link to a post on embossing that
    gave him the idea to to press Plymouth into his valve covers. He knew I did this kind
    of thing, and asked if I would give him a hand. Well hell yes! Here's a link to that post:
    http://www.hotrodders.com/forum/how-emboss-lettering-into-sheet-metal-207719.html
    It's a great post with good info, and I have done this in the past. With the 18 gauge we
    are using I like to use a female pattern, and use the polyurathane as the male die. Either way will work, I'm used to doing it this way. I'm just an amatuer, and learn something new on every project. Enough yakking let's get started.
    The pic below shows the pattern marked out on the valve cover. Below the valve cover
    is the 16 gauge pattern taped to a piece of 18 gauge to use a test piece.
  2. Rich B.
    Rich B.
    from Portage,IN
    HOTRODPRIMER likes this.
  3. Rich B.
    Rich B.
    from Portage,IN
    Trying to post more than one pic is a problem.
    Here's another pic showing the above pattern, and blank turned over with
    the polyurathane on top. I like to press the area with the small pieces taped
    to them first. The P, and O require them to finish the letter shape. Doing
    them first locks them in so they won't shift while pressing. Than work
    back ,and forth over each letter to finish.
    D-Russ, HOTRODPRIMER and volvobrynk like this.
  4. Rich B.
    Rich B.
    from Portage,IN
    In the next pic I have moved the ***embly over to my work bench, and am
    chasing the letters with a home made corking tool for better definition. I like
    to clamp either side of the letter I'm working on to prevent possible distortion
    of the surrounding metal. This is only the test piece, but I treat it like
    the finished valve cover.
  5. Rich B.
    Rich B.
    from Portage,IN
    Just to be clear the pic in the last post has the pattern under the test piece. It will
    stick to the pressed piece, and you will have to pry it off when finished. The pattern
    beneath the piece will keep chasing toll in place as you work it. Size the tool tip
    to just fit the pattern width of a letter. The tool is just an old chisel with a small piece
    welded to it that I flappered smooth when shaping it.
    D-Russ and HOTRODPRIMER like this.
  6. Rich B.
    Rich B.
    from Portage,IN
    Here's the finished test piece. Doing the test piece will give you a feel for the amount
    of pressing , and chasing needed.
    sko_ford, D-Russ and kiwijeff like this.
  7. Rich B.
    Rich B.
    from Portage,IN
    Ready to press the valve cover. I centered the pattern, and taped it to the cover. The small pieces
    of tape on P, and O are all that is needed. If 2 layers are used it will imprint the valve cover.
    The pattern should have all edges rounded or you are libel to get an edge mark imprinted
    in the valve cover!
    1
    -Brent-, D-Russ and volvobrynk like this.
  8. deto
    deto
  9. Rich B.
    Rich B.
    from Portage,IN
    Here's how I had to set up to press the odd shaped valve cover. Notice the apron
  10. Rich B.
    Rich B.
    from Portage,IN
    This view shows the urathane with a heavy backup piece of steel used to
    press with. I have a 50 ton press with air ***it that I added to it which makes
    repeated pressings much easier. I mounted the floor treadle on the side of the press
  11. Rich B.
    Rich B.
    from Portage,IN
    Here I have moved the valve cover to the work bench, and am chasing the
    letters. I have just finished the T, and am ready to cover it, and start on the U.
  12. Rich B.
    Rich B.
    from Portage,IN
    This close up of the letters are on the test piece.
  13. Rich B.
    Rich B.
    from Portage,IN
    Here's the finished valve cover.
  14. Rich B.
    Rich B.
    from Portage,IN
    I of course stole Scotty's idea since we both have the same valve covers. Mine is
    a Dodge truck Hemi . This pic shows the finished test piece, the pattern, and
    the polyurathane that we used. That's McMaster Carr's stock number.
    I made both patterns with my milling machine . I machined common block
    letters in them, and than used a small air file to square the corners of some of
    the letters as was needed. They could be plasma cut, water jetted. In the past
    I have made patterns by drilling, cutting with small air saw, and lots of filing!
    D-Russ, kiwijeff and volvobrynk like this.
  15. Rich B.
    Rich B.
    from Portage,IN
    Here's a close up of mine after light bead blasting. I was able to make mine slightly
    larger as there are fewer letters.
  16. Rich B.
    Rich B.
    from Portage,IN
    This pic shows the pieces to back up, and press the covers. I surfaced one of
    the apron pieces in my mill, and also the cover piece. Care here will make a
    big difference in the finished piece.
    kidcampbell71, D-Russ and volvobrynk like this.
  17. Rich B.
    Rich B.
    from Portage,IN
    Here's the finished piece with a coat of etch prime. I hope this helps some one
    with their project. If I get time I'll try to add some pics on how I press with
    steel male, and female patterns.
    Rich
  18. Martin Harris
    Martin Harris
    Looks cl***y. great idea.:)
    volvobrynk likes this.
  19. gnichols
    gnichols
    from Tampa, FL
    Insane, and very nice. Man, I wouldn't even think of trying something like that myself, just one slip and you're looking for another valve cover. Well done. Gary
  20. 56premiere
    56premiere
    Very nice , I try this sometimes and have varied results. I usually am just playing with ideas.
  21. Nice work, endless possibilities.
  22. HOTRODPRIMER
    HOTRODPRIMER
    Another excellent tech with thinking outside the box and the results speak for itself and would rival anything offered by the manufacture. HRP
  23. Rich B.
    Rich B.
    from Portage,IN
    Thank's so much for the kind words guys! I've made my
    share of s**** metal in my time also! LOL
    Rich
  24. awesome work! thanks for sharing
  25. Hnstray
    Hnstray
    from Quincy, IL
    Sometimes I am more slow witted than others:confused:.....this is one of those times.:(
    I looked at the linked thread and carefully studied your photos and remain a bit confused.
    In the linked thread, individual 'male' letters were used to press into the workpiece, but I did not see a 'female' die, unless it is the urethane. It appears to me that your method employed a 'female' die and no 'male' die, but you also used urethane.
    What am I missing here? Would you be so kind as to explain the "sandwich" in detail?
    Thank you for a great thread!
    Ray
    fstfish66 likes this.
  26. Rich B.
    Rich B.
    from Portage,IN
    It can be confusing! The linked thread uses individual male letters, with the
    urathane acting as the female die. I find when using heavier gauge I have
    better luck reversing the process. I use a female pattern with the urathane
    acting as the male die.
    The female pattern is placed on the outside of the valve cover instead of individual
    letters inside the valve cover. I place the urathane inside, and cover it with a
    piece of steel. I than press the the cover piece, which forces the urathane into
    the face of the valve cover forming the letters. I had hoped showing both
    methods would give options, but may have confused the issue. I had wanted to
    give credit to the other poster.
    Rich
  27. MP&C
    MP&C
    Nice job Rich!
  28. falcongeorge
    falcongeorge
    from BC
    That's pretty cool.
  29. Bugguts
    Bugguts
    That is nice. I think it's probably harder than you make it look, but it looks very cool. Thanks for more personalized ideas.
  30. there goes my thread on the "mystery" plymouth hemi i found in the junkyard! Rich B is quite the craftsman and a nice guy to boot. THANKS RICH!
