*Tech Week* Few bead roller ideas
Discussion in 'The Hokey Ass Message Board' started by Carb-Otto, Mar 10, 2012.
  1. Hellfish
    Hellfish
    Great tech! How long do those nylon dies last before you need to cut a new pair?
  2. I_be_moose
    I_be_moose
    What process do you use to cut the profile for the cutting edge? From the pictures it appears that there is a tapered edge to them. Isa that correct or just the angle of the picture?
    moose
  3. Uncle Jess
    Uncle Jess
    from Western Ny
    Yes Sir that is using your mind, I like the idea thanks. Good work.
  4. Carb-Otto
    Carb-Otto
    from FINkLAND
    Long enough to make beads for pick-up body... ;) Sharp edges will wear out quite quickly.
  5. Hellfish
    Hellfish
    That's what I thought... but they look cheap enough to make multiple copies as needed. Great idea.
  6. Inland empire hot rods
    from so cal
  7. loudpedal
    loudpedal
    from SLC Utah
    Ya know, every once in a while you run across something that let's you know that your are doing it the hard way. This is one of those times. The way your dies are made is so simple ...why didn't I think of that? You have just made my life easier. There is a bunch of stiff compe***ion this time around. This one get's my vote, hands down.
  8. Well said, and I could not agree more.
  9. continentaljohn
    continentaljohn
    Very cool and great idea , they are many grade of nylon delron and hardness as well. You get my vote and will be using this idea soon
  10. mashed
    mashed
    from 4077th
  11. lincolnhead
    lincolnhead
    from Marysville
    im going to my buddies house this weekend and im gonna give this a whirl! kuddo's on the extra support of the offshore rollers.
  12. nickk
    nickk
    awesome idea, gonna try this for sure
  13. Dyce
    Dyce
    That's a neat way to cut the dies!! Did you have a sharp edge on the profile peice you used to cut with? That plastic can be hard to hold, I would think it would chatter like crazy!! What kind of speed did you use when you made the cut?
    Edit: I see the edge now in the side shot. I have to try this now:)
  14. Carb-Otto
    Carb-Otto
    from FINkLAND
    Can't remember... it's been a while since I made these. Nylon rod tends to melt, so take your time and cool it off with air and/or water rag.
    When you are almost done with your new nylon die, let it cool off totally.
    You'll want to work with cooled nylon last few millimeters to get more accurate surface. Pockmark or notch on your tool will affect the bead...
  15. Finnrodder
    Finnrodder
    from Finland
    Thats a neat idea with the dies.
    Have you any idea where that steering wheel is from on your bead roller?
    I have pretty much similar operating wheel on my roller,i dont have clue where its from.
    Some old truck or bus maybe...
  16. mika112
    mika112
  17. johnny bondo
    johnny bondo
    from illinois
    awesome never really thought of using plastic
