Technical TECH WEEK - Ford Spoon Throttle Pedal Update
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Jul 26, 2017.
  1. the-rodster
    the-rodster
    I don't know what it is about a Ford throttle pedal, it just seems like the perfect blend
    of art deco form and function. Why anyone would pull one out to use something else
    is beyond me.
    They do pose a small problem for later engine installations, since the rod is on the wrong
    side most later carburetors.
    We can fix that, and make it look like Henry designed it that way.
    Stock ***embly
    Removed
    117harv, brad2v and chryslerfan55 like this.
  2. the-rodster
    the-rodster
    Transfer the angle of the rod in relation to the pedal to some cardboard.
  3. the-rodster
    the-rodster
    Drive the pin out of the pedal ***embly that attaches it to the cross-shaft
  4. the-rodster
    the-rodster
    Now reverse the cross-shaft and lever, making it come up on the right side.
    LOU WELLS, brad2v and chryslerfan55 like this.
  5. the-rodster
    the-rodster
    Position the pedal, using the diagram, to the same angle as before, and mark.
  6. the-rodster
    the-rodster
    Drill it, and pin it.
  7. the-rodster
    the-rodster
    Modify the hold down bracket so that the cross shaft can come all the way through.
    brad2v, TagMan and chryslerfan55 like this.
  8. the-rodster
    the-rodster
    Slowly bend the spring so that the end holding the arm faces the other direction.
    brad2v likes this.
  9. the-rodster
    the-rodster
    Re***emble.
    Tim, LOU WELLS and brad2v like this.
  10. the-rodster
    the-rodster
    I made a small tab to hold the end of the spring, that is held on with the stock upper screw.
    brEad and brad2v like this.
  11. the-rodster
    the-rodster
    Done!
    And it works as smoothly as the original.
    loudbang and brad2v like this.
  12. Bruce Lancaster
    Bruce Lancaster
    Cool, and fully thought through for simplicity, proper appearance, and function!
    A minor note...Ford throttle ***emblies '32-48 all, as far as I know, have the same size rod as the mainshaft...this means that any of them can be spliced into whatever s**** you have. V8 ones come in more than one length, and the various 4 and 6 cylinder ones give some extra variants. '32-4 use the dual purpose stamped hold-down support shown, others generally have two of the eye bolts like the single one on '32's. There's no reason or excuse for putting in a cable...
    HemiDeuce, AHotRod, Frankie47 and 3 others like this.
  13. Awesome work! Something I hadn't even considered when planning out mine.
  14. bct
    bct
    You got my vote
  15. gdaddy
    gdaddy
    from nw fl.
    what does a stock aussie or brit car gas linkage look like ?
  16. flatoz
    flatoz
    I haven't taken a photo of it as such but you can see it on my roadster here, this is the best photo I could find right now. both 4 and V8 used the same pedal ***embly.
    Texas Webb and 1927graham like this.
  17. gdaddy
    gdaddy
    from nw fl.
    thanks , that is a nice looking ride , love the flattie
  18. wingedexpress
    wingedexpress
    Cool, im going to try this on my 34
  19. My approach was slightly different. I removed the '32 pedal from the horizontal shaft. I used a piece of round stock and started bending. The right end incorporates the original throttle return spring. The firewall bracket was replaced with a new one made from square tubing. The left end extended out to line up with my throttle. Note that the engine is a 4 cylinder and the throttle is farther to the left than a regular V8.
    Charlie Stephens
    Tim likes this.
  20. Bruce Lancaster
    Bruce Lancaster
    Any of you Antipodeans, Britons, or Canadians have a decent picture of throttle linkage on a WWII CMP type truck?
    Especially the under hood part.
  21. the-rodster
    the-rodster
    Thanks Bruce,
    That means a lot coming from you.
    Rich
    bchrismer likes this.
  22. flatoz
    flatoz
    to the OP, great job! I made a V8 ***embly out of a B model one and it works well.
    Wondering if a new thread should be started on what pedal ***emblies look like so as not to draw away from the rodsters great work.
  23. MrNailhead
    MrNailhead
  24. 52lomofo
    52lomofo
    Looks like one on 48-52 ford truck too
  25. Bruce Lancaster
    Bruce Lancaster
    Remember the the s****s were used with a mushroom footrest beside the pedal...having only the pedal forces your foot to pretty much support itself in position. Foot goes solidly on the footrest for stability and comfort, and then a slight roll of the foot sets your pedal use. Just a s**** hanging in the air would be uncomfortable in a hurry. Stolen picture:
    bct likes this.
  26. timwhit
    timwhit
  27. Bruce Lancaster
    Bruce Lancaster
    Can't fool me...I know a spatula when I see it!
    flatford39, Tim and charleyw like this.
  28. bchrismer
    bchrismer
    Rich,
    GREAT MOD!
    My bro-in-law did a similar mod to the throttle pedal on his '40 truck, but we haven't gotten it together far enough to see how it is going to work on his '40.
    I did mine backwards, on my '40 stake truck, slightly tweaking the arm to clear the distributor, and attaching to the kickdown hole on the carb. (Using a manual transmission, so there is no need for a kickdown for me.) Also, once I have the fundage to rebuild my bored and stroked flatty, I won't have to find another stock throttle linkage when I swap it in place of the 283.
    Doug's truck will be using a 350TH transmission, so keeping his on the driver's side will help with dealing with the kickdown cable.
  29. IronFord
    IronFord
    from NoDak
    I know this is an old post but can anyone tell me what size the pin is that runs through the pedal ***embly and cross-shaft shaft?
    EDIT: the pin is slightly larger then an 1/8 in diameter.
