Technical Tech Week - Halibrand/Winters Quickchange
Discussion in 'The Hokey Ass Message Board' started by GearheadsQCE, Oct 4, 2015.
  1. continentaljohn
    continentaljohn
    Thank you what year was this made? The pinion nose or support bearing OD is 2.045 and shaft OD on the housing is 3.122 or that's my telescopic gauge reading and don't have a inside micrometer that can reach it. A few more pics
    Deuces and kidcampbell71 like this.
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Looks like that is a ball bearing case.
  3. continentaljohn
    continentaljohn
    Cool do you know the reason to make both? Or is one early production and one later? Thank you for all the help John
  4. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The ball bearing case came first. Halibrand later offered a O.D. ground tapered roller bearing race. In 1985 they started boring the cases for the standard roller race.
    I believe the original thought was to reduce bearing drag by using the ball bearings.
  5. louisb
    louisb
    Posts like these are one of the main reasons I hang out here. Veddy cool.
    --louis
  6. von Dyck
    von Dyck
    Always good to hear from the guru of quickchanges from Davisburg! :D
  7. gmgrunt
    gmgrunt
    would be interested in a set of your proposed side plates if you get the number of orders.
  8. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    We are up to 30 Plates now. Need to order 40, minimum.
  9. HotRod-1
    HotRod-1
    Are you still taking orders for side plates? My center section is a Halibrand 12 bolt.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes, I have 12 bolt plates. I am out of 11s right now. I may not make more depending on the price of the castings.
    I'll send you a private conversation.
  11. Frames
    Frames
    I quit building champ QC'c at least 8 years ago. I found there was so little demand. I guess you do OK. A friend has a Halibrand 12 bolt magnesium bare case. He asked me to look out for a pair of side plates. What's the best you could do shipped to 28027?
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Dennis,
    Check your 'Conversations'
