**Tech week Jan. 11 to Jan. 18 '10 Threads.**
Discussion in 'The Hokey Ass Message Board' started by zman, Jan 11, 2010.
  1. zman
    zman
    from Garner, NC
    Lets keep track of the Tech threads for the week here. Just post a link to the thread in here and I'll add it to the list...
    Technical Remove a pilot bushing the easy way
    Tech! Floor patches without special tools!
    Technical Shift Knob Adapter
    Technical 55 Chevy to Closed Drive Ford Transmission Conversion
    Tech week- Model A simple tricks to update your car
    Tech: Re-gauging the stock housing
    **TECH WEEK** Install soft top on Model A sedan and custom rain gutters
    Tech. - Fender Skirts for a '35 Ford Tudor
    Ch***is swaps! Modern frames under vintage tin!
    Simple & effective engine mounts
    Tech: Exhaust fabrication tips
    Technical Tech - Gauge Face Customization/Restoration
    Technical *Tech Week* Rear Spring Tools
    TECH: Salvaging ****PY E&J Repop HEADLIGHTS....or...Polishing TURDS
    Tech: Cheap replacement T5 Shifter
    Body Lifting Brackets (31 Coupe)
    Shorter shocks for a Falcon on the Cheap and Easy!
    Wood dashboard for the roadster
    Cheap n easy lake header baffles
    TECH WEEK: My lake header mufflers.
    Technical Build your own Disk Sander
    TECH WEEK:Bendix brake conversion for Ford backing plates
    Juiced 36 backing plates
    ***how to widen a wheel*** PART 1
    TECH!!!! Rebuild Your Rochester For *****s (Like Me)
    TECH - My take on 33-34 hydraulic brake pedals
    TECH: What to do with OEM SBC center bolt valve covers
    straight tap in tube starter for Tech week
    Heater Motor Lubrication:
    Woodie Tech: Applying veneer to curved steel panels
    *Tech Week* D/A Sander Aluminum Wheel Re-Finishing
    Tech Week:Rear Model A Crossmember in a 34 Ford frame
    Tech Week: Another way to clean parts.
    Tired Ole Flathead Head gets put to good use...
    Back Gl*** Install....'49-54 Chevy, Shoebox, Etc.
    The making of a Hot Rod Clock
    *Tech* Useful Uses for Hole Saw Donuts
  2. zman
    zman
    from Garner, NC
    and we are a go with the first one...
  3. 3wLarry
    3wLarry
    from Owasso, Ok
  4. hotrodjeep
    hotrodjeep
  5. K13
    K13
  6. Little Wing
    Little Wing
    from Northeast
  7. zman
    zman
    from Garner, NC
  8. Chris
    Chris
  9. jakesbackyard
    jakesbackyard
    from ND
  10. Crusty Nut
    Crusty Nut
  11. Almost every link I open in this thread, I have to scroll back and forth to see the pictures. Is it just me, is there some setting on my computer I can change?
  12. rjgideon
    rjgideon
    It's not just you. Folks aren't resizing their pictures when they upload them to their picture sharing sites. I usually go for 800x600 just to prevent that from happening.
  13. Slonaker
    Slonaker
    The people writing the posts need to resize their photos a little smaller. About 800X600 would be really nice. It would prevent the problems you are having for most readers.
    Slonaker
    EDIT: It looks like I need to type faster. :)
  14. freebird101
    freebird101
  15. SimonSez
    SimonSez
  16. the-rodster
    the-rodster
  17. Mark H
    Mark H
    from Scotland
  18. KIRK!
    KIRK!
    Wow, you got mine up quick! Thanks.
  19. zman
    zman
    from Garner, NC
    It's because I'm internet stalking you.
  20. t-rod
    t-rod
  21. skwurl
    skwurl
  22. Kramer
    Kramer
  23. kansasplowboy
    kansasplowboy
    from SW Kansas
  24. Slim Pickens
    Slim Pickens
    Thanks ALL, Never read so much. Slim
  25. hot rod pro
    hot rod pro
    from spring tx.
  26. Dan Hay
    Dan Hay
    Thanks for this thread, saves time wading through alot of ****pola on the main board.
  27. oz40
    oz40
  28. flat34pu
    flat34pu
    :D this is a great week.
