Tech Week - Old Skool Jack Stands
Discussion in 'The Hokey Ass Message Board' started by Bib Overalls, Mar 1, 2012.
  1. There was a time in America when every mechanic's garage had a set or two of jack stands made out of old "banjo" axle tubes. Most were simple torch jobs. Some with a rounded notch and others with a "V". Most are gone now. Victims of s**** drives, OSHA, and cheap, adjustable Chinese imports.
    While they may be gone in the commercial world a set looks "right" in a traditional hot rodder's garage and they are really useful. I have three pair.
    In this Tech Week submission I am going to show you how I make mine using tools that you most likely have access too. My technique is simple, accurate and repeatable. This means you can make one set today and another next week and both will have the same height.
    Any Ford "banjo" axle tube from 1928 to 1948 will work. I'm not suggesting you go out and tear up a "Primo" rear end. But axle tubes, for one reason or another, are frequently discarded as s****. In this case, I am using 1946 Lincoln bells. They look like Fords but there is almost no demand for them. Perfect jack stand material.
    The first thing you have to decide is "how tall". I am making these 14". Just right for a rear axle with a 30" tire.
    Start by cutting the axle bell a couple of inches longer than your desired height. This can be a rough cut and even be on a bit of an angle.
    With the axle cut to rough length secure it to a work surface, like the WorkMate I am using, put on your safety gl***es, pick up your angle grinder, and remove the lip around the sealing surface. This will improve the stability of you jack stand.
    Jack Stand 1 by Bib Overalls, on Flickr
    Jack Stand 2 by Bib Overalls, on Flickr
    The next step requires a drill press and a mandrel with a cut off disc. I got mine at Harbor Freight for less than five bucks.
    Jack Stand 3 by Bib Overalls, on Flickr
    Chuck the arbor and cut off wheel into your drill press and set the belts for the highest speed. Level the table and set it so the cut off wheel contacts the axle tube at the desired height less the thickness of your top cap.
    Jack Stand 4 by Bib Overalls, on Flickr
    With your safety gl***es on, turn on the drill press and start cutting. Rotate the axle tube into the the cutting disc using light pressure. It will thake several rotations to make a clean cut.
    Jack Stand 5 by Bib Overalls, on Flickr
    Jack Stand 6 by Bib Overalls, on Flickr
    Finish the jack stand by welding on a square of "C" channel. 4" works good on tall stands. Because of the short height of these stands I used 5" and narrowed it to 4.5". I like the wider width because I can lay 2"x 4" and 4" x 4" nominal lumber across two stands to form a bridge. Useful in some fabrication situations.
    Jack Stand 7 by Bib Overalls, on Flickr
    Paint or leave naked, whatever looks right to you.
    Miller time.
  2. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Nice! I always wanted a set of those...but I would have to have mine CHromed :D
  3. TexasSpeed
    TexasSpeed
    from Texas
    Thanks! I had been wondering about how to make mine but wasn't sure how to make them both identical.
  4. KWashburn
    KWashburn
    We're starting off Tech Week with a bang. Excellent write up.
  5. fifTsix
    fifTsix
    from TEXAS
    Good stuff Thanks!
  6. william.ali.kay
    william.ali.kay
    from Milwaukee
    Very cool info here.
  7. cederholm
    cederholm
  8. Noland
    Noland
    cool. real good Idea with the drill press. Like JJ said it would be awesome to have a chrome set.
  9. Good tech story! I have got to get a set - they just look the part! I remember seeing them all the time....
  10. slobroy
    slobroy
    Chrome would be nice, but to costly for me.
  11. garcoal
    garcoal
    sorry i will stick with my store bought set. adjustable height and wider base. still nice work
  12. D-man313
    D-man313
    Nice work. Dont let your wife see that last picture.:eek: Unless you have a kitchen counter and family room furniture in your shop.
  13. While I like adjustable jack stands, I thought the drill press idea was pure genius. Well done!
  14. The37Kid
    The37Kid
    Nice! For the Historical Record early Model T rear axles were cut down for milking stools on farms. The 1909-14's used to turn up at Hershey many years ago, I'm sure they are under todays show cars.
  15. rancid737
    rancid737
    cut-off wheel in a drill press? why have i never thought of that?
  16. redroaddog
    redroaddog
    nice!!!! i use my drill press like a lathe making small stuff but never to cut! a cool idea!!! thanks:cool:
  17. Lowrders
    Lowrders
    from DUBUQUE IA
    Agree'd! awesome info!
  18. Sweepspear
    Sweepspear
    Maybe he was going to run them through a dishwasher cycle. :D
    The drill press trick is genius.
  19. Ha, I just finished up a pair Friday. Mine are not as fancy I am afraid. my first jackstands were model A axle bells.
    Good tech
  20. falcongeorge
    falcongeorge
    from BC
    Yea baby!!
  21. flatheadpete
    flatheadpete
    from Burton, MI
    Cheap and easy. Just what most of us are looking for!
  22. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    very nice! i have a tall pair and a short pair of these
  23. bobss396
    bobss396
    ... and one will always be more identical than the other.
    Bob
  24. matthew mcglothin
    matthew mcglothin
    Very awesome tech! X15 on the cut off wheel idea. Just started cleaning my old jacks just yesterday using electrolysis.. Big difference! I guess there old house jacks(don't worry not using them on my car just cleaning for looks). Nothing like the old USA made stuff.
  25. Steel A Rod
    Steel A Rod
    Always wanted a set. Drill press idea is awsome. Thanks for the great info!
  26. pasadenahotrod
    pasadenahotrod
    from Texas
    Even Model T rearend housings can be used cut for a taller set of stands to hold a rearend or front axle.
    Old time tech is great. Don't forget you can use an early Ford driveshaft for a digging bar and the longer torque tubes make good uprights for clothes line poles. Like a pig every piece can be used except the "oink"/honk.
  27. Hubcaps in the dishwasher are also a sore spot in my digs!
    Dang I woulda never thought of the drill press/cutter idea ... the applications are endless!
  28. Speedy Canuck
    Speedy Canuck
    Man, that's great tech! Very cool.
  29. thequietwon
    thequietwon
    The cutoff wheel in the drill press is a great idea...
