Tech Week! One Man Half Brain Brake Bleeder.
Discussion in 'The Hokey Ass Message Board' started by Da Tinman, Mar 5, 2012.
  1. Da Tinman
    Da Tinman
    The pump is capable of 75 psi so it should have no problem pushing past any residual valves.
  2. dirty old man
    dirty old man
    If the piston is still depressed when pedal is all way up, you can't pump fluid in reverse as the port from cylinder into reservoir is covered. Check to see if you have a little free play on master cylinder push rod and that master cyl. piston is pushed all the way back by the return spring.
    Dave
