Technical Tech week. Radiator overflow or steampunk pipe bomb
Discussion in 'The Hokey Ass Message Board' started by the man, Oct 10, 2015.
  1. Jeff J
    Jeff J
    Need one to go to the bottom or reverse it as yours comes from the bottom ! This way it ****s it back in and if there is to much it will blow it out ! If that makes sense !!!
    turboroadster likes this.
  2. That looks nice.
  3. 26 T Ford RPU
    26 T Ford RPU
    What im making for my T. JW
    the man likes this.
  4. What is the cap from?
  5. 26 T Ford RPU
    26 T Ford RPU
    A swap meet, that's all I can say, it will have a small pressure cap bonded inside it. JW
  6. Fedcospeed
    Fedcospeed
    If you want instant age effect, pick up some Liver of Sulfur from a crafts store. Comes in liquid or pellet form. Dissolve or add small amount in warm water.It will turn yellow.Part will have to have a textured or light scotchbrite finish for best results. Submerge part all the way.Deeper finish-more time in solution. It will darken up fast. Rinse in warm water and wipe dry with clean cloth or blow off with air. Make sure you wear a pair of latex gloves or your fingerprints will show up.
    Learned this at a side job I had and still use it for artwork and such. If you buy the jar of pellets, make sure to seal the lid good because air will effect its lifespan alot.
    You can then lightly sand or scuff to a desired "patina" Works on br***,bronze and copper
    26 T Ford RPU likes this.
  7. I
    Barons hotrods and kustoms fb
    Baronmetal ig
