Tech Week Threads 8/27-9/17
Discussion in 'The Hokey Ass Message Board' started by zman, Aug 27, 2012.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
  2. Dreddybear
    Dreddybear
  3. Scrap Iron
    Scrap Iron
    from Mesa, AZ
    http://www.jalopyjournal.com/forum/showthread.php?p=8130395#post8130395
    Here is mine, it's nothing big but sure saves time.
    Valve timing on a freshly built SBC.
    Once you get the long block of your sbc built
    1. turn the engine over till you reach TDC compression on #1 cylinder
    2. set the exhaust valves on cylinders # 1,3,4,8
    3. Set the intake valves on cylinders # 1,2,5,7
    4. Now rotate the engine so #6 cylinder is at TDC compression
    5. Set the exhaust valves on cylinders # 2,5,6,7
    6. set the intake valves on cylinders # 3,4,6,8
    now you have a very good base for startup of that fresh motor.
  4. Tech week is 3, THREE, tres , this many I l l weeks long plus a day !
    If a guy can't come up with something he ain't gonna with a weeks notice either.
  5. niceguyede
    niceguyede
    from dallas
  6. T Hudson
    T Hudson
  7. R35J1S
    R35J1S
    from Missouri
    Is there any rule that says a guy can't put 2 tech articles in the contest? I have 1 that is fairly simple and another that is a little more drawn out. I would like to post them both but understand if only one entry is allowed.
  8. zman
    zman
    from Garner, NC
    Nope, just has to be submitted during the allotted time.
  9. R35J1S
    R35J1S
    from Missouri
    sweet thanks Zman
  10. Drewski
    Drewski
  11. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  12. bjinatj
    bjinatj
  13. wingedexpress
    wingedexpress
  14. StevenH
    StevenH
  15. This is always the thread going. I love this stuff.
    Thanks to everyone that is involved.
  16. carbuilder
    carbuilder
    How do we post the link I just stared a 2 fer 1 tec steering wheel modify & custom dash.
  17. johnboy13
    johnboy13
  18. NealinCA
    NealinCA
  19. 47flyer
    47flyer
  20. Jethro
    Jethro
  21. Jethro
    Jethro
  22. Chevy Gasser
    Chevy Gasser
  23. roseville carl
    roseville carl
    Did this a while back......
    Material 1000 lb hand winch HF on sale 14.00, old chev timing chain and gears free, Alum stock 3.50 lb about 7 bucks worth, old cam slug free, and a days worth of my time, not worth much.......
    first remove outer cable drum
    drill out cam bearing to fit od of winch shaft and id of cam gear
    Braise together
    Cut inside and outside of coupling to match existing stand shaft
    cam gear bolts to alum slug
    Drill new pin hole and pin to shaft
    ***emble winch and gears and attach to stand with secure mounting points use at least 1/4" material
    and wa la you have a cheap rotater for your engine stand
    that will lock in either direction
  24. zman
    zman
    from Garner, NC
    Now post in its own thread then put the link here. Since you decided to put it in here there is no way for me to put a link to it in the list.
  25. 4 pedals
    4 pedals
    from Nor Cal
  26. roseville carl
    roseville carl
  27. Salty
    Salty
    from Florida
  28. R35J1S
    R35J1S
    from Missouri
  29. rocketbob
    rocketbob
    from West Texas
  30. scottybaccus
    scottybaccus
