TECH...well sorta... JAG IFS into mid fifties F100
Discussion in 'The Hokey Ass Message Board' started by Tall Paul, Feb 28, 2010.
  1. Bad Bob
    Bad Bob
    from O.C. Baby
    I just read through the whole thread and after talking to my friend Tony at El Mirage,i'm gonna go with a Jag front on my '60 F100. If he can do it....I CAN!!! haha
    The whole process WITH PIC'S will be posted on my thread.
  2. IRON MAIDEN
    IRON MAIDEN
    If you don't mind, post it on this thread as well. This thread has pretty much become the best Jag IFS thread on the net. The more that is posted on it, the better it becomes.
  3. Bonehead II
    Bonehead II
    Good for you Bob, can't wait to see the pic's. Iam doing the same, hope to get started around the end of July, I have '52-M3 long box ford pickup, & '87 XJS V12 jag.
    Good luck with your project.
    mike
    zagamuffin likes this.
  4. slosteve
    slosteve
    I second that! Got a '57 F-100 waiting for the '74 Jag susp I acquired recently.
  5. jclars
    jclars
    from Lynden, WA
    Well worth it. I own two MG's - an MGB and a MGA. Both fun to drive on curvy roads. Neither can keep up with the Jag/T-bird combo!
    John L.
  6. Pity the Jag threads are being shut down.
    Does it take someone to complain about the thread or what?
  7. plym49
    plym49
    from Earth
    ??? Are you talking about this thread? Perhaps it could at least become a sticky. E-Type Jag front and rear suspensions were being swapped into '49 and earlier rods in the 60s and 70s; is that traditional enough?
  8. Indy47Caddy
    Indy47Caddy
    This is one of the better Jag threads on this site, so I'll just post my question here...
    Does anyone know what the stock spring rating is on the rear Jag suspensions?
    I am using the IRS from a 1980 XJ6 for my 47 Cadillac. Looking to purchase new adjustable coilovers. The Cadillac weights a lot more than the original Jaguar, however most of the weight difference is in the front. The original coilovers seem to be very stiff (2 guys, @400lbs, can jump up and down on the frame and only get about 1/2˝ of travel). I did a search on a Jag forum and found one guy calculated each of his springs to a 200 rating (using a press and his bathroom scales, scales read 200 when he compressed the spring 1˝). Not sure how accurate or proper technique that is. That is all I have found on my searches.
    Looking at using QA1 coilovers because I get a good discount on them through work... Ratings range from 95, 125, 150, 175, 225, 250, 275, 300, 350, 375, 400, 450 & 500. What rating would you suggest?
  9. Weasel
    Weasel
    Complaining makes no difference. Hundreds of threads on Mustang II (1970 Pinto) and air bags (the trend started in the mid 1990s) still open. The Jag IFS was introduced in 1955 and the Jag IRS was designed in 1957. Jag suspension started being used in hot rods in the early 1960s and was in full force by the late 1960s. Just saying....
  10. gatz
    gatz
    Great thread !
    This answers a question I had about the IFS.
    So....no British 55º thread form ?
    However, I noticed that the heavier HexHd bolts that hold the steering arm & caliper to the spindle on my '86 XJ6 are 12mm....does that seem right?
  11. IRON MAIDEN
    IRON MAIDEN
    Lame! They shut down my thread on installing a Jag IRS in my 46' Harvester before I can even finish. WTF???
  12. 73RR
    73RR
    ...often wondered why some threads/topics get killed and other similar threads just fly on by....
  13. It was IRON MAIDENS thread I was referring to.
    I don't understand WHY it got shut down.
    There was another GOOD Jag thread shut down as well.
    MODS .. any ideas?:eek:
  14. fiftyv8
    fiftyv8
    from CO & WA
    Yet they let the 1965 Falcon thread run even though it is past the 1964 cut off!!!
  15. Cut off year is actually '65 I believe .
    I'm pretty p***ionate about the Jag IFS / IRS and have noticed how the threads about them seem to fall off , so have created a group where I'm hoping we can share tech / swap info , post our install threads etc .
    Take a look and get involved .
    http://www.jalopyjournal.com/forum/group.php?groupid=855
  16. Cut off year is definitely '65 (pre '66) according to Ryan.
    Good Idea about the Jag IFS / IRS group.
  17. Kiwi 4d
    Kiwi 4d
    If your are abandoning the front drum brakes in your 53 to 56 f100 we would be interested. Thanks.
