TECH: What to do with OEM SBC center bolt valve covers
Discussion in 'The Hokey Ass Message Board' started by 4t64rd, Jan 16, 2010.
  1. Everybody has at least one, of not a set of those OEM Small Block Chevy valve covers laying around.
  2. Get your chopsaw out and remove the ugly parts of the valve covers, making sure to catch the ribs where they are full size one either side of the bolts hole flat areas. The lip around the edge can come off after you weld the remaining parts together.
  3. The parts that you weld back together and use your grinder to make relatively smooth. It helps to weld it together from the inside.
    Once it's close, put a coat a filler on it and paint it black, use it to cover for modern bits under the hood, like relays, and ugly connectors. as a cover for a storage box, or as the battery box cover if your car is simple enough to be able to use a MC battery. Get enough of them strung together, you could make a cool console.
    What's nice is that the covers are symmetrical from side to side so both ends are the same and they are flat. This one is going for another project, but the next one I get is going in my trunk to cover the fuel pump relay.
  4. twofosho
    twofosho
    At first I thought you were going to show us how to put them on a
    Studebaker V8
  5. chaddilac
    chaddilac
    ha! that's pretty freakin cool!!! Nice job!
  6. Put enough of them together and I might just get something that looks like this:
    ...probably not wide enough, though...
  7. hotrod mike
    hotrod mike
    Son of a.... What a cool idea. You never cease to amaze. Nice job big!
  8. roosters hot rods
    roosters hot rods
    way to go big...i like the idea
  9. AHotRod
    AHotRod
    Cool BIG :)
    Now that's a great idea, a guy could think of lot's of ways to use that.
    Thanks for sharing with us.
  10. RopeSeals???
    RopeSeals???
    Great idea!
    All I could think of was adding concrete, some rope, & yellow paint to make wheel chocks out of 'em...
  11. zman
    zman
    from Garner, NC
    all tech week to the top 27
  12. AHotRod
    AHotRod
    Awesome ideas to use this for....
  13. Carb-Otto
    Carb-Otto
    from FINkLAND
    Hey, good idea!
  14. full race
    full race
    from florida
    Big you have the kool things in your head. Awesome job
  15. clever, might try it.
  16. Rog
    Rog
    Sweet! There's something useful for those after-all! Thanks for the idea.
  17. rottenrod
    rottenrod
    that is a great idea and sure enough i do have a set i knew there was a reason for keeping them
