TECH: Zoomie baffles, a monkey can do it
Discussion in 'The Hokey Ass Message Board' started by Chris Casny, Mar 12, 2007.
  1. Here is my humble tech on how to make Zoomie baffles.
    An unfortunate thing, if you don't want to get in trouble with the law.
    I've built some Zoomie a few month back.
    They are made from 1 1/2" od, 16ga tubing. Why 1 1/2" you ask, because bigger pipes would not have fit on my exhaust flange.
    For the baffles, I'm using 1 1/4" od tubing, they slip into the 1 1/2" nicely with some play.
    Step one: Cut 6" sections, in my case 8 of them.
    Step two: Make some lay out marks, I did it on 3 sides of the pipe.
    then I layed out were the holes were going to be, in this case 1" apart, staggered per each quarter turn (I'm confusing myself here).
    Step three: At your layout marks cut the pipe appox. 1/4" deep on the bandsaw, a hacksaw will work too.
    Step four: Use the pneumatic hammer with a "pointy" chisel and start making indentation into the pipe, were you cut slices earlier.
    Step five: Mounting the baffles. I basically drilled holes into the Zoomies one per Zoomie at the bottom about 1" from the end, so you can't see the bolts later.
    Drilled holes into the baffles about 1/2" from the edge, welded a 5/16" not to the inside. Voila.
    All thats left to do is to bolt the baffles on the inside of the zoomies. The baffles fit tight now since the pipe has been distorted a bit.
    I don't have shots of that process but you get the picture.
    These simple baffles have made huge difference, but not to the were the car sound like an import.
    Try it.
    The reason I made the baffles myself is, that I could not find motorcycle ones that would fit, my Zoomies.
    Besides it's much more fun doing it yourself.
  2. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  3. FiddyFour
    FiddyFour
    quick question for you. . . why not just drill holes 1/4" under the size of your chisel diameter and then blast away with the hammer? do the slots make for better flow?
  4. farm boy
    farm boy
    from reedley
    thanks Dreadman, you just saved me $160.00! I was gonna buy those motorcycle baffles for the weedburners on the 'Cancer Car'.but not now. Thanks for thinking "outside the box" Mark.
  5. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    ps......your Nash Boattail is amazing.
  6. It does not seem to flare "out" as nice when using an chisel in a hole, cutting the slots worked much better, at least for me it did.
    Keep in mind the object here is to devert the exhaust flow but not to block it too much.
  7. HotRodFreak
    HotRodFreak
    VERY INFORMATIVE HOW-TO.
    So so simple a cave man can do it
  8. tstclr
    tstclr
    I saw a rat rod a couple of years ago where the owner simply used coiled up brake lines tacked inside each zoomie pipe. Not sure how it sounded or if it really restricted flow. Anyone else see this method?
    Todd
  9. SlowandLow63
    SlowandLow63
    from Central NJ
    How Does It Sound?!?!?!?!?!?!?
  10. Hi there
    interesting...
    what sort of difference does it make sound level wise ??? is it really more silent than when you had straight thru zoomies ?
    Would be interested to know for my own car...
    Oh, and what are the sound limits on cars on your side of the planet ???
    JzF
  11. You just have to experiment, I definetaly did not take a scientific approach, and started using the db meter, all I know is that my motorcycle, is louder than the car now and I never had an issue with my bike.
  12. AHotRod
    AHotRod
    Very well done, and the you-tube is great, Thanks for taking the time to do this post for us.
  13. SlowandLow63
    SlowandLow63
    from Central NJ
    Sounds damn good. Honestly is there a difference from completely open to with your baffles? Sound levelwise not tone.
  14. rodknocker
    rodknocker
    nice.....real ****in nice...
  15. I did some tests today. I took the baffles out and started the motor, and the rumble was just great and fricking loud, then I put the baffles back in, and to me it seemed like a significant drop in volume.
    Then I made four new baffles, just for one side, that had alot more holes/indentations, I even gave the ends a little wack with a hammer.
    It sounded like the a un***uming late model grocery getter (I'm exaggerating a lil' here), but you get my point.
    Experiment, start out with my method, if it's still too loud keep going.
    But make sure, all 8 baffles are the same and the exhaust is still flowing nicely.
  16. Bad Bob
    Bad Bob
    from O.C. Baby
    "Whiley Coyete...GENIUS!!!"
    ACME zoomies,LOL! Once again,you've raised the bar for "do-it-yourselfers",Chris.
  17. Blowing sunshine up my ***, won't get you anywhere, are we still going to the Petersons on sunday???
  18. realestatemongrel
    realestatemongrel
  19. Aman
    Aman
    from Texas
    When you go to his u tube, check out the related video "the boattail hits the streets" or somethin like that. I like that sum bitach!
  20. burger
    burger
    dreadman - thanks for taking the time to put this together on here.
    one quick question ---- which exhaust setup is in place during the "boattail hits the streets" video? baffles or not?
    thx
    ed
  21. Absolutely, in fact a cop stopped me today, asking how come your exhaust is so quiet.
    Needless to say I took the baffles out after he said that.
  22. burger
    burger
    next question --- what's been done to the engine, speed parts-wise? how much compression?
    i guess that's two questions not one.
    thx\
    ed
  23. pigwilliams
    pigwilliams
    Thank's Dreadman!
    I made my baffels today and installed them, what a difference in the sound
    and in the wallet. Thank you for taking the time and posting...
