Technical Technical differences between Ford Shoeboxes and '53-'54 Mercs
Discussion in 'The Hokey Ass Message Board' started by Paketbil_förare, Oct 29, 2022.
  1. Paketbil_förare
    Paketbil_förare
    Hi everyone, especially Mercury Men.
    I've been thinking about buying a '53-'54 Mercury Monterey. As I know, 1953's are with Ford Flatheads, 3-speed manual or Merc-O-Matic, and 1954 was made with the then-new Ford Y-block and this Merc-O-Matic.
    But how much are there similarities in frames, suspension, etc., when compared to base-line Fords? Seems that is difficult to find parts for '53-'54 Mercuries. But for example, you can buy complete new frames with ISD for the 1953 shoebox. The big question is will Ford upgrade parts fit to Mercs?
  2. "Shoebox" Fords are 1949-51. Ford changed body style in 1952, but the chassis was very similar thru 53. Chassis front end changed in 1954 with ball joint suspension. I believe the Ford and Mercury chassis was very similar for each respective year.
    Paketbil_förare likes this.
  3. Slopok
    Slopok
    A Mercury is a Ford with lock washers! ;)
    jaracer, 302GMC, vtx1800 and 2 others like this.
  4. jimmy six
    jimmy six
    ^^^^^^ kinda like a GMC Pickup vs a Chevrolet.
  5. Are the wheelbase the same for same year Ford and Merc?
  6. Generally not. The Mercs are usually longer.
  7. manyolcars
    manyolcars
    I installed a 1954 Mercury front bumper on a 1950 Ford. It bolts up and the curve of the bumper end matches the curve of the 50 Ford fender lip
  8. Jagmech
    Jagmech
    Truly separate division's in the 50's. I owned 49-51 Ford's and 54 Lincoln Premier, noticed nothing interchangeable chassis and brake wise, Mercury may have more interchangeable parts, get a Hollanders Interchange manual for exact info.
  9. Paketbil_förare
    Paketbil_förare
    You're right, Merc's wheelbase is 118'' and the 1954 Ford Crestline, for example, has 115'' wheelbase.
  10. Paketbil_förare
    Paketbil_förare
    Hollander's interchange manual? Plz tell me more.
  11. sunbeam
    sunbeam
    Not only did Ford change to the Y block in 1954 but the front suspension went from king pins to ball joints same with Mercury
  12. Paketbil_förare
    Paketbil_förare
    Do you mean 1954?
  13. sunbeam
    sunbeam
    thanks guess I didn't proof read.
  14. Paketbil_förare
    Paketbil_förare
    For a while, I thought I don't know anything about old Mercs...
  15. goldmountain
    goldmountain
    If you are in Canada, the 1954 cars run flatheads.
  16. Rickybop
    Rickybop
    About 600 lbs.
  17. Jagmech
    Jagmech
    Hollanders Interchange manual, used by junkyards , pre internet, for parts swapping, they are for sale, eBay, Hemming 's, etc. Check around the net for availability. Might be of use to you. Actually any older print manual is probably a good purchase, there's a ton available now, but I can see were in the near future this stuff will just be old books and get pitched. I heard that Haynes is done printing their stuff, internet only, from now on, that's the future.
