Technical Technical model A
Discussion in 'Traditional Hot Rods' started by Gil Boyles, Apr 11, 2019.
  1. Gil Boyles
    Gil Boyles
    from houston
    Have model A sedan
    Sbc with mustang 2 independent
    Coil over shocks
    Current coils are almost fully compressed with load
    Car riding rough. I think coils are weaker than should be. Not much travel.
    Has anyone experienced this and what lb rating coil worked
    Appreciate your response
    Gil
  2. sdluck
    sdluck
    Call Pete and Jakes
  3. 62rebel
    62rebel
    Stiff suspension on a very light car makes a hard ride. You're looking for compliant shocks and springs to get a smooth ride. A's were only slightly changed from the supple and highly flexible T frame. It should be fairly simple for P and J to work out a solution for you.
  4. fastcar1953
    fastcar1953
  5. Larry Pearsall
    Larry Pearsall
    I've done many Mustang II front susp. After 6 mo. to a year the 4 cyl ordg, springs sag and lose some of there travel height. I replace them with V-6 springs minus a coil or more to get the A- Arms level to each other , problem solved... .
    62rebel likes this.
