Technical technical question
Discussion in 'The Hokey Ass Message Board' started by verde742, Jul 26, 2023.
  1. verde742
    verde742
    how do I get the BEL-AIR chrome wording off the side of my '53 Chev 2-door hardtop w/o destroying it, or taking apart interior ?
    please text: 602-617-3559 thanks
    Tow Truck Tom likes this.
  2. Joe Blow
    Joe Blow
    They were installed with barrel clips.....so you should be able to pry the script off with a plastic tool. Might want to put painters tape on the finish.
  3. Bandit Billy
    Bandit Billy
    Blow Jobs idea works fine. Use those nylon prybars.
  4. ClayMart
    ClayMart
    You really should turn off your autocorrect.
    :eek:
  5. Joe Blow
    Joe Blow
    If yuo’re albe to raed tihs, you might have Typoglycemia.....which of course, would make you a master at word jumbles.;)
    SS327, clem, VANDENPLAS and 9 others like this.
  6. BJR
    BJR
    It also helps to spray the pins with some lube, sometimes they are really stuck.
    ClayMart likes this.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    I would use a horoscope or similar device to SEE what's inside the panel , who knows what may have been used I've the years . Plus that old die cast is very brittle , use a lot of caution !
    WalkerMD, rusty valley and VANDENPLAS like this.
  8. Mr48chev
    That particular trim is hard enough to get out in one piece when you have the Barrel clips or push on clips off.
    WalkerMD, Hnstray and VANDENPLAS like this.
  9. ClayMart
    ClayMart
    What if you don't know the car's astrological sign? o_O
    :rolleyes:
    SS327, clem, 38Chevy454 and 12 others like this.
  10. verde742
    verde742
    thanks guys !!!
    Joe Blow likes this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    Stupid spell check & my bad for not proof reading .
    Bandit Billy and ClayMart like this.
  12. ClayMart
    ClayMart
    Well at least you didn't spell it with a "W" . . .
    :eek:
    Bandit Billy likes this.
  13. choptop40
    choptop40
    i use a sheetrock taping knife long enough to tuck under length of emblem and pry / rock back and forth evenly gently on all pins ...
  14. ClayMart
    ClayMart
    Were barrel clips commonly used in original production on 1950s vehicles? I think of them as coming along much later as a "field fix" type of item for body shops to more easily re-attach nameplates and moldings and such without having to access the back side of the panel.
    Seems like a lot of 60s and 70s vehicles still used stamped steel nuts to attach these bits from the factory. :confused:
    WalkerMD and 2OLD2FAST like this.
  15. Joe Blow
    Joe Blow
    Hnstray, Johnny Gee and ClayMart like this.
  16. ClayMart
    ClayMart
  17. Two work better in my experience. One on each side so you can maintain a 'straight' pull, you'll be less likely to break off the fragile pins that way. Slow and easy does it....
    WalkerMD and 41 GMC K-18 like this.
  18. spanners
    spanners
    What he said but most importantly, make sure your tongue sticks out the correct side.
    WalkerMD, vtx1800 and 41 GMC K-18 like this.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    It would take so little to verify what's behind the fender SMH:oops:
    41 GMC K-18 likes this.
  20. 41 GMC K-18
    41 GMC K-18
    Now you fellow experts can laugh all you want, but as a former dental lab tech in the Military, we had an amazing array of instruments to pilfer from supply, that did all kinds of things, that were helpful in a situation, that has been described here by @verde742
    Go to any dental supply house and purchase two Woodson #1 instruments. By having two of them, you can easily work the rounded edge of each one opposing each, other under the script, and gently use them as a baby pry bar, to gently lift the script out of the barrel clip.
    They are made out of high quality stainless steel, and you will find that these tools are well made. They come in handy for a lot of other uses that haven't presented themselves to you yet !
    Pretty handy for s****ing corrosion off of the contact points inside of distributor caps as well.
    Your welcome from Dennis.
    clem, vtx1800, Joe Blow and 1 other person like this.
  21. 1946caddy
    1946caddy
    from washington
    Sounds like the scrip is on the body not the fender is why he can't access the back wthout removeing the interior.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Is there somewhere on the body where a horoscope/ endoscope camera wouldn't fit ? I can't think of anywhere ..
  23. 1946caddy
    1946caddy
    from washington
    I can't answer that but if it were my car, I think I would pop off the interior panels for access.
    2OLD2FAST likes this.
  24. 5window
    5window
    "I would use a horoscope or similar device to SEE what's inside the panel , who knows what may have been used I've the years . Plus that old die cast is very brittle , use a lot of caution !"
    "Is there somewhere on the body where a horoscope/ endoscope camera wouldn't fit ? I can't think of anywhere .."
    Like ClayMart said, unless you're a Virgo concerned that the moon rising in Leo will affect your ability to download a dictionary, you'll want to use a BORESCOPE, not a horoscope, to look into the small spaced of that fender. :)
  25. 5window
    5window
    You'd likely get more responses if you changed your ***le to state what kind of technical advice you needed.
  26. 2OLD2FAST
    2OLD2FAST
    from illinois
    In spite of spell check & my lack of proof reading , you still KNEW what I was referring to .
    ClayMart and WalkerMD like this.
  27. 5window
    5window
    And, it was way more fun!
