Technical [Technical] stupid knock/tap problem.
Discussion in 'The Hokey Ass Message Board' started by bigblockrollin, Apr 3, 2014.
  1. bigblockrollin
    bigblockrollin
    I have a buick 455 in my 59 f100 with the most aggervating Nock/tap problem.
    Engine runs like a champ and has great oil pressure but here's the problem after it gets to running temp, if I turn it off and let sit for 20 min the knock/tap noise starts on initial start up but only lasts 20 sec at most. And thats even if it does make that sound. 50% of the time its quite.!! not sure if its a lifter losing prime or getting stuck or worse a main bearing. Any suggestions would be helpful. Thanks.
  2. bigblockrollin
    bigblockrollin
    Here is my engine info
    1973
    Buick 455
    Oem cam and valve train
    Running temp 180 deg
    Oil pressure. Start 70 psi
    Running temp 15 psi at idle
    Thanks agian.
  3. 57countrysedan
    57countrysedan
    from NY
    I've been wrong before but i would say its a lifter. I would think that if it was a bearing it would be bad and stay bad so you would have the noise all the time and i would think see an oil pressure issue.
  4. bigblockrollin
    bigblockrollin
    Yeah thats what im thinking. .. its always gone with in 20 sec. You can almost count it out. Lol
  5. 57countrysedan
    57countrysedan
    from NY
    Lol just long enough to be annoying.
  6. It does sound like a general high-mileage wear issue. I've had similar situations where I went to a 20W50 oil and it got a lot better. In worse cases, I'd run a straight 50 weight oil.
    Bob
  7. bigblockrollin
    bigblockrollin
    I've done a lot of research on this engine. And 10psi of oil pressure at idle is normal. (1000rpm) Not sure why. Maybe its the low oil capacity. Only 5 qts for a 7.5 ltr motor. .
