Technical Technical
Discussion in 'Traditional Hot Rods' started by TheGoGetter, Mar 16, 2020.
  1. TheGoGetter
    TheGoGetter
    Front hub iden***y? These hubs was mounted on my roadster on these spindels and I have no idea what they are from . They have 4 1/2 “ boltcircle
    And don’t seem to have been altered.
    I need new bearings and grease seal for them and there’s no number on the old seals :-(
    the outer bearing number is BOWER 09087.
    Inner bearing number is BOWER 15118
    The grease seals I got from the store is
    LYO 37002 don’t fit they are 2mm to big on the outer rim :-(
    Hub has a casted number on it
    IMG_1399.JPG IMG_1397.JPG IMG_1395.JPG IMG_1402.JPG IMG_1393.JPG IMG_1414.JPG IMG_1415.JPG
  2. squirrel
    Do you have a dial caliper to measure the hole in the hub that the seal fits into, and the round part of the spindle that it fits over? If so, then we can help you find a seal to fit.
    upspirate likes this.
  3. Yutan Flash
    Yutan Flash
    from Gretna, NE
    BA 1106-B3 looks like a Ford engineering number for a '52-'54 (and maybe '55-'56) Ford car. KHC is code for Kelsey Hayes Corporation. Is bolt circle 4-1/2"? This should give you a reference point.
  4. squirrel
    He said it's 4.5". I had a feeling that is what it would be.
    Is the spindle OD the same on the spindles he has, and the 56? Still a good idea to measure everything when looking for seals in situations like this.
  5. Mr48chev
    The Bower numbers will cross directly to SFK bearings You should be able to take your old seals to your local SKF dealer and have them figure that out too.
    Bower bearings are going to show up on most bearing charts as BCA as in BCA 09087 or cross to Timken 09087
    Looking at the brakes it looks like you have some year of Mopar. The welded wheel studs mean that someone replaced the lug bolts with studs.
    Still to get the right info the first thing anyone should do when asking a technical question is give us the details that you know on what you are working on and or detailed photos of the axle, spindle, backing plate from both sides and other pieces that may give us positive clues as to what we are looking at. Simply the more information you give us the better answers we give you.
  6. Mr48chev
    Hagen's cheat sheet. https://hagensautoparts.com/catalog plug in the info you have on what you are working on and go to bearings and they have the BCA / Timken bearing and seal numbers that you can check against your own.
    I still suggest just taking your bearings and old seal to the local SKF dealer and asking them to cross them though. If you pop the races out you can take them and use those numbers too.
  7. alchemy
    alchemy
    From the pics it looks like you have 48 Ford p***enger brakes, and probably spindles. Those are not 48 Ford p***enger hubs. So I'd bet the bearings and seals are not standard 48 Ford or whatever those hubs are from. They are probably a special combination measured up to mate the two dissimilar items. You are either going to have to measure carefully and search the books, or find a number on the existing part.
  8. TheGoGetter
    TheGoGetter
    Yes I do .. I’m just curious what these hubs are :)
  9. Wanderlust
    Wanderlust
    I would say that you’ve got a set of pre ww 2 Huthfucnose, apart from curiosity they could very well have been machined to accept the bearings, so your best bet is to use your measurements to do an online search, trying to find a partsman nowadays that can suss this out is horribley painful
  10. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Usually the bearing house can measure and locate the proper seals....
