Temp sensor for a 223 six
Discussion in 'The Hokey Ass Message Board' started by Daddyo's garage, Apr 3, 2010.
  1. Daddyo's garage
    Daddyo's garage
    I'm tryin' to figure out how to install the temp sensor onto my '55 f100 with a 223 six. The truck has the stock sensor for the stock gauge and a set of old cool lookin' Stuart Warner gauges with the same sensor. It's a mechanical gauge with a 2" probe and about a 1/2" fitting. Any suggestions?!:confused:
  2. i'd leave the sender for the original gauge where it was originally....then look another spot that you can screw the mechanical gauge probe into. if you can't , you may have to use a Tee. you may also need various bushings or reducers
